2018 Kona Unit converting to geared- Mtbr.com
Results 1 to 3 of 3
    Apr 2019
    I recently bought a Kona Unit 2018 and will pick it up soon. I will do a three day bikepacking tour right after picking it up and want to put a cassette/gears on it before.
    Since I can't check by myself I would like to know which tools I need to remove the single speed cog. Is it the same I would use to remove a Shimano cassette? I'm a bit of a layman concering bikes.
    I have this tool for the cassette: 2018 Kona Unit converting to geared-bg9jyww6ly8vchjvzhvjdc80otmzmtdfms5wbmc.jpg
    I also have a chain whip and the Kona derailleur hanger (Type CC)
    Also if there's anything else I need to keep in mind please let me know.
    RaD
    RaD is offline
    Trampelpfadbenutzer
    Reputation: RaD's Avatar
    Yes, it will fit.
    Reputation: Rynee's Avatar
    Aug 2014
    Apart from the obvious (shifter, derailleur, cable, housing) and assuming you are not adding a front derailleur, you will want to make sure that the front chainring is a narrow wide style ring.
    Based on FSA's and Kona's website, that should actually be ok:
    https://shop.fullspeedahead.com/de/d...inring-1x-3023
    If you zoom into the crankset area, it very much looks like it says "megatooth" on the chainring, and the ring looks like a narrow-wide style.
    http://images.konaworld.com/2018/full/unit.jpg
    Nevertheless, check it out when you receive the bike. If not, you should change that one as well. As shown above the 2018 unit has an FSA Comet Modular crankset, so any new chainring will need to fit their mounting system. In case you're buying it from a shop, they should hopefully be able to supply the correct one.
    If possible, I strongly recommend to use an oval chainring instead of a round one. Especially as you plan to be on a multi day tour, oval rings will help you conserve a lot of energy during those long days in the saddle (i made exactly that experience on a 3 day tour with a 10 speed Honzo ST).
    Hope this helps (and sorry for stating the obvious in the first sentence).
    Enjoy your new rig!
    Ah yes, pics would be highly appreciated
  1. Replies: 4
    Last Post: 03-21-2016, 09:36 PM
  2. Replies: 3
    Last Post: 04-18-2015, 03:46 PM
  3. 2013 Kona Unit or 2014 Kona Unit
    By evosil98 in forum Singlespeed
    Last Post: 12-10-2014, 10:06 AM
  4. Kona Unit geared hanger.
    By Nrs1Rider in forum Kona
    Last Post: 07-10-2014, 01:20 PM
  5. 2007 Kona Unit or 2008 Kona Unit 2-9?
    By EVERYUSERNAMEISTAKEN in forum Singlespeed
    Last Post: 01-28-2008, 01:42 PM
Members who have read this thread: 13
