Results 1 to 7 of 7
    Cannonball!
    Reputation: coiler-d's Avatar
    Sep 2004
    Fire Mountain questions
    I have decided to put my old 1996 Fire mountain back together mostly for road riding and training. I have ordered some Avid V-brakes to replace the cantilevers and also ordered some semi-slick tires. My question is pertaining to the headset/fork, it is a threaded headset and I would like to know what size threadless I can use, and if I need to know anything else to order the correct headset. Also I am up for sugestions for a fork, probably in the 80-100mm range. Thanks!
    Reputation: top_ring's Avatar
    Quote Originally Posted by coiler-d
    If you`re going to use this bike for road keep the threaded headset and get a rigid mtb fork. Your bike will track better. You can find them really cheap in bike shops everywhere. The front end will weigh less too. Approx. 800g for rigid - double that for suspen.
    The fire mountain probably isn`t suited to run a 100m fork. A headset, new fork and stem can be pretty costly.
    Even with a rigid front end you can go off road and enjoy the trails. Your skills will grow!
    Konameister
    Reputation: konameister's Avatar
    Your headset is a 1". Most new headsets are 1 1/8", but you can get a Chris King in 1" or buy a converter to fit a 1 1/8" fork.
    Or go for a 1" fork. Marz. sells a 1" fork.
    Live 2 Ride
    Reputation: Kona0197's Avatar
    I had a '96 Kona Lava Dome. It had a 1 1/8th inch neck. Why would this one be different?
    My Bike: '19 Giant Talon 2 29er
    My Blog: http://http://kona0197.wordpress.com/
    Konameister
    I just looked at the picture of the bike and it looked very much like a 1", but you are sure then...
    Cannonball!
    Sep 2004
    I do know that I have an old Manitou (elastomer) fork that I was going to put on it at one time. It is a threaded fork but it has a smaller head tube than the original fork. I really was hoping to put an inexpensive suspension fork on it because I will be riding some single track with it, and I don't seem to have as much problem with numbness with suspension. I don't mind spending a little money on the old girl as I can shop Ebay, clearance, etc... to accumulate the parts I need. I don't mind the extra weight, the Fire Mountain with fork will still be around 5lbs less than my Coiler.
    Live 2 Ride
    OK here are a few low cost options for you from ebay. I have a nitro fork myself (you can buy it if you like) and these forks work great.
    Check out all three:
    http://cgi.ebay.com/ws/eBayISAPI.dll...130331738&rd=1
    http://cgi.ebay.com/ws/eBayISAPI.dll...131033331&rd=1
  1. *Blue mountain questions!
    By finchy in forum Eastern Canada
    Last Post: 08-24-2004, 04:10 PM
  2. Mt Lemmon: Exteneded Doggie Drivel
    By SunDog in forum Arizona
    Last Post: 08-09-2004, 05:02 PM
  3. Question about my Fire Mountain
    By netbeui in forum Kona
    Last Post: 06-17-2004, 05:21 AM
  4. Fire XC Pro...1.8" and 127tpi questions
    By upstateSC-rider in forum Wheels and Tires
    Last Post: 05-18-2004, 12:18 PM
  5. Blast vs. Fire Mountain - $200 Difference
    By noonievut in forum Kona
    Last Post: 04-21-2004, 06:54 AM
