Results 1 to 7 of 7
    Jun 2005
    04 Coiler tyres???
    Hi every1 does anyone know what is the max. tyre width you can use on an 04 Coiler (frame not fork).
    Cheers peeps...
    Reputation: shiggy's Avatar
    Dec 1998
    Check the specs on my Tire Site.
    mtbtires.com
    Jun 2005
    that's all good but I want to know what the maximum tyre width is i can use with my frame???
    Reputation: Coiler Mad's Avatar
    Jan 2005
    Hi, on my Coiler, can't go much higher than 2.4, some 2.5 tyres will fit, the frame clearance is not the problem, it's when in the granny ring/large rear sprocket gear the chain catches the side knobs on the tread, does'nt seem to be anything really you can do to get round this apart from dish your wheel over, but this seems to be a bit extreme!
    Jun 2005
    Cheers, I think I'll give a 2.5 a go - I hardly use the granny anyway, and also I'm upgrading to a close ration cassette which sould lower the chain line slightly. Cheers 4 the help.
    Dec 1998
    Quote Originally Posted by grahamjtriggs
    Every tire is different. A Kenda Kinetics 2.6 fits fine. A WTB Timberwolf 2.5 is marginal.
    Do you have a tire on your Coiler now?
    If so, measure the clearances between the tire and swingarm/derailleur/seatstay.
    Find your tire on my spec charts. Compare with other tires models listed. You can get a good idea what may work.
    mtbtires.com
    Jun 2005
    cheerz guyz
  1. Replies: 24
    Last Post: 03-03-2006, 11:25 PM
  2. Full 05 Kona Coiler Review
    By Mountainbikextremist in forum Kona
    Last Post: 07-26-2005, 12:07 AM
  3. Help 04 or 05 Gemini....long post
    By spacoli in forum Bike and Frame discussion
    Last Post: 03-04-2005, 12:58 PM
  4. Elsworth Dare... hit or miss?
    By Korrupt in forum Downhill - Freeride
    Last Post: 08-13-2004, 08:17 AM
  5. 04 Stinky, 04 BigHit? or 04 Atomik?
    By Phil_Mosco in forum Downhill - Freeride
    Last Post: 05-13-2004, 12:29 AM
