    Sep 2016
    shimano alfine 8 shifter uses thumb to shift up (harder gear). can I swap this ?
    hey people, I have a broken alfine 11 commuter which when you use the thumb shifter it goes to an easier gear which is similar to my mountain bike (and I like).
    However I have now bought an alfine 8 commuter bike where the thumb shifter goes to a harder gear (ie from gear 1 to gear 2).
    confusing I know.
    I can get used to this thumb upshift but would like to change it if possible with another 8 spd shifter as it might confuse me when mtn bike racing one day (after changing opposite way on my commute)
    Does anyone know if this is possible or is a limitation of the nexus 8 internal hub ?
    8 speed bike is a Focus PLANET 3.0 2014, just FYI.
    Cheers
    Perry
    ** just re read this and its a bit confusing. the below should help:
    - currently my alfine 8 uses the thumb shift to shift up and the finger pull to shift down.
    - I would like to reverse this so the thumb shift shifts down and the finger pull shifts up. similar to my sram mtn bike setup and my old alfine 11 setup.
    Reputation: Velobike's Avatar
    It's the other way round on the new Alfine hubs apparently.
    Shame, I prefer the finger pull to change down because that's faster and changing down is when you need a fast gear change IMO.
    I don't think you can simply swap the changer over, but if it's possible I'd like to know too.
    Latitude: 5736' Highlands, Scotland
    Quote Originally Posted by Velobike View Post
    Correct on both points. You can't just swap the gear changer because the resting points on both hubs are opposite. The shifting spring inside the older hub is literally wound the other direction, and Shimano flipped the shift map (including all of the not-equal cable pulls between gears).
    You can buy a new axle assembly and retrofit it, along with a new shifter, but that is a bit of a boondoggle when there aren't any damaged parts. Better to buy what you want, replace the old one, and sell it in its entirety.
    Sep 2016
    awesome thanks for the replies, I will just make do and see if my alfine 11 can get repaired at some point.
  1. Shimano rear XT shifter cables won't back out of the thumb shifter housing
    By ReturnOfTheMTB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-06-2016, 05:21 PM
  2. Adjusting a SRAM XX1 low gear thumb shifter positioin
    By Phread in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-27-2016, 04:16 PM
  3. Carbon frame uses BB30, alu uses BB386??
    By Alias530 in forum Felt
    Last Post: 12-28-2014, 04:07 PM
  4. Replies: 27
    Last Post: 03-28-2012, 09:06 PM
  5. How Hard is it to...swap XO grip shift for trigger shift????
    By Quantdude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-17-2007, 03:25 AM
Members who have read this thread: 16
