Results 1 to 5 of 5
    Apr 2016
    Upgrading my Primer.
    For the upcoming season I'm doing a few upgrades to my Primer Bandit.
    One is Sram XX1 gold drive line with 170mm cranks to help cut down on pedal strikes. Has anyone switched to shorter cranks and actually noticed?
    One thing I'm not sure on is, my bike came with M1900 DT swiss and the wheels are fine but the rear hub has a fair bit of back pedal to engage the next pawl. Can I just swap out to the DT 350 hub or whatever it's called on the 1700 wheel sets. I think the spokes are straight pull on the 1700 wheels. I'd like to swap my rear hub and not have to change my whole wheel.
    Sent from my SM-T820 using Tapatalk
    Reputation: slider_phil's Avatar
    Aug 2014
    You can just upgrade the ratchet in the hub itself. A 15 min job. Just look for DT Swiss ratchet kit. The 350 hub usually has a 18t engagement and you can buy a 36t and 54t upgrade kit
    nmh
    nmh is offline
    I just switched to a 165 mm cranks on my 17 Primer. I am on a large frame bike, am 5'10". I have a longer torso and short legs. Pedal strikes were annoying, but it seems common on all my friends newer bikes too, at least in our East Coast terrain. Only have had two rides, in under 30 deg temps, so far so good, no pedal strikes. Will really need to get a bunch of warm weather rides to see how it affects my rides/handling.
    Jan 2018
    Quote Originally Posted by slider_phil View Post
    Unfortunately, I do not believe the Banding (with the M1900 rims) has 350 hubs but some lower quality ones that don't have the option to upgrade as mentioned above. If I am incorrect, that would be good news as I have the same bike/rims and would love to do an easy upgrade such as this.
    Apr 2016
    Quote Originally Posted by RCederholm View Post
    The 1900s come with 370 hubs which aren't even listed on the website
    Sent from my SM-N950W using Tapatalk
  1. Trail maintenance primer
    By Woodman in forum North & South Carolina
    Last Post: 06-18-2013, 08:59 AM
  2. I Need a Primer on MTB Community/Trails in Nashville Area...
    By cohenfive in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 11-14-2012, 07:42 AM
  3. carbon painting... primer ?
    By eric_syd in forum Frame Building
    Last Post: 03-09-2012, 08:25 AM
  4. How long to let primer dry and how much to sand?
    By getagrip in forum Beginner's Corner
    Last Post: 09-13-2011, 12:39 AM
  5. Painting my frame. Should I sand the primer?
    By f3rg in forum Frame Building
    Last Post: 09-12-2011, 10:52 AM
Members who have read this thread: 56
