Upgrading an old XCR Pro- Mtbr.com
    Oct 2019
    There were about 5 forums here I could have posted this, but I'm hoping I can get more detailed info from those who love Jamis
    I have a 2007 XRC Pro, 98% XTR. I've worn out my chainrings and they are not available new.
    This is a 26" wheel, 13" frame bike. I built it because after the specs were released on it, Jamis decided the 13" market was too small for such an expensive bike, so I had to change my order to frame-only. I had to order a different front derailleur due to the frame geometry (still XTR but not a normal pull, I can find the specs buried in my drawer or take a pic). Also I worked at a shop at the time, so it was EP'd and I hope that explains why it's so tough for me to easily replace such a light bike that I got at a great deal. They are hard to find out there used, I do keep looking.
    My fork is a few years old and the shock was rebuilt last winter.
    I have a friend with some older group sets and we thought we could change it over to a 2x
    We went through his parts last week, and all of his cranks are 175, and I need 170.
    My options seem to be: a 3 chainring set from Wickwerks, along with new cassette, chain and recabling the bike. Probably the simplest repair.
    Then I found 2x conversion sets from Wickwerks. I could go to a 10 or 11 speed then (I'd need a new free hub for my wheel for the 11 speed)
    https://wickwerks.com/products/mountain-bike-3824/
    At this point though, I've seen conflicting info on needing to change the shifters to a 2x10 or 11 set. And derailleurs too. Some say yes, others say you can limit the travel on the current ones.
    I also found an M9000 double at the right length for under $200, but I'd still need to know about the shifters. And the bottom bracket isn't included, so I'd need to make sure mine is compatible - which I think it is....
    Most of my friends parts seem to be in the M9000 and M9020 series. He did have some random 980, 985 and 986 stuff, but only a couple of pieces, I'm not even sure there were full shifter sets for those. But I think there are for the M9xx's
    Would love any thoughts - winter is coming and I need a disc brake bike to survive Thanks all!!
    Mar 2019
    Why not do a 1 x conversion. toss the front derailleur, toss the left shifter. Install a 10spd rear derailleur and shifter, put a wolf tooth chain ring on and a shimano 11 -42 cassette.
    Oct 2019
    Ah the one thing I left out! I don't want a 1x. I ride on varied enough terrain that I do use all 3 rings. I think I'd be struggling with only 10 speeds.
    Mar 2019
    Check out wolftooths site. They have alot of good info on the conversions. Most of the gears of a 3 x are actually redundant if you choose the right gearing combination. I converted my 3 x 9 over to a 1 x 10 and feel that it has improved drastically.
  1. SR Suntour XCR 24" coil fork - lighter springs or upgrade to XCR air?
    By zuuds in forum Families and Riding with Kids
    Last Post: 07-07-2018, 08:12 PM
  2. Upgrading a Suntour XCR fork possibly to a Rockshox?
    By Luclin999 in forum Shocks and Suspension
    Last Post: 08-06-2012, 08:47 PM
  3. Upgrading 2007 Marzocchi MX Pro TAS/ETA to Manitou Minute Pro ?
    By pirati in forum Shocks and Suspension
    Last Post: 05-25-2012, 10:07 AM
  4. Paid Spam - BWW wheelset, Pure XCR Rims with Pure XCR Hubs
    By CharlieCafe in forum Wheels and Tires
    Last Post: 01-17-2011, 03:12 PM
  5. Why does BWW recommend a Pure XCR FH with it's XCR Wheelset?
    By eddieruko in forum Wheels and Tires
    Last Post: 01-11-2011, 10:15 AM
