2008 kona stinky primo floating brake?????- Mtbr.com
Results 1 to 2 of 2
    so i have a 08 Stinky primo with the floating brake on it. It needs new ends to the rod that comes from the seat tube to the rear brake. Any idea what size these are and were to get them. Instead of getting the hole kit from Kona.
    Mike G.
    The ends of the Floating Brake arm, are commonly know as a HEIM JOINT.
    These can be purchased from most high end automotive parts outlets, or simply google for results.
    You'll need to verify if one or both are reversed thread. To determine the rod/thread diameter, simply get a couple of open end wrenches (metric) and slip the open end over the threads, the wrench that fits best, will be your size/diameter.
    Hope this helps...
  1. floating brake for kona stinky
    By timmyfosho in forum Downhill - Freeride
    Last Post: 05-05-2010, 03:43 PM
  2. floating brake for Kona Stinky (mod edit to title)
    By Amazing Larry104 in forum Downhill - Freeride
    Last Post: 01-29-2007, 06:33 PM
  3. 06 Kona Stinky Primo DHX help
    By kntr in forum Kona
    Last Post: 08-12-2006, 07:44 PM
  4. 04 Kona Stinky Primo
    By likestocrash in forum Downhill - Freeride
    Last Post: 02-03-2005, 01:38 PM
