Jamis Dakar XCT 3
Printable View
  • 02-10-2010
    allie1115
    Jamis Dakar XCT 3
    Is there anyone familiar with the XCT 3? I am a little concerned about the weight as I am a 5'4, 135 lb., female rider. I'm really hoping that this is the bike for me but here's my question:
    If you have a moment to take a look at the specs, can you tell me please where you think weight can be shaved?? It's listed at about 30.2 lbs.
    Thanks so much for any advice you can give me!!
    Frame Kinesium alloy main triangle, STW 7005 seat & chainstays,
    130mm travel mp3 linkage design, cartridge bearingpivots,
    Fox FLOAT R shock with 10mm hardware,
    replaceable derailleur hanger
    Fork Fox 32 Talas R, air spring, external rebound adjustor,
    15mm thru-axle, 100 - 120 - 140mm adjustable travel
    Headset Ritchey Pro Logic Press fit, semi-integrated
    with 20mm shim stack, 1 1/8
    Wheels Mavic XM317 eyeletted disc rims, 32H, Shimano XT front disc
    hub w/ 15mm thru-axle, XT rear disc hub,
    WTB 14g stainless steel spokes
    Tires Kenda Nevegal, 26 x 2.35, Stick-E compound
    Derailleurs Shimano Deore XT Shadow rear,
    Deore XT 34.9mm top pull front
    Shiftlevers Shimano Deore XT Rapidfire Plus-SL, 27-speed
    Chain Sram PowerChain 971 with Gold Power-Link
    Cassette Sram PowerGlide 950 , 9-speed, 11-34
    Crankset FSA V-Drive MegaExo, 44/32/22,
    170mm (13-15), 175mm (17-21)
    BB Set FSA MegaExo integrated
    Pedals Crank Brothers Acid clipless
    Brakeset Hayes Stroker Trail, hydraulic disc brakes
    with V7 front & V6 rear rotors
    Handlebar Ritchey Mountain Pro Rizer, 31.8mm x 20mm x 660mm wide
    Stem Ritchey Pro 4-Axis, 31.8 O˚ x 6˚ rise x 90mm(13-15,
    100mm (17-19, 120mm)
    Grips WTB MotoTec clamp-on, DNA compound
    Seat Post Ritchey Pro 2B OS, 31.6 x 350mm,
    with alloy clamp & cromo seatpin
    Saddle WTB Rocket V Comp with SL cover
    Weight 30.20 lbs
  • 02-10-2010
    insanitylevel9
    the wheels i had mavic 317 on another bike and they weighted like 6 or 7 pound each.
  • 02-10-2010
    sebastian21
    the weight to loose on the bike is everything that rotates with the biike such as wheels, cranks, chain, cassette,rotors,tires.... Dont focus on parts such as handlebar, seatposts,seats...
    You will noticed a big difference by replacing those heavy wheels, for your weight you could go easily with stans wheel and also use tires with stans. You will save a couple of pounds just by switching that...
    Good luck.
  • 02-27-2010
    ernestdamaso
    I also have the same bike and replaced some parts.
    I replaced my crank set with a shimano xt, also replaced the wheel set with a shimano xt wheel set with light 2.0 tubeless tires. Now the weight of my Jamis xct3 bike is 27.8 pounds...... :-)
  • 03-03-2010
    allie1115
    Thank you!
    Thank you so much for your replies, gentlemen! My new Jamis is home and I cannot wait to ride it; the weather is supposed to be, well, better than it has been on the east coast of the states. I know I need to get out there and ride , but I cannot keep my eyes off of a couple of new wheels. The new Easton Haven's are tubeless and supposedly weigh in at about 1650 grams....the Fulcrums and Alex's really look awesome...but that is champagne on a corona budget. lol. I just thought I would share. "just say'n!" Thanks so much for writing back.:smilewinkgrin:
  • 11-18-2010
    throoper
    2.0 or 3.0?
    Hey, hoping to revive this discussion for a minute. I"m considering buying this bike... at first I wasn't going to spend more than $800, then I decided to go with the Dakar 2.0, and now I'm thinking about spending the extra $275 for the 3.0. ($1370 on jensonusa.com, as opposed to $1100 for the 2.0).
    So, can I ask why you guys went with the 3.0 over the 2.0? Are the components a pretty serious upgrade? I'm 5'5" 120 lbs, so I'm definitely interested in the lower weight as well (and then probably will swap out the tires for lighter ones). And to the original poster, how do you like the bike??
    Thanks in advance for your thoughts!
