Fugitive build ideas & plans- Mtbr.com
Page 1 of 6 12345 ... LastLast
Results 1 to 200 of 1122
    Reputation: Kombinat.PL's Avatar
    Oct 2011
    I'm planning my Fugitive build and as I haven't build up a new bike for the last 3 years I would like to ask you guys for some critique and tips on how to improve durability and comfort without sacrificing weight.
    General idea behind the build - 135mm travel option
    A tough, durable trail build for all day epics, focused more on comfort than racing against the clock. Key aims are low maintenance requirements and limiting total cost of ownership.
    Hence I stay away from carbon bits on the bike, as I had hit and miss experience with composite parts on my current bikes.
    Air is also out of the question, as you can save shit load of money on service, as coil is way cheaper to service if you ride a lot. Plus I like set and forget nature of coil. The fact that, Knolly feels awesome on coil is another reason to dismiss the evil of air suspension
    Suspension
    My preferred setup would be DB Inline Coil with OPT remote lock-out coupled with DROPT remote for on the fly adjustments and clean cockpit.
    For the fork I'm thinking Cane Creek Helm Coil, if it will be available in time.
    That way I would have a low maintenance setup and lower service costs than air.
    If Helm 29 Coil will not be available, I will go for a used Pike and AC3 kit. Maybe MRP Coil if it will have service support over here in Europe.
    Wheels
    A bulletproof setup with DT swiss 350 hubs with upgraded ratchet and EX511 rims. If budget allows maybe I9 hubs.
    Cockpit - which alloy bar would you recommend?
    Syntace Megaforce 2 stem and I'm lost which alloy bar to choose. Renthal Fatbar? People rave about the ride quality, but I haven't tried one yet. Any suggestions for durable and comfortable bar?
    I had plenty of top carbon bars, and they're great, but there's one thing I hate about them is that I'm always wondering if they're safe to ride after a crash in the middle of nowhere. Second guessing gets on my nerves really bad. I know it's stupid but I can't get out of my head.
    I want to try also push-on grips to see how they improve comfort over long rides.
    Drivetrain
    Will go with X1 drive train, as I have almost new one on the Chilco. Propably I will switch to 12sp XTR with DM rings, which is to be launched for 2019.
    Brakes - Modulation - any alternative to Guide RSC?
    Modulation is key for me so probably Guide RSC. Or Hope's E4/V4? It's a tough choice as nothing is perfect in that department.
    Dropper
    Bike Yoke or 9.8 -reliability is a must!
    Any ideas and pointing out anything to improve are really welcome. I want this bike to be right from the start and avoid changing out components mid season.
    Below estimated weight of full coil build with rather durable parts.
    Attached Thumbnails Attached Thumbnails Fugitive build ideas & plans-comparison.jpg
    Reputation: David R's Avatar
    Sounds like a good plan to me. I haven't serviced my CoilIl yet so unsure how the cost compares to the Inline air, but the service intervals are the same so not sure how much cash you'll save there. Certainly would feel good and more reliable though!
    You going to run 120mm or 135mm? I'm still waiting to see a full geo chart for both options, the weight etc will be the same and if the geo is similar I'm trying to get my head around what the advantages of the shorter travel option could be.
    Oct 2011
    I will go for 135mm.
    I did a calculation on total cost of ownership of air vs. coil with CC products, Fox is even more expensive to service here than CC, and the main saving comes from lack of servicing air spring, which is quite expensive. I assumed one air spring service per year.
    Apr 2005
    Brakes - if you want modulation, have you considered Magura MT7 or MT5? I have the MT7 on my Endo and they're very powerful with excellent modulation. I just ordered a set of MT5 for my old Delirium-T. They're easy to bleed and they're very affordable from those German online stores.
    Oct 2011
    @ B&F,
    I didn't like their levers. I have really small hands and I must have levers close to bars with small throw. I haven't tried them with Danny M new levers though.
    You have the improved levers? Or the old ones?
    Apr 2005
    I have the old levers. I like them, but I know other people who didn't like them at all, I guess it's a personal preference. The MT7 suit me fine (I wear a size large glove). I have read that with the MT5 you can dial them in so the lever is much closer to the bar and they suit people with smaller hands. Yes, the new levers look nice but I don't feel the need to upgrade.
    Oct 2011
    @B&F,
    I will need to test MT5 then. I had a look and they come on a few German brands, so I will find someone around here with them.
    Reputation: vikb's Avatar
    Quote Originally Posted by David R View Post
    FWIW - Our local-ish CC service centre charges the same price for an air or coil CC Inline rebuild. If you go direct to CC it's $10 cheaper to do a coil Inline service....$150 vs. $160.
    The service intervals for the air & coil shocks are the same as it's based on the damper not the type of spring used.
    Safe riding,
    Vik
    www.vikapproved.com
    Quote Originally Posted by Kombinat.PL View Post
    Suspension
    I would skip the shock remote. The only time most people touch the climbing switch on their shock is for long smooth road climbs. For that you can reach down and flick the switch. I can't think of one Knolly owner who has bothered with a bar mounted remote after riding the 4x4 suspension.
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2005
    Geo on 120 vs 135 mm should be the same (static) as the shock has the same eye-2-eye length in both travel options (just the stroke that differs). Of course there will be a little more sag on the longer stroke shock ...
    Dec 2005
    Everyday 26 does service on MRP in Germany if that is of any help ...
    Dec 2005
    Oh and for bars I have been very happy on Deity bars (love their shape). But why no Syntace bar if you plan to use their Megaforce2 stem (my favorite stem by the way)?
    Oct 2011
    @ Vikb
    For my market a difference between and air shock-fork combo and a coil setup a price difference per one service is more to the tune of 40-60 bucks. Twice a year it makes for a nice set of tires (tires are cheaper here than in US).
    Concerning a remote, I think I will test it. After a few years with Chico I would find a use for remote on short smooth gravel sprints over here.
    @ Zuzi. Thanks for the reminder about Syntance. I had only carbon Syntance bars. Any experience with their alloy offerings? Are they comfy?
    Oct 2015
    I normally swear by carbon bars, the vibration damping is real. A buddy just got the spank vibcore bars. And they feel just as good as my carbon.
    Apr 2015
    for brake why not go for hope if you want modulation?
    I would go with a ribbon coil fork. I have one on my Warden C and love it.
    Reputation: CHROMAG19's Avatar
    Mar 2014
    DVO Fork and shock
    CHROMAG BZA bars and stem, saddle
    Chromag Scarab flats
    Sram GX Eagle
    Hope headset and bb
    i9 305 wheels
    maxxis tires
    Bike Yoke Revive dropper
    magura stoppers
    Oct 2011
    Quote Originally Posted by pedrosalas7 View Post
    Hope's can be pricy depending on exchange rates, so they're a second option funds permitting.
    I think I will go for CC Helm Coil on a nice bro deal. Plus there's no way to test Ribbon overhere
    Quote Originally Posted by CHROMAG19 View Post
    I like Chromag parts, but haven't had really chance to ride their alloy bars. Aren't they very stiff to suit freeride more than old man's trail riding?
    Oct 2011
    Added estimated weight for 135 full coil build. It comes around 15 kg. Not bad for am build.
    I guess with air and carbon components, one can get around 13,5kg. With carbon version 13 kg doesn't seem impossible.
    Reputation: knollybikes.com's Avatar
    These are reasonable estimates. The frame is very slightly heavier than the current 27.5 Endorphin: A small amount of weight was added on purpose for a few reasons:
    • Improved Industrial Design: no matter what, this always adds weight;
    • Increase in downtube cross sectional area at BB for increased torsional rigidity;
    • Larger bearings and bushings;
    • Trunnion shock mounting weighs more than conventional eyelets due to the addition of 2 more bearings and hence, increase in linkage size for those bearings;
    • And the frame is bigger and stronger as it's designed for larger wheels and to be thrashed on: we're testing them to the same standards that we currently test the alloy Warden to.
    29er bikes in general weigh about 1 - 1.5 pounds more than equivalent 27.5 bikes strictly due to the wheels, so if you're a current Knolly owner and build the Fugitive up similarly to an Endorphin or Warden for example, expect your equivalent build weight to be about 1 - 1.5 pounds higher mostly due to the 29er vs 27.5 wheels.
    Cheers,
    Noel Buckley
    www.knollybikes.com
    Instead of PMs, please contact me here.
    Another possibility for brakes would be XTR race levers with Saint/XT 4 pot calipers.
    Ripley LS v3
    OG Ripley v2 handed down to son
    Oct 2011
    @TwoTone
    I never got along with how Shimano brakes' feel.
    @Noel,
    Thanks for the validation and detailed info!
    I added a comparison with AIR/Ca build. With Air, bling wheels and light cranks you can get below 13,9 kg.
    If still coil is the preferred suspension, going for wheels, cranks and carbon bar will bring weight down to 14,7 kg. However budget will need to be increased by I guess 40-50%
    @TwoTone
    @Noel,
    That's why I said the Race levers. They don't have the Servo Wave which makes the other models feel on/off to people.
    Ripley LS v3
    Reputation: Magsrgod's Avatar
    Build looks super solid. Your looking at slip on's for longer rides, do you get a lot of hand fatigue? I know this sounds stupid but have you considered the Pivot Phoenix Padloc grips? You have to do the stupid angle cut on your bars for Padlocs, but they are damn comfy. I've broken various bones in my hand and have game keeper's / skier thumb injuries on both of my hands. I would bounce back and fourth between ODI rouges, Ergon GA2 and GA2 factories until I found these.
    Jun 2014
    I've just switched to Code RSC brakes from Guide RSC. Awesome upgrade that I'd recommend.
    2018 Nomad 4
    2016 Kona Honzo Ti SS
    Retired.
    - Mondraker Dune
    - Yeti ASRc
    - Banshee Rune
    - Niner ROS9
    - Niner WFO
    - Ibis HD3
    - Ibis Ripley
    - Niner Air9 RDO
    - Rocky Mountain Element
    - Ellsworth Epiphany
    - Spcialized Stmpjumper
    - Claud Butler
    Reputation: Bizarro's Avatar
    Trying to figure out if I want to take the leap to an xl being 6'2" and 252 lbs. My chili is a L and I should be on an XL with that dirty little ho but I make it work... love that thing. I know the ATT is a bit longer on the Fug than the chilli and the Reach is longer.. hummm... but I don't know. Maybe an XL fug and shorty stem?
    I know some knomers out there like me so whatcha thinking for yourself?
    k n o ll y r o c k s
    Wondering the same thing, at 183cm I'd be comfortable on the large, but I've always been curious about longer bikes and would be interested to try something with significantly more reach than my L Endo. Best bet would be e demo, but not really an option for me down under.
    Oct 2011
    Quote Originally Posted by Magsrgod View Post
    There are three reasons I want to go push-on instead of lock-ons:
    1. I have small hand/short fingers and the best grip/wrap on the bar I have with grip diameter of around 26-28 with normal gloves. Lock-ons are around 30mm, tested almost all of them, so slightly too thick with gloves.
    2. The ultra tacky Renthal by being really slim and providing this sticky grip let me clench the bar less, and by this reduce my fatigue over long rides. Having to use less grip to hold on to the bar is quite important to me, as after braking my elbow, twice, I don't have the strength of the grip I used to.
    3. They're really cheap while providing great comfort and bike feel. I was skeptic but now I'm a convert.
    Quote Originally Posted by mattnz View Post
    It's an upgrade in terms of modulation, power or both?
    My left hand, after the injury, is not particularly strong and finger control could be better. Hence I need a good modulation on the brakes with predictable bite point.
    Quote Originally Posted by Bizarro View Post
    I'm 182 and currently on L Chilcotin. I ride with 60mm stem, but with 70 mm I get the position Paul is talking on Pinkbike . For Fugitive it means L with 50mm stem, while going for XL would mean 35mm stem. The short stem makes me hesitant with XL, as from experience on ROS9 with 50mm stem and 51mm offset, I know that 50/50 combo feels balanced to me. I think Minaar also was testing this and found out that stem more or less inline with offset give the most balanced feel.
    By the way I asked Noel this question. Will share when answer arrives.
    Reputation: Legbacon's Avatar
    I'm 5'9" and had thought that the large would be perfect until the geometry got stretched out. I'm going to have to demo. I recently built a hardtail with 470mm of reach and while I love it, I don't know if I want longer.
    Formerly Travis Bickle
    Team Robot. "modulation is code for “I suck at brake control.” Here’s a free tip: get better."
    Jun 2014
    Definitely more power in the codes power. Modulation is very good, but the power does come on quicker than the guides. I suppose from a modulation perspective they sit between an XT brade and a guide. I am running guides on my honzo (with fresh bleed and new levers) and codes on my SC N4. both get smashed on DH runs in Queenstown, NZ.
    2018 Nomad 4
    Retired.
    - Mondraker Dune
    - Yeti ASRc
    - Banshee Rune
    - Niner ROS9
    - Niner WFO
    - Ibis HD3
    - Ibis Ripley
    - Niner Air9 RDO
    - Claud Butler
    Reputation: flyinmike's Avatar
    Dec 2005
    I'm sorry, I haven't seen an e-mail or PM with your question, but I'll reply here
    At 182 you will definitely want an Large frame not an XL.
    Obviously bike geometry has changed a lot over the past 5 - 6 years and what we thought was pushing the envelope back in 2012 or 2014 is pretty much considered to be standard geometry now. The Fugitive will embrace these changes as the geometry measurements show, so please size correctly and don't try and size up or down just because you "think you need to". Additionally, with the advent of longer stroke dropper posts (default now being 175mm for most riders and up to 200mm where possible), we've accommodated that on these frames: this increases sizing flexibility as standover height becomes less of a concern for a given frame size.
    Cheers,
    Noel Buckley
    www.knollybikes.com
    Oct 2011
    Quote Originally Posted by knollybikes.com View Post
    Thanks for info! I wanted to go with L, but just wanted to be sure that my thinking is correct. I will test a few stem lengths, but now I now my starting point of 50mm and will go to 40mm, to see how it will perform.
    Oct 2011
    After doing some research and deal hunting I managed to get the weight to around 15kg with full coil build.
    Also I think will go for a full custom paint job on that bike.
    Key changes vs. the original idea:
    Wheels:
    Ibis 942 on I9 - saved almost 400 grams and got sweet deal on them
    Cockpit:
    Lighter saddle - Ergon Comp
    Lighter bars - Syntace Vector 780 20mm rise.
    I got very good deal on those two as well and saving almost 200 grams.
    Details below:
    Reputation: inonjoey's Avatar
    Great thread. I'd started my own thread before seeing your's - shame on me! Big thank you for putting such a detailed thread together.
    I'm pretty much in line for the type of build you're going for with durability, low maintenance and not too much carbon.
    Main differences for the build I'm considering:
    Full GX Eagle including the cranks; I just can't justify going carbon on the cranks because the weight savings is not that much and the added cost is significant.
    Yari at 150 with Avalanche cartridge. Great bang for the buck and I'll save the Yari cartridge to put in whenever I need to take the cartridge out for mods or unexpected maintenance. I get where you're coming from with coil, but I think this will be a pretty excellent fork.
    Float DPX2. I'm still considering coil, but I thought I'd try the DPX2 and then maybe send it to Avalanche for their mods. That said, considering I'd only be adding 90-100 grams for the coil, it's looking a bit more enticing.
    DT350 hubs laced to We Are One or Derby rims. Should be nice and light with great reliability, easy maintenance and decent 36t engagement.
    I'm still debating brakes. I don't care for the Guide RSCs that I currently have. They work, but the pistons often get out of sync and I have trouble getting them completely drag free. I'm debating between Hopes or Deore XT levers with Saint/Vee calipers. I love the idea of the Hopes, but I like that the Shimanos use mineral oil and pads are super easy to come by in a pinch.
    "So you think it's the hat?... A lot of people hate this hat. It angers a lot of people, just the sight of it." - Uncle Buck
    Oct 2015
    Quote Originally Posted by inonjoey View Post
    The Avalance Yari is such a nice fork. Unless you want to get it reshimed changing oil is all you do.
    Oct 2011
    Hi,
    This thread isn't just mine. It was meant for all to share build ideas. So maybe you could merge your thread with this one to keep things in the same place? If you don't mind?
    My view is that, regardless of my other personal considerations, for 29er brakes with good modulation can improve the ride a lot. With 29er acceleration, if you overbrake, isn't as easy as with 26er and you have way more grip, which means you should brake less. Hence any graby/anchor like brake could/would make your ride way less flowing, slower and more physically demanding.
    Above is the reason I'm reluctant to go Shimano, which can be had dirt cheap over here, and thinking going Hope. Guide were an option, but pricing here is on par with Hope's, so I'm not willing to take risks with them.
    If you still thinking Shimano and want less graby brakes, try the Gwin setup described a few post above by TakeTwo.
    Concerning carbon cranks. If you ride places like Finale Ligure they're an expensive proposition. Finale eats them, literally. For loamy places they're definitely an option.
    However seeing pedal inserts fall out of top RF cranks after a climb, I would be very, very careful, which brand of carbon cranks to buy. Broken or sheared off ankles are bitch to heal and rehab. Praxis maybe?
    Non of this will matter when Shimano will release their 12sp XTR with direct mount rings, which is to be launched end 2018 start 2019. You will get bomb proof uber light alu cranks with normal spindel. DUB? No faaking way
    Reputation: slider_phil's Avatar
    Aug 2014
    As someone who's got and ridden guides, XTs and Hopes. I'll never run anything but Hope on all my bikes from now on. I got caught with the sticking pistons with my guides but I'll admit the XTs have been going strong like XTs do for years. Great for a budget option but they've got no adjustment and they're really "on/off" in nature.
    Hope gives better modulation than guides with more power than XTs in a nice shiny machined aluminium package. Bleeding them is like bleeding car brakes, piece of piss. Plus, if for some reason you do break something in a crash then Hope will sell you replacement parts. Even for stuff that they made back in the early 2000's.
    Jan 2018
    I have been on hydraulic brakes since 1998. Have used a slew of these and the XT seems to be superior to any others I have used. Two different pads available and you can even use one metal and one resin in each caliper if all metal is too much stopping power for you. No Hope ridden lately put their hubs are ridiculously loud. Brakes must be quiet, great modulation and not weigh too much. XT are a tad heavier than others but brakes and tires are the most important safety devises on our rides. So a bit more weight so I can have all the rest.
    Apr 2015
    +1 here for hope brakes. I've been on m785 XTs, Guide RS and Hopes tech3 E4s.
    They have more stopping power than XTs and better modulation than guides. they are a bit more expensive but worth it. bleeding is very easy, no syringes or special tools needed. Pads last a long time and aren't really hard to come by, specially online.
    Plus they look really nice, and can be had in a lot of colors if you're into that sort of thing
    Ride On
    Reputation: geraldooka's Avatar
    Quote Originally Posted by Travis Bickle View Post
    Remember though that on a hardtail reach will never be shorter than spec in riding (yes you can shorten it by adding a taller fork, wheel etc.) On a full sus it will vary depending on what you and the bike are doing at any given moment.
    Here's the Pipe dream at full fork compression:
    Demo day on 15 April
    Oct 2011
    That's the fork for my build : Helm 29
    Now CC needs to release T-mount Coil [IL]!
    Reputation: formu1fan's Avatar
    I am going with the SL build through Knolly, with the I9 enduro 305 wheels and DPX2 factory. I will run the Code RSC for a bit, but eventually I'll swap them out for either the M4s I have or orange E4s to match the frame. I'm having problems with my rear M4 piston sticking so I'm working on fixing that. I may also pick up a coil like the DBInline with CS for some fun, but we'll see. Can't wait to see what others are building up.
    2013 Kona Process
    Canfield Yelli Screamy
    Sep 2013
    When looking at these builds I am wondering a couple of things.
    1. Is it in fact true that the only difference in the LT vs regular model is the shock stroke?
    2. Have there been any confirmed timelines yet on when these will be available outside of the July time frame on Knolly site?
    Quote Originally Posted by Idaho View Post
    Answers
    1. Yes, it is true that the 120mm travel "regular" and the 135 LT version of the Fugitive are the same frame: this was designed from the start to be the case. Certain metric shock lengths allow multiple OEM stoke lengths: in the case of the Fugitive, the frame uses a 185mm i2i trunnion shock. The "regular" 120mm Fugitive uses this shock with 50mm of stroke and the LT version of the frame uses the same shock but with 55mm of stroke which generates 135mm of rear travel. Technically, the shock is also capable of being set up with 52.5mm of stroke leading to ~127mm of rear travel, though Knolly won't offer the Fugitive from the factory with this setting.
    2. Yes, we are still working with this date for the first production run and have additional production runs scheduled afterwards in the late summer and early fall.
    Cheers,
    Noel Buckley
    www.knollybikes.com
    Reputation: KRob's Avatar
    Maybe you reported on this somewhere else, but how did it go?
    Isaiah 58:14
    www.stuckinthespokes.com
    Just got back from the Fugitive LT demo. Loved the combo of 4x4 and big wheels, traction plus. I tried a large pre-production with a 60 mm stem which has 15 mm less reach than the production model. I'm 5'9" and it didn't feel too big. Stem is longer than I prefer but it felt very natural to me on familiar trails. It has the long shock DPX2 and smoothed the chunk better than a Endo DPS. Cornering was planted but not sluggish. pedaling was maybe a bit better than an Endo, and I gelled with the steeper STA. Not sure what else to say, it was pretty much what I was expecting and I would be very happy with it. I gotta check for fit on the production frames though.
    Attached Thumbnails Attached Thumbnails Fugitive build ideas & plans-20180415_085520.jpg
    Oct 2011
    In a couple of weeks my "local" dealer should have a Fugitive in L for tests. I will use all my persuasion skills to take the bike for a few days of testing. No idea what build it will come with. For the Euro guys, if you will be around south of Poland we can meet up and have a unofficial test session.
    I will also test the new Ritmo from Ibis to compare and evaluate carbon wheels and etc.
    PM me if you are interested in meeting up for a test.
    Oct 2015
    MRP just released a coil shock with a climb switch. Fully adjustable compression and rebound.Also can get a progressive spring, not that I believe a Knolly would need one. If its simmilar enough to their other shocks, you can get it Avy tuned. This is good news for those that don't want to deal with a Cane Creek.
    T , V , & K Rider
    Fugitive just added to wish list !
    Ultimate Poseur
    Reputation: moff_quigley's Avatar
    I'm in the market for a new ride to replace my Sultan and the Fugitive looks like a winner. I run an XT 1*11 drive train currently and will swap over what I can. I'm guessing I'll need to get an XT boost crankset. What about the front ring? Is there a particular model I should run/consider? My current ring is a One Up oval.
    Reputation: buddiesconfusion's Avatar
    Sweet Travis! You think you’d get the LT or less travel version?
    Those purple delirium’s look amazing! Have two girls have made pink and purple my favorite colors
    Long travel would be my choice for the extra 15mm and to better match a 36 class fork.
    Moff, I'm pretty sure you run a boost chainring flipped to get the chainline right with the 157 rear end.
    Oct 2011
    Mozartt chainguide to match raw/orange
    First post in maybe ~9 years...
    So I recently decided a Fugitive LT will be my next bike after a lengthy search process. I almost pulled the trigger on a Transition Smuggler Carbon, but felt I used the travel a little quickly when I demoed it, and wanted a little more tire clearance. So down the rabbit hole I went, and this is where I'm ending up.
    Frame - Fugitive LT w/ Fox DPX2, medium, in black cherry
    Fork - Fox 36 GRIP2, 44mm offset, 150mm travel to start
    Brakes - Shimano XT 4-piston, 200/180
    Drivetrain - Shimano 1x11, XTR shifter, XT derailleur, Garbaruk 10-46 11s cassette for XD driver, not sure about cranks yet, whatever chain I have lying around, there's probably some sort of Shimano in my spares box.
    Cockpit - RF Turbine 40mm stem, cheap aluminum riser bar, seat from some other bike maybe, lock on grips.
    Dropper - Not sure here. I like idea of the E13 because its dead simple, basically a Gravity Dropper with a remote and internal routing. Maybe a little heavy and clunky, but unlikely to ever fail on me in the middle of a huge trip. Also considering the Fox Transfer, because I can still get industry pricing on Fox stuff, and I'd like to rep the local product (Santa Cruz FTW!).
    Wheels - Here's where things get really interesting and I might be losing my mind. You see, I've loved the Enduro 29er that I'm on. Its a 2014, so really more trailbike than enduro sled, and generally excels in both directions. That said, I've been getting plus curious lately. A friend of mine who's never been a real ripper really impressed me on a recent trip to Idaho. He got on plus tires while living in Austin, TX and riding rocks, and he's really changed as a rider. WAY more confident going downhill.
    I've been historically averse to the idea of plus tires, since I pride myself on my cornering prowess, and I feel that plus tires squirm a little under heavy side loads, such as high speed cornering. The thing that's got me curious is an experience on a plus sized SJ FSR, where I was giggling like a child the whole time, along with some new parts available. Maxxis is making the High Roller II in a 3.0" casing, and there are more and more rims available for plus sized rubber. In particular, I'm considering rims with a 45mm internal width, under the theory that the wider stance could give plus tires the sidewall support needed for higher cornering speeds.
    The argument for this plan is that I had a lot of fun on the one demo I got on a plus bike, and isn't that what this is all about? Child-like giggling as you launch something silly? And I like trying new things, and this would be a new thing for me. I could always change my mind for the price of a wheelset swap...
    The arguments against are all fairly conservative (I generally distrust conservative arguments, as I feel they disregard historical progress and boil down to "we always did it this way", which is logically invalid as an argument). I know how 29er tires ride, and I like them, and I ride fast on them. I build wheels with cheap chinese carbon rims and good hubs, which ultimately are NOT cheap wheelsets, so a mistake here is expensive. I could just use a wider than average 29er rim and a 2.5-2.6" tire, and have kind of a middle ground between the two. A very safe option.
    I'm curious if anyone else has gotten plus tires to meed their cornering needs by using wider rims, and what you guys generally think of my hare-brained scheme. I'm leaning towards doing it, because even if I'm wrong, I could end up with two wheelsets, which might be kind of fun to play around with. And I could just end up giggling maniacally while tractoring over everything in site as fast as I'm willing to go.
    Oct 2011
    One thing to consider when going for the plus size is the fact that, most of the plus tires have not very tough sidewalls. Where I ride Maxxis Exo usually means ripped sidewall sooner rather than later on the rear tire. Mostly during navigating tight trails with sharp rocks. Hence I will stick to 29 and DD in WT.
    And I ride very conservatively after wrecking my elbow the second time.
    Been in contact with Knolly regarding the placement of the Di2 compartment and wanted to share what I found out from them:
    "The battery rests on the rounded channel on the frame guard and is strapped down with zap straps through the two slots on each end. The battery (attached to the guard) then slides into the downtube of the frame through the oval opening just forward of the BB. The cables are run through our standard compression cable guide at the top of the down tube."
    I'll be running an XT Di2 setup and will follow up with pics of the install when the time comes.
    While I'm posting on build details for the Fugitive, thought I'd share the Robert Axle Project axle for the Fugitive:
    https://robertaxleproject.com/shop/t...-x-1-0-thread/
    I contacted Robert Axle directly to make sure this is the right part and received mine in the mail already. It is a BEEFY looking/feeling axle, but the biggest plus for me is the lack of an attached lever to get snagged and loosened on tight trails.
    Reputation: bigdrunk's Avatar
    Thanks for posting this. I will be running Di2 as well.
    Large Raw frame
    2019 Grip2 36 150mm air shaft
    Fox DPS
    We Are One Agent wheels with DT 350
    Tires ???
    35 mm Atlas stem, 35mm clamp
    780 SICX bars
    Deity Knuckleduster grips
    160mm Bikeyoke Revive
    Anvil Forge saddle
    Next R 175mm cranks
    XTR Trail pedals or Kona Wah Wah 2
    28t RF oval ring, flipped
    XT 11 speed shifter and derailleur
    XT 11-42 cassette
    SRAM X1 chain
    Shimano XT brakes, 203mm F, 180mm R
    EDC tool
    Mine is similar....
    Large Raw frame
    Fox DPS Performance Elite (sending to Avalanche in the winter)
    Fox 36 Grip2 Performance Elite with HSC/LSC and 150mm airshaft (will see how the Grip2 damper is, might put in Avalanche cartridge)
    We Are One Agent wheels with Hope Pro4
    Maxxis DHF 2.5WT/Aggressor 2.4WT
    Hope 175mm cranks
    Hope B.B.
    Hope Headset
    Hope 30t Boost chainring flipped
    Shimano XT Di2 shifter/RD
    Shimano 11-46 cassette
    Shimano XT 4 piston brakes
    Bikeyoke Revive 160 or Fox Transfer 150 (waiting on pricing)
    Wolftooth Remote
    Deity Skyline 787 bars, 15mm rise, 9 deg backsweep
    Deity Copperhead 35mm/31.8mm stem (stem, handlebars and spacers will be switched around a lot first month or so)
    DMR Deathgrips
    DMR Vault pedals
    Certainly wont be the lightest/cheapest/burliest, but wont be the heaviest/most expensive/wimpiest either. Goal was high quality, low maintenance and cost effective.
    May 2017
    Mine is going to be like this:
    XL Raw LT frame with DPX2 kashima
    2019 Grip2 36 150mm 44offset
    Renthal Carbon bars
    Renthal Apex stem
    Ergon GE1 grips
    Shimano Saint brakes (203/180)
    BikeYoke Revive 185mm
    Wheels : i9 torch / Sapim CX ray / carbon rims (internal 32-external 38,4 - profile 30mm)
    schwalbe Magic Mary / Dans Dampf 2.35
    Shimano XT 11sp shifter/RD/cassete (due for XTR 12sp )
    Cane Creek eewings crankset - no idea about chainring yet
    WTB saddle
    DMR Vault Bredog signature pedals
    Man, lots of love for the Fox 36 in here! I'm looking at a new fork for the Endo at the moment, kinda weighing up between the Helm and Ribbon, but the consensus here seems almost unanimous for the 36...
    I would’ve gone with the Ribbon or maybe even the Lyrik, but the price I can get on the Fox 36 makes it a no brainer for me, especially as I’d like to get the Avalanche cartridge in there when funds allow. Actually, if Rockshox still made a 150mm Pike 29 fork or the Manitou forks were available in 150mm for 29er, I would likely have gone with one of those two! So, Fox 36 was actually 3rd or 4th choice for me, but I’m sure it will be awesome.
    True, between the 36, Pike/Lyric. Ribbon, Helm, DVO etc we're spoiled for choice with enduro/AM forks I guess. I'm stuck paying retail so I'm thankfully spared the agony of chosing between what I can get deals on and what I really want...
  67. #67
    44mm Ribbon coil here. Love that fork and also love the fact it takes 20 mins to change the travel.
  68. #68
    Reputation: the cracker's Avatar
    Quote Originally Posted by bigdrunk View Post
    Do you have some time on it? Mine is sitting in the garage waiting for the frame. I am stoked to ride it. Haven’t really seen much feedback from people who have ridden one yet.
  69. #69
    Oct 2015
    Yari is the best option if you plan on going with the Avy cartridge. I did this and loved it, just installed the push coil conversion kit and it's the best form I have ever ridden!
  70. #70
    Quote Originally Posted by Cerberus75 View Post
    That was my original plan, but I got the 36 cheaper than I could get a Yari! According to Craig, both chassis work just as well for the Avalanche cartridge. In the meantime, I’ll ride the Grip2 and see how I like it.
  71. #71
    Oct 2015
    Wow, I got the Yari for 400.00 new. But the Grip is better than Motion control.
  72. #72
    Dec 2008
    The ribbon sounds like a great fork, but I am sure enjoying my 36 with a luft kappe.
  73. #73
    Reputation: islander's Avatar
    Quote Originally Posted by vikb View Post
    It's now $197 for the CC IL service at SW. So, that's like $2/h given this is a 100h service interval? Seems like their rates have jumped quite a bit more than regular inflation rates..
  74. #74
    Quote Originally Posted by islander View Post
    Just had a CCBDA/CS serviced at SW for $153 CDN. My DBA [IL] last fall was ~$149 CDN.
    Safe riding,
    Vik
    www.vikapproved.com
  75. #75
    I see most people are planning on a fork with the reduced offset 44mm. Does everyone feel its necessary? I have a new mrp ribbon coil in 51mm offset ready to rumble. I am curious if i should start looking at reduced offset options or not. Currently leaning toward running what i have and see how it rides.
  76. #76
    Quote Originally Posted by the cracker View Post
    It's not necessary. I would just run with the fork you have.
    Safe riding,
    Vik
    www.vikapproved.com
  77. #77
    Great ideas for builds and thanks for the info on mine coming up.. XL blue fug LT with DPX2 coil with 600lb spring.
    question: Has anyone tried and have Velocity Blunt I35 29er rims? Looking to lace some good alum ALL BLACK rims with a wide profile to Hadley hubs. Would love to plunk down for We Are One wheelset but over budget then... hummm...
    thanks!
  78. #78
    question: Has anyone tried and have Velocity Blunt I35 29er rims? Looking to lace some good alum ALL BLACK rims with a wide profile to Hadley hubs. \
    thanks!
    I ran the Blunts on my Turner Burner and it always seemed like the alloy used was on the soft side. I say this because I managed to dent 3 separate rims quite badly. On a positive note, the rims always held air, even after getting damaged and I was able to make it back to the trailhead each time. I bent two of the rims back into shape, the third was bent so badly that I didn’t want to risk riding on it after. Now, I may have just had bad luck with the Blunts and/or happened to make dumb decisions while riding them, but that was my experience.
  79. #79
    thanks buddy! Interesting. I want Peace of mind in the wheelset like I have on my Chilly... but different machine I know. I'm 255 so need some security on the way I ride too... Do you know any other bombproof rim/wheels out there? Still on the fence on if I just should max out Credit Card on the We Are One wheels.
  80. #80
    I am a similar weight as you. I went with raceface arc 30 rims. Had great experience with them on my trance. A buddy uses them as well and hes 300lbs. He turns like no bodies business and rides hard. I am also a fan of the wtb asym rim. They have eyelets and are very durable, little heavy though. I am keen on the new KOM rims from wtb now that they are releasing a wider version. I just looked into the We Are One stuff because i was unfamiliar, looks super nice and i love their deal. If i was in the market with some cash, id do that.
  81. #81
    Perpetual Hack
    Reputation: mykel's Avatar
    Alex Volar 3.0 look like good alternative to the Blunts.
    They also come in micro sizes if you still have a 26er in the stable.
    http://www.alexrims.com/products/volar-3-0/
    Hatched in '64
    A Dirtbag since '69
    A Knomer since '07
    Knolly Fugitive
    Knolly Podium
    Knolly Endorphin
    Knolly Delirium
  82. #82
    Alex Volar 3.0 sounds good.. I'll check them out also! thanks! I'm looking at the DT Swiss E532 also.. good rim it looks like and keeps cost down.
    Ok guys.. serious.. going with the Fox 36 Factory fork.. should I get orange or matte black?? I have the blue fug coming with the coil dhx2..orange ti coil. Too much ????
  83. #83
    Mar 2014
    Orange Fox for sure .
  84. #84
    ahhh thanks.. but you know how bright that will be.... just trying to picture it somewhat. Don't know if I want some kind of offset tone or a nice clown build.
  85. #85
    Mar 2014
    It doesn’t look bad on a Yeti. Colors aren’t that different .
  86. #86
    That Gulf blue is just begging for an orange fork IMO, I haven't seen one but to me it always looks not-quite-finished with a plain black fork.
    I've just picked up a used 36 with orange lowers and black stanchions for my red Endo, going to be interesting but the price was right so colour matching be damned! I'm sure someone with black lowers would be willing to swap if it looks as dreadful as I suspect....
  87. #87
    Nov 2008
    Just do it!
  88. #88
    Dec 2005
    Lot‘s of love for the raw which would have been my first choice also but is sold out in L and XL from my source... wife wanted the classy Le Mans blue so I went with the Black Cherry. Will pair that with greyish and bling polished parts (e.g will try the new Formula brakes after happy years on the previous generation of Shimanos).
    Ordered the wives Fugitive LT with the DPX2 factory and mine with the RS Super Deluxe - will try them both on my bike and then decide which one to keep ... I’m a ba$tard, I know ...
  89. #89
    Well prob going orange then! Yeah saw the Yeti with that fork and shock and not that bad. Funny I'm going from an all Black Knolly to this Gulf blue...can't wait to see it in person. love it.
    Has anyone been on the DPX2 by the way? I'm coming from a CCDB coil... I just learned CC is offered now on the KNOLLY site with frame or package!
    David R gotta put a pic up when you can of the red / orange endo!
  90. #90
    Jul 2018
    I ordered 2 Fugitives and I was hoping for orange Fox forks but even with the right connection I couldn't have it in the build kits.
    I would swap if the red Endo with orange fork looks silly.
  91. #91
    Thanks, but I don't think 27.5 and 29er lowers are interchangeable? And I'm in New Zealand too, might be easier to find someone local to me.
  92. #92
    Jul 2018
    I use to live in NZ, and my in-laws are still there.
    Maybe I can cut the lowers and extend them.
  93. #93
    Mar 2014
    Im going from the black Warden Carbon to the Blue Fug LT .
  94. #94
    Quote Originally Posted by M4rc0 View Post
    Can of spraypaint and some new decals might be easier...
    Looking forward to seeing some of these bikes built up and out in the wild.
  95. #95
    This was waiting for me when i got home. What a nice gesture. Solid move Knolly. I am very much looking forward to hitting the trail on the Fugitive soon. Thank you.
  96. #96
    Nice.
    Safe riding,
    Vik
    www.vikapproved.com
  97. #97
    My shop just called and let me know that they’ve got a gift from Knolly -and not my frame- waiting. I will definitely put it to use!
  98. #98
    Dec 2008
    Classy move Knolly! I am sure the fugitive will be worth the wait, as frustrating as it is.
  99. #99
    I got the same thing in my mail box. It's a really nice surprise.
    2013 Kona Process
  100. #100
    Reputation: Slurry's Avatar
    Dec 2008
    I wish my flask was full when it arrived. Oh well, still a nice gesture.
  101. #101
    Hisforever
    Reputation: SHAHEEB's Avatar
    Dec 2004
    Does this mean keep waiting?
    still very nice indeed
    PipedreamMoxie
    calling
    offering
    Yz 250x braap
  102. #102
    Very nice gesture...would it be wrong to ask for a Gulf Blue or Raw fug flask?
    seriously kidding...or am I????
    I love mine. Mahalo !
  103. #103
  104. #104
    Mar 2014
    So this is what Noel is refuting to.
  105. #105
    I think i would give the coil a whirl if available. I have never ridden a cane creek shock.
  106. #106
    Re: Cane Creek shocks: they'll have reservoir trunnion mount shocks available soon. I'm currently testing a DBAir-CS, but there really isn't anything to expect that's different: it's a dialed shock that really just has a different upper mounting option. My understanding is that the DBA-CS and the DBC-CS will be available in trunnion mount and would be suitable for the Fugitive LT with more aggressive builds. I'll have some more information on our social media regarding this bike over the next week.
    RE: Bigdrunk: if you want DBA-CS or DBC-CS, please let your reseller or us know directly!
    RE: next project comment (CHOMAG19 - I'm guessing this is what you're referring to - my comment in the other thread?): that will be something totally unrelated to the Fugitives and we'll leave it there until Crankworx in two weeks
    Noel Buckley
    www.knollybikes.com
  107. #107
    Dec 2008
    Some shots of the Fugitive up on Pinkbike. Second from the top.
    It's nice to know that they exist in the wild, even if we don't have ours yet.
  108. #108
    May 2017
    I am curious how tall is Martin Ziestman....
    I am waiting my XL...
  109. #109
    He makes the XL Fugitive look small!!
  110. #110
    Is it just me, or do comments there on pinkbike seem mostly about how the bikes look rather than how they might perform?
  111. #111
    Quote Originally Posted by attaboy View Post
    Since all you have are a few pictures of the bikes it's not crazy that people are talking about how they look. It's not an article discussing the performance of each bike relative to the others.
    Safe riding,
    Vik
    www.vikapproved.com
  112. #112
    That’s true. I’m just so biased the other way. I could care less what it looks like.
  113. #113
    Dec 2008
    The Pinkbike comments section is a hallmark of the shortcomings of public discussion on the internet. Only read them to try and have a laugh.
  114. #114
    Quote Originally Posted by Slurry View Post
    I read them often for the same reason. All for lols.
  115. #115
    Mar 2014
    A lot of people hate on Lnolly because of the way the fourby4 linkage looks. Unfortunately most people go by the way something looks other than the way it performs .
  116. #116
    The local bike shop guy described my Endo as looking very "agricultural", which I said I'd take as a compliment. The new linkage and seat tube on the Fugitive is a good improvement, not that I think the old look was ugly, the Fug is probably one of the best looking bikes in that article IM(totally non biased)O.
  117. #117
    Got my hands on a pre production Fugitive in size L. Very different build from what my LT will be, and with the shorter pre production geometry, but I’m still pumped to take it out for a ride tomorrow! Won’t be anything crazy as I’ve been off the dirt for a couple weeks due to a back tweak and work, but it’ll be fun I’m sure.
  118. #118
    Ride On
    Meh. I actually prefer the more industrial look Knolly’s have had. I think the new linkages and design are being overly sanitized. Just like the car industry Honda civics for everyone... boring.
  119. #119
    So I got in a decent 12 mile ride on the Fugitive. The trails were mostly technical singletrack, with the final descent being the only one that really allowed me to open it up speed wise.
    In terms of setup, I tend to set my front and rear suspension by feel as opposed to some pre determined sag, which means it often takes me a few rides of fiddling and tweaking to get things right. In this case it meant that the rear suspension on the Fugitive was undoubtedly set up a bit more firm than necessary.
    Despite the above mentioned firm setup, I was quite happy with how active the suspension remained while braking. And, while I was not on the fastest travel gobbling trails by any stretch, the 120mm of travel out back never felt overwhelmed.
    As far as climbing, the firm setup definitely helped to reduce any pedal bob, but I was more than happy to keep the shock in it's "trail" setting for the bits of smooth fire road that I encountered. I purposefully sought out some steep and technical bits of climbing and was impressed with how the Fugitive seemed to dig in and find traction out back.
    In terms of fit, this was a pre-production mode with 15mm shorter reach (I believe, maybe only 10mm shorter), but it confirmed that I'll be very happy with the Large and will likely settle on a 35mm or 40mm stem. Also worth noting that while I went with a Fox Transfer based on price, I definitely could have fit a 180mm travel dropper on the frame (I'll be just fine with 150mm).
    Handling was quite nice. It's always weird for me to hop on a new bike, and I did overshoot one tricky corner and find myself just a bit out of sync in timing on a couple different moves, but the bike felt very easy to get along with and I'd characterize the handling as intuitive.
    Overall, I'm even more excited to get my Fugitive LT and ride it into the ground.
  120. #120
    here ya go geraldooka..
    Still have this beast. Had black one too. War n back... she shined pavin the way for my chilly.
  121. #121
    Quote Originally Posted by Ntinos P View Post
    I am curious how tall is Martin Ziestman....cm
    Ask and ye shall receive.
    https://www.instagram.com/p/BmVwcOpA...by=fietsman_sa
    6'5" or 1.94cm.
  122. #122
    So who plans on going with one of the Cane Creek offerings?
  123. #123
    Mar 2014
    What offering? I don't think they are offering a shock yet for this bike.
  124. #124
    They can make it happen if you call. Check noel’s Response above
  125. #125
    May 2017
    6'5" or 1.94cm.
    Looks taller, maybe is the angle of the photo
    In any case this is a pre production fugitive (a little smaller)
  126. #126
    My We are One Agent DT350 wheels are here, now I just need the frame.
  127. #127
    Mar 2014
    Any word on ship date for frames?
  128. #128
    Will they fit a gravel bike?
    Safe riding,
    Vik
    www.vikapproved.com
  129. #129
    Dec 2008
    Anyone have experience on Cane Creek DB Air vs Coil in conjunction with Knolly's suspension design? I'm trying to decide between the two for my Fugitive.
  130. #130
    Ride On
    Lots of us do. I run both and they both function great with my Endo. I imagine you would be happy with either. Did you have any specific questions?
  131. #131
    If it's 157 Super Boost Trail +.
  132. #132
    FYI, latest update from my shop via Knolly is that there’s been another small delay and they’re looking at shipping the first Fugitives out in early September. I am anxiously awaiting my frame and hoping to get my new ride in the dirt mid September.
  133. #133
    Oh Boy...
  134. #134
    Dec 2008
    Quote Originally Posted by geraldooka View Post
    I was just curious if one played better than the other with this suspension design. I like the coil for low maintenance, but I don't know what spring rate I would need to order for my body weight. I'm sure I could figure that out, but with Air springs you don't have to worry about it. I like to be able to do all my own service, but it looks like CC wants you to send your shock in for any significant service of the air spring.
  135. #135
    Marcus
    Aug 2018
    Hi, are you getting a large? i think i read that you're 5' 9.' I'm 5' 10.5 with a 30 inch inseam, and am torn between medium and large. Interested in your thoughts as you've demoed one.
  136. #136
    AFAIK the service intervals for CC shocks are the same for air and coil, and either way it's the damper they don't want you pulling apart at home so they've both still gotta go in. Not sure on the difference in cost, haven't sent my CoilIL in yet.
  137. #137
    Ride On
    Better is hard to quantify. I’m not trying to be a jerk but these things are pretty subjective. Knolly’s have a fairly progressive leverage curve so theoretically they’d work awesome with coil because coil is not progressive. Meaning the suspension design would take care of the end stroke bottom out by being more difficult to compress the spring the further into travel it gets. With that taken care of you could look at other benefits of coil like lack of stiction, when I first mounted the coil I was shocked at how little effort was required to initiate travel compared to air. The ride reflects this with excellent small bump performance and more importantly improved traction. As David mentioned service at least according to the manufacturers has been changed over the past couple of years to be the same regardless of spring type. Besides weight I see no real downside to using coil. Some folks have suggested that they’re able to get a more playful or poppy feeling out of an air shock but I’ve been able to achieve that same feeling using the coil shock too so…
    Having said all that the in-line airshock is also great shock and I enjoy riding the bike with that as well. And there is something to be said for a lighter bike.
  138. #138
    Mar 2014
    Quote Originally Posted by MarcusFarley View Post
    Med for sure.
  139. #139
    May 2017
    They are large and medium, or XL & L?
    Sent from my Nexus 6P using Tapatalk
  140. #140
    Marcus
    Aug 2018
    Med for sure.
    Didn't Travis at 5'9" demo and is getting a large?
  141. #141
    I'm 5'9 and absolutely getting large since I'm not stuck in 2014. I have my Pipedream Moxie that matches the large Fugitive pretty closely and love it's fit. I also cut down the seat tube on a large Endorphin and it was a huge improvement over the medium, but still a tad short compared to the Moxie, so I'm certain on the sizing for me. I feel that medium bikes should be 460-475mm in reach, but watch the stack because this effects reach. The lower the stack, the shorter the reach. My Moxie has a higher stack then the Fugitive but has 7mm less reach, but me guesstimate has the about the same.
  142. #142
    Ride On
    How does lower stack shorten reach? Stack is independent of reach. Lowering it will lengthen butt to hand or ETT and raising it will have the opposite effect.
    Hardtails being that they pivot on the rear wheel will always get longer in reach during a ride and never shorter whereas full suspension will generally remain similar. Something to bear in mind when comparing a hardtail to a full sus.
    I agree that sizing up on a Knolly is something to seriously consider especially given their ummm unique ETT measurement method...
  143. #143
    Longer ht would increase the front-centre over a bike with the same reach and HA and a short head tube, wouldn't it? And if you run a lot of spacers under your stem and replace that with higher stack then you will gain a tiny amount of reach for the same bat height.
  144. #144
    Marcus
    Aug 2018
    Am thinking large now.
  145. #145
    Marcus
    Aug 2018
    Any pics of full builds in the purple colour?
  146. #146
    Seen at the BCBR. Sorry not the best shot to show off the bike. The colour is pretty rad though. Looks great in the sun.
    Safe riding,
    Vik
    www.vikapproved.com
  147. #147
    A bike with shorter stack needs more spacers and this reduces the TT, FC, and your felt reach.
    We have a Black Cherry preproduction in the shop and it is pretty dark.
  148. #148
    Yup. You can't evaluate Reach without factoring in Stack. My 29er has the same Reach as my Endo, but higher Stack. The 29er is a bigger bike.
    Safe riding,
    Vik
    www.vikapproved.com
  149. #149
    So it's not that the reach changes with stack, but the amount of spacers you need to run because of the stack height that reduces the effective reach. According to this handy calculator with a 65* HA every 10mm of spacers you add reduces the effective reach by a 4.2mm, not drastic but if you've gotta run 30mm+ of spacers it's going to add up.
    Easy solution is to sort your bar height, then ditch the spacers in favour of bars with the appropriate rise.
  150. #150
    Reach is calculated based on the Stack height so Reach definitely changes as the Stack changes all other things being equal.
    Safe riding,
    Vik
    www.vikapproved.com
  151. #151
    Ride On
    I understand the interpretation of stack and reach discussed here and agree it needs to be taken into consideration when purchasing a new bike to ensure you’ll be able to get the cockpit where you want it.
    I was speaking from a design perspective. I can lower stack independent of reach (designing a hardtail now). Similarly I can do the same with reach either lengthen or shorten whilst maintaining the same stack.
  152. #152
    Spill the details.
    Safe riding,
    Vik
    www.vikapproved.com
  153. #153
    Jul 2018
    Medium in Raw and Large in LeMans Blue
  154. #154
    May 2017
    Nice
  155. #155
    Mar 2014
    When are these bad boys getting shipped ? C’mon man!
  156. #156
    Marcus
    Aug 2018
    i think i like the gulf colours most.
  157. #157
    Mar 2014
    Knolly says frames aren't shipping until next month now.
  158. #158
    Sssslllllooooowwwwwww boat apparently.
  159. #159
    Yup. They told me there was another few week delay and now shipping is estimated to be in early September. I’m hoping to have my frame by mid September. We’ll see.
  160. #160
    That's the latest. So far 2018 has been the year of the hardtail for me. I'm tired of being "too cool" for suspension, and am ready to conform again.
    Sent from my SM-G935S using Tapatalk
  161. #161
    Hi, Travis. Just wondering if you can get a 36 150 travel with Grip2? That would be my ideal fork as well, but from what I can tell, Grip2 is only in 160 and 170. Thanks!
  162. #162
    May 2017
    Yes you can get the grip2 with 150mm.
    I think fox gives (to knolly) the grip2 already adjusted at 150.
    If you get a 160 version (not direct from. Knolly) you can change the air shaft only, so to go to 150, cost something around 50 usd
  163. #163
    My understanding is that the travel can be reduced. Haven't done it yet but should get around to it soon.
  164. #164
    May 2017
    Can be reduced by changing the air shaft:
    https://www.worldwidecyclery.com/pro...y-150mm-travel
  165. #165
    Mar 2014
    Most guys if been talking with are going to run 160mm fork.
  166. #166
    Unit 91
    Reputation: TheProphet's Avatar
    May 2005
    What offset are you guys choosing?
    Bikes
  167. #167
    May 2017
    44 here.
    Not sure about 150 or 160 though
  168. #168
    44. I replaced a 51mm offset 34 with a 42mm Lyrik on my HT and the front end does feel more planted and cornering is a bit better. Reduced offset, better fork, 10mm less travel, or a combination?? The new Lyrik is very nice, and I'm looking forward to comparing it to the Grip2. Life is good.
  169. #169
    May 2017
    Hi Travis
    Do you have any idea when you will have your Fugitive ?
    Any inside info maybe ?
  170. #170
    I put my deposit down on a Raw large LT from the first batch. Just heard from Knolly that with how the first delivery is looking, my color choices are now Gulf Blue, Gulf Blue or Gulf Blue, in that order.
    Did anybody order a large Raw or Black Cherry and had a change or heart and want a Gulf Blue? If so I would love to swap.
    Color usually isn’t that big of a deal for me but the Gulf Blue would be my 4th choice out of the 3 colors offered.
    Just thought I would throw it out there....
  171. #171
    Mar 2014
    When did you put your deposit down?If it was early then I dont see why you wouldn't be getting a RAW?.
  172. #172
    Mar 2014
    Hi Travis
    Mid September
  173. #173
    A am hoping that since I ordered just a frame it may be earlier. I have no updates though.
  174. #174
    May 2017
  175. #175
    My deposit was made pretty late in the game (early July) so I can’t complain. The black cherry has really grown on me.
    Also trying to decide DB Air vs DPX2 but that is another issue.
  176. #176
    Here’s an interesting article on PB with Noel in it discussing 157mm rear axle spacing. I wonder how the fugitive is with heel clearance? Noel and Cavan are big fellas like myself and I wonder if they have big size 12+ flippers and are having any issues with her strikes on the frame? The comments below are joke as a well.
  177. #177
    Quote Originally Posted by buddiesconfusion View Post
    Current model rear spacing (BLUE) compared to the Fugitive shows how the rear stays are only slightly wider and that we can continue to run a 73mm wide threaded BB shell.
    https://www.knollybikes.com/single-p...widens-the-gap
    FRAME CLEARANCE: We have re-designed the entire rear-end area to keep things as tight as possible. The 157TRAIL spacing increases rear axle width by 15mm (7.5mm per side), and yet heel clearance of our new designs has only moved outward by 1.5mm per side!
    Safe riding,
    Vik
    www.vikapproved.com
  178. #178
    Dr. Pepper drinker
    Reputation: catch22's Avatar
    I've got size 13s and had zero issues with heel rub on the frame with the Fugitives I've ridden. I wondered about it as well but after riding one it wouldn't concern me.
    Sipping the Knolly Whisquillappa
  179. #179
    Oct 2015
    Ok my order has officially been placed. Large, raw LT model coming my way in the 2nd shipment. Being told October right now. Here's the build I have lined up:
    i9 system wheels with race face ARC 30 rims
    Kenda Hellkat 2.4 front
    Schwalbe Rock Razor 2.35 rear
    Cane Creek Helm coil fork 140 or 150
    Cane Creek DB coil CS w/550 spring
    9point8 Fall line post 150 or 175
    RaceFace SixC 175 cranks
    Garbaruk 30T oval ring
    BBinfinite ceramic BB
    OneUp aluminum flat pedals, silver
    Chormag BZA 35 carbon bars 800/15
    ANVL Swage stem, black
    SRAM Eagle X01 cassette, shifter, derailleur
    KA engineering billet pulleys
    Bike Yoke Shifty
    Cane Creek headset
    up in the air on brakes. Currently running Magura Trail Carbon but I'm considering going to hope V4/E4's
  180. #180
    Mar 2014
    Quote Originally Posted by vegasR6 View Post
    Bike Yoke Shifty
    Cane Creek headset
    At this rate the 1st shipment will be October.
  181. #181
    May 2017
    Another delay???
  182. #182
    The Fox Float X2 is now an option for the LT and I have one coming, soon....
  183. #183
    May 2017
    I used to have the X2 on my warden C, and changed it with the DHX2 (both with cs)
    I am waiting my fugitive with DHX2 too. (Hope soon too :-) )
  184. #184
    Thanks for the heads up Travis! I'll contact knolly soon and change the order.. I never ran the X2 or DHX2 on my bikes.. I have the fugitive coming with a dpx2.. but want the x2. Don't know if you can go wrong with either though??
  185. #185
    Dec 2008
    How would you compare the two shocks? I have the X2 on my Warden and love it. Definitely better than the ccdb.
  186. #186
    Contact us for sure regarding this change.
    We are starting to ship Fugitives next week and it's going to be crazy hectic this month getting these bikes out the door. If you want to do a shock change, I would suggest contacting your reseller or us directly on Monday before we get slammed!
    Cheers and thank you!
    Noel Buckley
    www.knollybikes.com
  187. #187
    we are starting to ship fugitives next week and it's going to be crazy hectic this month getting these bikes out the door.
    boom
  188. #188
    Sorry all - I have been off of MTBR for a bit.
    Regarding heal clearance: remember our current bikes are 142 x 12 so they are narrower than almost all current 148 Boost bikes. As mentioned above by vikb, we have completely redesigned the chainstay assembly and dropouts to ensure that we maintain really good heal clearance. What people don't realize is that the back of the foot ends about 3 - 4" in front of the rear axle, so the heal actually never comes close to the rear axle when you're riding. It does - however - come close to the chainstay about 4" in front of the rear axle. This is the point of contact that most people have with the chainstay.
    When designing the Fugitive and when we decided to go from 142 to 157, maintaining heal clearance was one of the highest design priorities. We have a bunch of people at the office with size 11 and 12 feet and this was a major concern for them. We were able to completely redesign the chainstay / seat stay pivot assembly and also redesign the dropout to add less than 1.5mm in width per side (people assume that it would reduce heal clearance by 7.5mm per side but that's not true). So, in fact we've stayed more narrow than if we just took the existing assembly and moved it outboard 3mm per side (i.e. moved from 142 to 148 Boost).
    The other thing we did is maintain the ability to run narrow cranksets. There was a recent article in Pinkbike recently about 157mm rear ends (https://www.pinkbike.com/news/burnin...tandard.html): many of the authors state that moving from 148 Boost to 157 will mean the requirement of wider Q factors for cranksets. Well, that's funny because the Fugitive DOES NOT require a wider Q factor so really this is a design question. In fact during the BC Bike race, I used a 134mm spindle Next SL crankset which has a Q factor sub 170mm (around 168mm) and it was awesome for a pedaling centric race. The Fugitive can even run a front derailleur for those who want them (and believe it or not, those customers exist even if they're just a few % points of the overall customer base).
    Cheers,
    Noel Buckley
    www.knollybikes.com
  189. #189
    Lots of shock choices now but even more glad the frames are shipping soon
  190. #190
    We are starting to ship Fugitives next week...
    Nice. This forum is going to get a lot more exciting over the fall!
    Safe riding,
    Vik
    www.vikapproved.com
  191. #191
    I had a nightmare last night. My Fugitive showed up and it was a moped.
  192. #192
    Sounds like those getting the raw frames will get yours soon. Those of us waiting for a painted frame are going to have to continue to wait.
  193. #193
    Dec 2005
    Actually heard the painted frames will ship this week!
  194. #194
    Battery or petrol powered?
  195. #195
    Not what I was told by Knolly yesterday. Only the raw frames are ready, the others need to be painted.
    Quote Originally Posted by Zuzi View Post
  196. #196
    Oct 2015
    Think they’d sell me a raw without the orange? Saves time in paint
  197. #197
    I'd take one as well. Last thing I want on a raw frame is paint right in the line of fire from the front wheel.
    But, doing anything custom even less work takes a lot more time/hassle in a manufacturing situation so I'd say your chances are approximately 0%.
    Best we can hope for is that Knolly does a future production run of 100% raw Fugs.
    Safe riding,
    Vik
    www.vikapproved.com
  198. #198
    I have heard that the painted frames aren't far behind.
  199. #199
    Of course if you bought a raw + orange frame and spent an hour and about 2 beers with a dremel tool it could become a 100% raw frame.
    Safe riding,
    Vik
    www.vikapproved.com
  200. #200
    Talked with Santa Knolly last night and changed my shock from the dpx2 to the Fox X2. Had a nice chat as always with them also.
    Yeah some peeps getting theirs at the end of the week..raw. Like you guys said paint not far behind.
    I don't have all my bits yet anyways but all good.. will be just in time.
    XL Gulf BLue Fug
    Fox 36 Factory Grip 2 160mm (color..hummm)
    Spank 350 vibracore wheels (blk) on DT swiss 350s
    XT drivetrain..
    XTR shifter
    Stem?????? don't know what size yet.
    32 XT oval ring
    BikeYoke dropper 185mm
    Ergon saddle
    XT 4 piston brakes 203 rotor f 180 rotor r
    Maxxis DHF or Bontrager XR4 tires (heard they are great)
    RaceFace Atlas 800mm with bar low rise.. .bronze (something monkey they call it)
Page 1 of 6 12345 ... LastLast
  1. Replies: 517
    Last Post: 09-12-2018, 01:08 AM
  2. pump track ideas or plans?
    By azimiut in forum Trail Building and Advocacy
    Last Post: 04-01-2017, 06:54 AM
  3. Replies: 2
    Last Post: 04-17-2015, 11:45 PM
  4. Does anyone have plans to a decent set of ski bike plans?
    By bonzi13 in forum General Discussion
    Last Post: 01-19-2012, 12:59 AM
  5. 40+ acres for trails, Need Obstacle Plans/Ideas
    By supraturbwoah in forum General Discussion
    Last Post: 07-19-2011, 10:07 PM
Members who have read this thread: 201
