Flat prevention- Mtbr.com
Results 1 to 10 of 10
Thread: Flat prevention
    Reputation: Phoinix's Avatar
    Flat prevention
    In Boise how many are using tubeless or stans or slime to prevent flats or do you just run regular tubes and tires?
    King of the Barneys
    Reputation: CBro's Avatar
    slime tubes all the way for me. the foothills aren't so bad for thorns, etc., but the neighborhoods sure are.
    CDB
    May your trails be narrow, crooked, lonesome and dangerous, leading to the most outrageous adventures. Paladin
    Sheepherder/Cat Herder Moderator
    Reputation: Visicypher's Avatar
    Count me as one using tubeless with new Mavic valve stems with the removable cores and Slime for tubeless. My race wheels are not tubeless.
    ...building wherever they'll let me...
    I use UST wheels/tires with a scoop of Stan's. Thousands of miles, zero flats.
    TRAIL KUBUKI CORNDOGGER
    Reputation: TwistedCrank's Avatar
    I have wooden wheels on all my bikes so it's pretty much a non-issue.
    Nobody cares what kind of bike you ride.
    TERVOR THE GREAT
    Reputation: DelTaco's Avatar
    Jan 2005
    USE STANS IN A TUBE!!!
    It's amazing stuff. I have not flatted in 2 years with the exception of 1 pinch flat. I've had screws sticking out of my tire from riding through a construction site and it sealed!
    Trust me. Get stans and put it in a tube and flats will become a forgotten problem.
    I am become death, the destroyer of worlds.
    liver abuser
    Reputation: SpeedyGonzalas's Avatar
    I have been running Stan's Notube in Spec. Fastrack tires, on regular DT rims for 4 years with only one flat. That was a big tear in the sidewall.
    Rocks Rock
    Reputation: impdude's Avatar
    Feb 2005
    Steve showed me some Penziol stop leak for tires (Orange). I'm going to try that, it's cheaper then Stan's.
    Am I being kind?
    BMX:Our Shining Future
    Reputation: davidarnott's Avatar
    Feb 2007
    Stans No Tube Here
    I tested stans no tube in a pugsley by riding it over the top of about threee hundred cactus plants didnt even lose any air pressure so far no flats
    Feb 2007
    also
    also I tried putting stans no tube into a tire that was flat from cactus spines without even taking it off the bike spun the tire back and forth for two minutes and then just pumped the sucker right up its the easiest and fastest way to FIX a flat ever
