Results 1 to 7 of 7
    jzt
    jzt is offline
    Reputation: jzt's Avatar
    '05 Dropoff Triple questions
    Hey all,
    I managed to get my hands on an OEM '05 Dropoff Triple. As far as I can tell, it's a Jr T with more primitive damping. Any tips n tricks to improve the fork's performance, ie rebound, positive air, etc etc.. Just wondering if anyone out there's tinkered with theirs, especially those who've bought the '05 Stinky.
    Dec 2004
    I have only set my air presures on my 05 stinky that came with the drop-off tripple.
    right leg i set it at about 50 psi and the left i think is at like 5psi.
    Im about 175 lbs and have the fork angle as high as it would go.
    Its starting to make a clunking noise kinda..not sure if thats cause im riding in 30 degree weather or not though..
    over all its a decent fork.
    cheers
    Just roll it......
    Reputation: ebxtreme's Avatar
    Drop off Triple's a bit different than the Jr. T
    The main differences are that the Drop off Triple uses a standard QR interface with the wheel (which is an advantage if you don't own a 20mm hub) and has 6" of travel vs. 7" for the Jr. T. Also, the Jr. T uses the SSVF damping system - which you mentioned.
    Sorry, I don't have any experience with this fork to help you out.
    EB
    Dec 2004
    ebxtreme, the OEM 05 will have a 20mm through axle..
    Just roll it......
    Yep, I stand corrected.
    It would've been helpful if I had read it better. 2005's indeed are coming with 20mm axles.
    EB
    Dec 2004
    for reference if any searches here is some pictures of mine.
    Dec 2004
    Jr.T.
    Quote Originally Posted by ebxtreme
    EB
    As far as to Jr.T. for both 2004 and 2005 it`s all the same apart from the decals. Thus they have SSV damping not SSVF, but still work different to Drop-off Triple.
  1. 05 liquid 25 questions
    By superbill in forum Trek
    Last Post: 12-17-2004, 12:07 PM
  2. Joe-Kona- 05 Coiler Questions
    By forester in forum Kona
    Last Post: 12-02-2004, 06:05 AM
  3. 05 Blur questions. Help needed
    By JDO in forum Santa Cruz
    Last Post: 11-18-2004, 07:13 AM
  4. 04 BH Expert vs. 05 BH FSR
    By DBoy in forum Downhill - Freeride
    Last Post: 10-05-2004, 08:34 PM
