Komodo Tire width- Mtbr.com
Results 1 to 11 of 11
    Komodo Tire width
    Hey guys tried puttin this on the allmountain forum and got told that i might get a better response here so here it goes... how wide of a tire does an 07 komodo take in the rear?
    Keep on Ridin
    Reputation: luckynumber9's Avatar
    they came with 2.35 wide tire out back
    oh and they came with maxis hans ventures
    I've squeezed a 2.5" Nevegal in there, but it's tight. You need a really stiff wheel to keep from rubbing. I routinely run a 2.35" Nevegal on mine and it still rubs now and then I guess, but I never feel it or hear it. I just see the result.
    sweet thanks guys
    Keep on Ridin
    dude
    Reputation: joeyjoedotorg's Avatar
    Yeah, 2.35 Nevegal is about as wide as I'd go.
    will a maxis 2.35 minnion work do you think?
    Keep on Ridin
    dude
    I've heard that the minions and older maxxis tires run a bit small. I'd give it a shot.
    Quote Originally Posted by Singletrakin Mike
    yeah it'll work NP, maxxis do fit a bit smaller, i run a 2.35 Nevegal and like previous poster said it fits tight, keep your wheel trued and tensioned and it'll be just fine, the maxxis being slightly smaller it should be a great fit for the komodo.
    Reputation: Moodrid's Avatar
    I run a 2.3 Continental Gravity on mine and still have a lot of room
    2016 Intense spider/Recluse build
    2015 Jamis komodo
    10 Banshee Viento
    dude
    Quote Originally Posted by AKRida
    Also, keep your bearings/cones & quick releases as tight as possible to keep flex to a minimum - I would fairly regularly buzz the chainstays if I was cornering hard.
