How's Velo or Hulls Gulch?- Mtbr.com
Results 1 to 8 of 8
    I am itching to go riding this afternoon...supposed to be 41 degrees! Does anyone have any idea how Velo or Hulls is?
    Thanks, Nick
    Back of the pack fat guy
    I rode lower Hulls on Friday and Saturday afternoons and it was dry enough to ride. Considering we haven't had any moisture, it should be fine. However, I wouldn't head down the Freeway or try Sidewinder, the bottom of which is totally hammered.
    Also, you can always check R2R's blog on trail conditions here: http://ridgetorivers.blogspot.com/ There's usually an update about Hulls.
    Reputation: flipnidaho's Avatar
    Hulls-Freeway is good. All of Trail 5 is good as well. The first part of Sidewinder is starting to dry out so there should be a ride-able line that will be good for today or tomorrow.
    Avoid Corrals, Bob's (the top is a mess), most of the Mil Reserve have long muddy sections... After a few days of sun and 50+ degree weather, it should get better..
    Rode Velo this afternoon...muddy in alot of sections...Rabbit Run was muddy in sections as well as D's Chaos!
    Velopark, Seamans Gulch, Pole Cat, and the trails by the Veterans Cemetary hold a lot of moisture and aren't typically useable in the winter unless frozen, regardless of how dry the rest of the trails may be.
    Feb 2006
    So now the are muddy and RUTTED............................
    oh no Fred they aren't...picked up the bike and walked through it...didn't rut it up for ya!
    Feb 2006
    Quote Originally Posted by nicksstorm
