Night riding in Boise...- Mtbr.com
Results 1 to 42 of 42
    Reputation: Steady Grind's Avatar
    Does anyone out there do it? Its to F'n hot to be riding during the day, and if you start early in the morning and end up riding for too long, you still melt...so I wouldn't mind doing some night rides....anyone interested in a tag-a-long?
    I've not been killed, only wounded...I'll just lie here a while and bleed, then rise again to fight another day.
    Reputation: BoiseBoy's Avatar
    Feb 2006
    Full Moon
    Quote Originally Posted by Steady Grind
    The moon should be full in a week or so. I find that full moon night rides are the best. Sometimes you don't even need your light on if it is a clear night.
    BoiseBoy
    mortman
    Saturday nights
    Some of my coworkers and I do a Saturday night ride. Ususally start at the "learning center" behind the lower parking lot on 8th. Usually start between 11:30pm and midnight. Won't be there this Saturday, probably next week though.
    Usually climb Kestrel to Freeway, ride to the water crossing and bridge on Hulls and come back to the cars on Hulls for some beers.
    Kind of a late start for most, but I will try to post before the next one. We have been doing the rides to beat the heat as well. Haven't seen a cougar yet this year.
    ride to work, work to live, live to ride.
    Quote Originally Posted by mortman
    Count me in!! If you don't mind a tag along, I'd love to catch one of these rides with you. I'm down with the post-ride beers too! Post something on here, or send me a private message when you know you'll be going out again.
    Anyone else do any night rides????
    I'd like to, but 11:30 is past my bedtime .
    I'll probably do night rides in the Fall.
    Idaho
    TRAIL KUBUKI CORNDOGGER
    Reputation: TwistedCrank's Avatar
    In the winter when it's cold, dark and dangerous is best.
    Nobody cares what kind of bike you ride.
    Sheepherder/Cat Herder Moderator
    Reputation: Visicypher's Avatar
    I ride in the dark every day.
    ...building wherever they'll let me...
    Quote Originally Posted by Visicypher
    Visicypher is dark, dangerous and cold too.
    Why play in the cat box when it is hot and sticky when there is nice cool riding above?
    Night light it's for winter!
    Since I don't have a visa to travel to Somalia...and insomnia is not an African nation...and I have been having bouts with it instead. I've been riding at 5:30ish am. It is not too dark...but it gets darker every day.
    Baa
    Dude,
    Since the insomnia you suffer from is most likely caused from the hellish place you call a livelyhood, I would think the flames from hell would light the way for your morning adventures.
    You might also think about starting your day with milk in your latie and a spark arrester on the seat- blue flame black sheep - baa!
    Your partner in hell!
    I would like to join for a night ride! Love being out on summer nights!
    mortman
    Riding this coming Saturday night the 19th
    Should be doing the usual SAT night ride around midnight in case anyone wants to tag along.
    We park at the "learning center" in the lighted parking lot and leave from there and return there. Usually climb Kestrel to Freeway to Hulls bridge and down Hulls to cars.
    Last ride for the first time in 15 SAT night rides, we had a BPD officer stop and give a Q&A about what we were doing. Just said he patrols there a lot and so do other officers and we might get a parking ticket for being in the area after dark. Kind of let it all go when we said we park there for the well lit parking lot.
    1 out of 15 rides...and it gets patrolled a lot.....?
    I'll post a note if plans change.
    What would the difficulty level be on this ride?
    Quote Originally Posted by strawflower16
    The route that he's describing is an easy ride...going up kestrel would be the most strenuous part of the ride, and that's no big deal.
    mortman: I'll be there...sounds like a good time...beers afterwards right?
    mortman
    Si, Cervezas!
    Also, the ride is not too bad. Kestrel is a good climb, if you usually ride flat loops. There is another steep short climb not too far after topping Kestrel. Then it is pretty easy to where Freeway meets Hulls. Coming down Hulls there are plenty of rocks that sneak up on you, worse if you do not have enough light. I suggest helmet mount and bar mount to see more. Some light set from a shopping center might not cover it.
    I do not take Hulls much slower coming down at night than in daylight, or it just seems faster because of the darkness. The speed could get you without enough light.
    If you have not ridden this in day light it, there might be some parts coming down Hulls that would be bad for a first time night time trail ride......My 2 cents.
    Also, last ride on this loop I thought I had enought charge in my lights and found out before Hulls that I did not. Low light, or not enough light made it difficult, even following someone with "full power".
    Okay, Thanks for the much needed info! Looking forward to it.
    You haven't lived until you've ridden Eastside by headlight. The trees seem to jump out at you and there are plenty glowing eyeballs to give you the willies.
    The willies I tell you!
    Ridge Road at night. Plenty of eyeballs peering at you. Occasionally, you'll hear the kitty.
    King of the Barneys
    Reputation: CBro's Avatar
    If you're not familiar with riding Hulls Gulch during the day...
    riding it at night can be a little tricky, even with good lights.
    I've ridden it on my fully rigid SS on a black night with just a bar mounted light and it was a wierd trip, light bouncing around like crazy--me trying to tell myself I was having fun.
    May your trails be narrow, crooked, lonesome and dangerous, leading to the most outrageous adventures. Paladin
    oops...
    Reputation: hodgee's Avatar
    Nov 2006
    I don't want to hear the kitty. Hearing the kitty costs around $100 (new shorts, new saddle, etc.)...
    I will check it out before Saturday night. Looking at the map looks pretty simple to navigate. Is there another name for Freeway? Not seeing that on there.
    oops...
    Nov 2006
    Crestline is the name on the map...
    King of the Barneys
    Quote Originally Posted by hodgee
    It's better to have somebody (Gary) email you pictures taken of the kitty, the next morning, showing you were at least within a quarter mile or closer to the kitty the night before.
    Ended my solo night riding career, right there.
    Back of the pack fat guy
    If'n I see one more person refer to the grand and noble cougar as a "kitty," I'll retch. It's like calling Twisted Crank a three-toed sloth. Yes, accurate, but way too soft and sweet.
    Kitty. Kitty. Kitty.
    And Beetlejuice to boot.
    One more quick question! Where is the Learning Center? Is that just the parking father in at Camels back?
    mortman
    I think it is called the "learning center"
    It might be called something else. Drive up 8th St. and after it turns to dirt pull into the first parking lot on the right (approx 400yds after the dirt starts). When you pull into this lot pull all the way to the back side and there is a dirt drive that exits to the right and takes you 40 yds to the lighted parking lot with a light that turns on and off because the bulb is burning out. The "learning center" is next to the second parking lot.
    I hope to be there between 11:30 and 11:45pm after I leave work and start riding by midnight.
    Quote Originally Posted by TwistedCrank
    Eastside?? I don't think I'm familiar with that one...does it go by another name?
    You guys are freaking nuts!!! I dont know that I want to go down that trail in the daylight again let alone at night! I'll definately be there on Saturday though, ha ha!
    Only click this link if you have a fast internet. It's an 8MB file that will tell you all you need to know. Trail 120 is Eastside.
    http://www.cityofboise.org/parks/R2R/Shafer_butte.pdf
    blet drive
    Reputation: JUNGLEKID5's Avatar
    ya thats the spirtit go for it
    Save a tree & wipe your butt with an owl.
    Thank your local Sierra Club.
    'steady as she goes' is the name of the game if you've never ridden a trail like that at night! Just make sure you've got your lights adjusted before you start heading down that one!
    How was it?
    Sorry I missed the ride!! How was it? I was really looking forward to it, but after I left the twilight criterium last night I was so tired that I just couldn't do it (got up at 4:30 yesterday morning!).
    I'm hoping you'll do the ride again next Saturday....let me know if it's going to go again!
    Hope you all had a good time!
    plays well with cows
    Reputation: belowambient's Avatar
    im in but i need to replace my battery first
    mortman
    Night Train
    The ride went well. No casualties, and a nice slow pace. Saw some field mice and some mormon crickets. GOOD TIMES!
    There were 5 riders total. The usual two, plus strawflower16 and two guy friends of hers. GOOD ride and a couple GOOD Beers. I had most of my shmorgisboard of beers left at the end of the night. My buddy Will brought Sam Adams Black Lager and it was a treat.
    Most likely doing it this coming Saturday also.
    The lights of five riders were pretty cool looking riding along!
    Sucks I couldn't make it, sounds like it was a good time! Next weekend will be a for sure thing for me though. Make sure you post time and location again if anything changes! See you next weekend......
    Riding Tomorrow?? (Sat. 26th)??
    Hey Mortman....
    Are you guys doing your ride again? I'll make it this time!
    mortman
    Same time, same place, same Bat Channel
    We ARE doing the usual night ride tomorrow. It will be three for sure if you are there. I do not know if any of the extras last week will be there, kinda sounded iffy at best. Who knows maybe others will show up for a way past bed time ride. The more the merrier!.....to a certain point. After that it's just plain crowded.
    Also, there will be a selection of cold ones again, I believe. I did not get home till 3am last week, but I live in Nampa.
    See you there around 11:59pm on Sat. the 26th!
    Word.
    Won't f'n make it...again
    Mortman...
    I hope you get this at work before you head off for the night ride. Dude...I don't think I'm going to make it again. Bad f'n timing...sorry. So, don't wait for me if I'm not there when you're ready to take off. SORRY!!!
    mortman
    Nite Brite is FUN!!
    Glad you could make it SG. I think night riding after a whole day at Tamarack might have been overkill. I rode way more sketchy than ever. A lot less control when muscles don't work like they are supposed to.
    Good pick on the Summer Honey!
    Next week is out for me, but hope to be out there again soon!
