Results 1 to 3 of 3
    Aug 2018
    Caution;  Merge;  Workers Ahead! Clicking on pedal rotation... help!
    Hey so I recently bought a 2013 D29 Team and after a few rides I've begun to hear a clicking noise on a pedal rotation, similar to pedalling backwards but not as frequent or as loud. Almost sounds like a creaking. It doesn't effect my ride at all its just the noise that concerns me. I'm wondering if this is something I should be concerned about, and what part might be causing it. The noise is happening around the front gears / pedal crank, however I don't know the exact culprit. Let me know if you need more info.
    bikeaholic
    Probably just a little dirt/debris in the BB area. Try removing the cranks and clean everything to make sure it's clear of dirt/debris. Then lightly grease everything and reassemble.
    That process will fix most creaky crank issues.
    Nov 2017
    I had this same problem. It turned out that I had some play between the bottom bracket and non-drive side crank arm. I ended up upgrading the BB and Crankset (the stock was 8 years old). The new parts are quiet. I probably ruined the original crank arm by over-tightening IMO
  1. Replies: 4
    Last Post: 03-28-2012, 09:31 PM
  2. bike makes a clicking noise when pedal
    By akacoke in forum Beginner's Corner
    Last Post: 10-29-2011, 07:58 PM
  3. pedal pedal pedal wtf? ouch!...chain broke
    By rzims in forum Singlespeed
    Last Post: 09-05-2006, 08:57 AM
  4. WTB AllTerrainasaurus Tire Rotation - Shiggy Help!
    By STUMPJUMPER FSR in forum Wheels and Tires
    Last Post: 06-24-2006, 11:01 AM
  5. need help with rokshox susp post rotation
    By crepitus in forum Shocks and Suspension
    Last Post: 01-03-2005, 12:48 PM
Members who have read this thread: 12
