6.6 12mm axle?- Mtbr.com
Results 1 to 8 of 8
Thread: 6.6 12mm axle?
    Hold on for 8 seconds!
    Reputation: Elmo's Avatar
    New question here. 6.6 12mm axle?
    Can someone tell me if my 6.6 frame can take a 12mm rear axle. I searched and searched and couldn't find the info.
    Cowboy's wear Hats not Helmets!
    Mar 2006
    No.
    Bonking ... not feelin' well
    Thank you.
    deez nuts
    Reputation: shaft's Avatar
    Your best bet is the DT Swiss 10mm on that frame
    Reputation: iRider's Avatar
    Or you could use one of these:
    Universal Cycles -- Delta Axle Rod Skewers
    It is significant stiffer than a quick release in my experience. And I think at least as stiff as the DT 10 mm axle.
    Dec 2005
    I have successfully been running Chris King Funbolts on mine for many years. Should be as stiff as any 12mm axle system.
    Thank you all for your replies!
    I bought a whole new rear wheel with the saint 12mm hub to stiffen it up and was suprised it didn't come with an axle. Then I found out that the 12mm axle won't fit the 6.6 anyway so it looks like I'll get one of these Sun Ringle Rear Conversion Axle 2012 | Buy Online | ChainReactionCycles.com Sun Ringle conversion jobs when they come out in a month or so. No big deal, still got my old wheel on the bike,. But in hindsight I would've just bought one of the suggestions above and saved a ton of money. By the way the 6.6 is still going strong!
    Mar 2006
    You can get your local machine shop to make u an axel that goes from 12mm down to 10mm threaded ends. I did this for $20.
