Which XT 12-speed cranks on Mojo3- Mtbr.com
Results 1 to 3 of 3
    I am upgrading my 2016 Mojo3 from an M8000 11-speed 2x setup to an M8100 12-speed 1x.
    I see there are 2 crank options, FC-M8120-1 or M8100-1. I am trying to figure out the best choice. I see Ibis specs the M8100, but I question the accuracy of the website to rely on it. Suggestions?
    FC-M8120-1
    - 178mm Q-Factor
    - 55mm chain line works with 148 O.L.D.
    - Prioritizes frame and tire clearance
    FC-M8100-1
    - 172mm Q-Factor
    - 52mm chain line works with 142 or 148 O.L.D.
    - Prioritizes narrowest possible Q factor
    Reputation: Rhialto's Avatar
    My Mojo has a Turbine 1x crankset. I'm pretty sure the chainline is 50mm. The upshot of a 50mm chainline is the largest chainring I can run is 32 tooth otherwise the teeth get too close to the chainstay. I think others have managed to fit a 34 tooth but the clearance is millimetres. However, as I spend a lot of time in low gears, the smaller chainline works better for me and I have no intention of fitting a larger chainring. Hope that helps.
    Dec 2008
    Quote Originally Posted by End_User View Post
    FC-M8120-1
    - 178mm Q-Factor
    FC-M8100-1
    - 172mm Q-Factor
    I would choose the cranks that give you a 52 mm chain line every day of the week.
  1. Replies: 4
    Last Post: 3 Weeks Ago, 07:20 PM
  2. Is XTR 12 speed compatible w/ Sunrace 12 speed?
    By endo_alley in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2019, 05:52 PM
  3. E*13 or Sram Eagle 12 speed cassette and Shimano 12 speed???
    By dvdslw45 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-26-2019, 10:29 AM
  4. 12:12 12/12/12
    By Guerdonian in forum Off Camber (off topic)
    Last Post: 12-13-2012, 06:09 AM
  5. 9 speed cranks versus 10 speed cranks
    By JokerBoy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2011, 03:01 AM
Members who have read this thread: 8
