CK Hub service/bearing replacement tool?- Mtbr.com
Results 1 to 3 of 3
    mtnjam
    Reputation: ryman's Avatar
    Anyone know who services CK hubs here in Boise?
    I could probably do MOST of it myself after reading the PDF's and viewing the videos on Kings website, but I don't have the hub tool to do the other work. Anyone have a CK hub tool or know a shop that does.
    Also in trying to get the rocker bearings replaced in the Switchblade does anyone have a bearing press that I could use?
    Reputation: flipnidaho's Avatar
    Quote Originally Posted by ryman
    Try Jason at George's on Front or Brian (for the Titus work).
    Reputation: Wayndar's Avatar
    You can clean and re-grease the hubs without the tool. Do your bearings need to be replaced?
    FWIW, You might want to send it direct to CK, they rebuilt mine and replaced the hub body with the ISO disc body for about $30.
