Results 1 to 8 of 8
    May 2005
    8 Inch rotors on coiler
    I have been taking my coiler for some DH runs and i found that i need to step up to 8 inch rotors. What do i need, besides the rotrors, to do this? More importantly where can i buy the parts i need. I have done some searching and found i need an adapter but i cannot find the right one online.
    Still on Training Wheels!
    Reputation: drum714's Avatar
    The adapters for the rear are pretty standard, but the adapters for the front are based on what type of fork you own. Marzocchi and Rock Shox usually use the same adapter, where as Manitou uses a different adapter. Also if you have a 20mm front axel you may need a different adapter. Typing this I'm being very vague, but going to your LBS and testing a few to see what works is really the best method.
    It's not a good ride if you don't scare yourself at least once.
    Yeah...I'm Sponsored..................by my Bank Account
    Reputation: Coiler Mad's Avatar
    Jan 2005
    I've done this on my Coiler, upgrade kits are widely available in either +20mm or +40mm, you will need to go for +40mm kit, this will include a rotor and adaptor, just bolt them on and away you go!!
    Jun 2005
    http://cgi.ebay.com/Disc-Brake-Rotor...QQcmdZViewItem
    I think this will work. You can contact them and they should be able to tell you. I am pretty sure the front and back of the Coiler are IS.
    Dec 2004
    qr front forks have problems
    with upgrading to 8in rotors. I have an 05 coiler which comes with the drop off fork with quick release axel. Hayes does not make a 8 in adapter for the qr so i had to go to avid 5s and even then they dont recomend8 in rotors. so i slapped avids 7 inchers and all is well
    Meh.
    Reputation: XSL_WiLL's Avatar
    I'm running Hayes Mag with 8 inch rotors front and rear on my bike with the stock fork (for now anyways). The adaptor for 20 mm forks seems to work.
    Jun 2005
    I got an 8" rotor and an adapter for my Coiler. Little disappointed. I thought it would make more of a difference than it did. Time for better brakes, I think.
    Unshaven Yak
    Reputation: Stinky Wiz's Avatar
    I have a friend whose 03 Stinky came with QR's and 8" Hayes rotors. No problems there....and I run 8" rotors on all my QR front forks with no issues. There are adaptors out there to fit just about anything you like.
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. Replies: 24
    Last Post: 03-03-2006, 11:25 PM
  3. Full 05 Kona Coiler Review
    By Mountainbikextremist in forum Kona
    Last Post: 07-26-2005, 12:07 AM
  4. 2005 Specialized Demo 8!!!!
    By COmtbiker12 in forum Downhill - Freeride
    Last Post: 05-24-2004, 02:05 PM
  5. 7 inch 888 Vs. 8 inch 888
    By R_D in forum Downhill - Freeride
    Last Post: 04-01-2004, 01:28 PM
