Monarch Plus with Debonair- Mtbr.com
Results 1 to 2 of 2
    Reputation: thedeathstar's Avatar
    Mar 2012
    Looking into moving from a CCDB to a Monarch Plus on my Delirium. I only have the one bike so I need it to be more like an All-Mountain bike and less like a freeride, and I can't get the DB set to where it feels good. It feels too plush and weak in the middle.
    Given this, is the Debonair a good choice? Is the small bump sensitivity even needed on a design that's already so active?
    Yebo Numzaan
    Reputation: Muttonchops's Avatar
    Hey
    I would encourage you to do some more testing and setup. I have found the CCDB to be highly tunable and I am still learning after more than a year. I ran a Monarch on a Nomad for a couple weeks earlier this year and felt like i missed the ability to tweak various settings.
    Assuming you live in Utah so there are a couple things you could play with to get the bike to feel a little firmer for those sorts of trails.
    Perhaps higher air pressure - less sag - and the play with the compression settings to compensate.
    One thing Noel talks about frequently is suspension bracketing - so to get the feel you are looking for - try making 'big' changes to your settings and ride a section of trail (repeatedly) to see whether you like the change - then make a change to the other end of the spectrum and decide which of the two options you preferred (e.g. 12 clicks of LSC and then 0 clicks)
    Hopefully you can fire this forum up for a week or two of recommendations and ideas
    Good luck
    I support EMBA
  1. Monarch Plus Debonair for E29?
    By tshred in forum Specialized
    Last Post: 10-08-2015, 11:11 PM
  2. Replies: 15
    Last Post: 06-03-2015, 09:39 AM
  3. Monarch Debonair Plus R vs Debonair RT
    By frango in forum Shocks and Suspension
    Last Post: 04-14-2015, 12:25 PM
  4. Monarch RC3 Debonair
    By marcus_dukakis in forum Where are the Best Deals?
    Last Post: 02-22-2015, 04:23 PM
  5. New Rockshox Monarch Plus DebonAir for HD?
    By spokeywheeler in forum Ibis
    Last Post: 04-03-2014, 05:14 PM
