Results 1 to 13 of 13
    Wat size seatpost clamp/collar for mojo?
    Want to swap out the SL clamp and go with a quick release style. Ibis is out of the qr in blue, so gonna go with Hope or Salsa. What size do I need? Any opinions on the two brands mentioned?
    31.6 same as Trek Top Fuel Carbon not a real common size.
    I think it might be possible to change out the bolt on the fixed collar with some quick release bolt of the correct size. I'm sure someone around here has tried something like that with a weight weenie quick release binder.
    Hope has one in 31.8mm and salsa has one 32.0mm. Will either of those work?
    Dec 2005
    i would only use ibis brand due to shape
    mx
    Now if they'd only get the blue in stock, I'd be happy! Guess i'll just go all out and get a Joplin (now if only they offered that in blue!).
    Hold on - the seatpost is 31.6mm in diameter - I think the clamp is 34.2mm? Must be bigger than 31.6mm, since it goes over the carbon seat post sleeve.
    That's wat I was thinking as well. But obviously i don't know, as I asked the question!!
    Slovakia (Europe)
    Reputation: PeterG's Avatar
    34.9mm will fit seat tube OK, but Ibis has specially shaped end of seat tube, so standard QR binder will not work very well and will not look nice. I guess it's an intention to spread the shear forces to carbon seat tube to wider area (not applied only in the plain) but maybe it's design purpose only. And more, usually 34.9mm QR seat binders are intended for 30.9mm seatposts, so internal diameter is not enough wide for Ibis 31.6 mm seatpost (too thick inner flange), because Ibis seat tube is thinner then normally. I've tried Tune Wurger 34.9mm, but finally sold it.
    Not sure why Ibis chose that odd shape but it is a bit silly to make a frequently changed/upgraded component that unique. I wonder if other clamps can be used safely.
    Agree. On my frame, the seatclamp doesnt go all the way over the sleeve, there is a gap showing. Is that the same for others, too?
    It wouldn't be a huge deal if they had the blue in stock. But I agree, it is a pain in the butt trying to find a part that should be readily available from Ibis
    They are actually in stock and we just forgot to update the webstore. Should be fixed Monday.
    H
    H
    Awesome, Thanks Hans
