Help with Alfine 8 and chain wear- Mtbr.com
Results 1 to 3 of 3
    Reputation: cr3anmachin3's Avatar
    Feb 2015
    Hopefully some Alfine 8 gurus here who can help me. I'm not a complete novice but a few issues are bugging me. Running one of these on a Pinnacle Arkose with eccentric bottom bracket. I wore down the last sprocket and chain so decided to spring for new FSA 40T chainring, new alfine 19T sprocket and paired with a KMC Z1 Wide SS chain. My problems are two-fold:
    1. After a couple of rides the chain loses tension and starts to slacken a little...so much that it starts to rub against the top of the Alfine gear arm. The EBB bolts are fine but I think after some bumps the alfine gear arm shifts (or the wheel does in the dropouts) which then creates a bit of slack. I've bodged it with a zip-tie round the gear arm and rear dropouts but it's not ideal and affects shifting to 1st gear a little.
    2. There is only 700km on this chain yet I stuck a Park Tool chain checker on it and it's already past 0.75...WTF? I've looked after the drivetrain and wasn't expecting chain to be so worn unless I'm missing something and the chain checker doesn't work the same with a SS chain?
    Thoughts or help anyone?
    XC
    Trail
    Road
    Fat...it's all cycling.
    Reputation: ladljon's Avatar
    All chains have a tight spot.....sounds like chain is too tight. Adjust tight spot with 10mm of free play.....
    Tread killer....
    What is your chain-line like, are the sprocket and chainring aligned?
  1. Chain wear on fat bikes - do chains wear quicker?
    By cr3anmachin3 in forum Fat bikes
    Last Post: 04-19-2018, 08:44 AM
  2. Alfine 11 vs Patterson/Alfine 8 for a clyde cruiser ...
    By tedsalt in forum Internal Gear Hubs
    Last Post: 12-25-2014, 08:32 PM
  3. Replies: 16
    Last Post: 12-13-2013, 10:30 AM
  4. What to wear and how to wear it
    By rcrscott29 in forum Apparel and Protection
    Last Post: 02-28-2013, 04:58 PM
  5. Replies: 2
    Last Post: 06-06-2012, 04:20 AM
Members who have read this thread: 8
