Chain compatibility with an Alfine 8 sprocket- Mtbr.com
Results 1 to 3 of 3
    Reputation: dfuse's Avatar
    Feb 2013
    Hi,
    I will be converting my singlespeed Surly Straggler to an Alfine 8. However, if possible, I'd like to keep my front setup, CX-1 cranks with a direct mount Wolftooth narrow-wide 42t ring. The Wolftooth only takes 10-speed or higher chains. For the Alfine sprocket the Shimano website advises to use a 9-speed chain. I have been bitten before by wrong combinations of front ring and sprocket so I'd like to make sure now.
    I could replace the CX-1 with the Alfine cranks but preferably not.
    Any advice?
    Another question related to the gear ratio, I ride a 42x17 now. I require a bit more range both above and below that, that's why I'm going to the Alfine. What sprocket would I best use? Here it recommends to have a 19, 20 or 21 sprocket but it seems that the Alfine sprockets only exist in 18,20t. I just don't know if for example I pick an 18, how many gears do I have above and below it, ie what's the starting gear for a given combination?
    Many thanks.
    Reputation: Wombat's Avatar
    I think you'll be fine with a 10 speed chain. They are the same internal width as 8 and 9 speed chains.
    For your 2nd question, 5th gear in the 8 speed hub is 1:1. This is taken from here: https://bike.shimano.com/en-EU/produ...G-S7000-8.html. If you use a 17 tooth sprocket, it will give 4 gears below and 5 above. You can use Nexus sprockets on Alfine hubs.
    Gear ratio_1 527
    Gear ratio_2 644
    Gear ratio_3 748
    Gear ratio_4 851
    Gear ratio_5 1
    Gear ratio_6 1223
    Gear ratio_7 1419
    Gear ratio_8 1615
    Tim
    Feb 2013
    Thanks a lot!!
  1. Alfine 11 vs Patterson/Alfine 8 for a clyde cruiser ...
    By tedsalt in forum Internal Gear Hubs
    Last Post: 12-25-2014, 08:32 PM
  2. Chain wrapping back around crank sprocket catching on chain stay what to do?
    By Thall36 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-05-2013, 08:53 PM
  3. Chainguard on Alfine Sprocket
    By drofluf in forum Fat bikes
    Last Post: 11-14-2012, 04:54 PM
  4. Replies: 2
    Last Post: 06-06-2012, 04:20 AM
  5. smallest sprocket on an alfine?
    By sonic reducer in forum Internal Gear Hubs
    Last Post: 02-23-2012, 05:29 AM
Members who have read this thread: 12
