    Reputation: Coiler Mad's Avatar
    Jan 2005
    6" to 8" disc upgrade
    I've got a 2004 Coiler and want to upgrade the front brake disc size from the stock 6" to 8", does any body know of any upgrade kits for the Hayes set up?
    inner peace to make peace
    Reputation: TrailNut's Avatar
    $215 Hope M4
    you may want to resort to a $215 Hope M4 200mm
    “Everyday is a good day,” from the Blue Cliff Records, Yun-men (864-949 AD).
    sLigHtLy lEft oF CEntEr
    Reputation: burninator's Avatar
    Quote Originally Posted by Coiler Mad
    I think all you need is an 8" mount bracket ($10-$20) and an 8" rotor ($20-$30)
    Appalache Cycles
    Reputation: RobV's Avatar
    Yeah, all you need is the larger caliper mounts & discs. I see you're in the UK too, so you can get them from CRC for £12.99 for the mounts. There are two different mounts for the front, one for QR and the other for 20mm and one won't fit the other. I upgraded my fork to one with a 20mm axle so had to put the wider 20mm specific one on.
    Rob
  1. Singulator vs. ENO disc to upgrade to disc brakes
    By TwistedCrank in forum Singlespeed
    Last Post: 11-27-2004, 08:46 AM
  2. Cannondale Disc brake upgrade
    By afinstad in forum Brake Time
    Last Post: 09-20-2004, 05:12 AM
  3. Switching 6" Promax disc brakes for 8" Avid Mechs
    By Phat Tire in forum Brake Time
    Last Post: 08-19-2004, 08:12 PM
  4. 2004 Trek 4300 disc upgrade?
    By Gimmezell in forum Brake Time
    Last Post: 06-08-2004, 01:58 AM
  5. What's needed to convert Hayes 6" to 8"?...
    By UPSer in forum Brake Time
    Last Post: 03-15-2004, 12:30 PM
