• 07-30-2010
    ianthom
    upper link bolts stuck in lopes link
    Hey guys
    was installing a new lopes link, and discovered that my upper link bolts are stuck in the bearings, anyone had this trouble before, and if so any tips for getting em out?
  • 07-30-2010
    hanssc
    Originally Posted by ianthom
    Hey guys
    Sent you an email..
    H
  • 07-31-2010
    GbrNole
    Hans could you make the fix known, I switched out some links on the HD and had the same problem. Looked like loctite was stopping the bolt backing out and bending the link.
    I resorted to a hammer but would be good to know for the future
  • 08-01-2010
    hanssc
    That's what we do too.. Tap them out of the bearing once you get the link out.
    A little anti seize should prevent it from happening in the future. I'll mention it to the guys in case we've been missing that during assembly.
    Hans
  • 08-05-2010
    GbrNole
    Yeah the bolt couldnt back out past the bearing when i was unscrewing, ended up flexing the link and pulling the bearings out of the links. I had to unscrew the bolt somewhat and then hammer the bearing to get it to break free from the bolt (whilst still on bike)
    Can you confirm I dont need to apply threadlock to the bolts on reassembly, i thought the problem occurred due to threadlock?
  • 08-05-2010
    hanssc
    On the Ti bolts, we use anti seize. On the stainless we use loctite. It's touchy, on one hand you don't want it backing out during riding, on the other hand, you would like to be able to remove it later without any damage. If you use loctite, if you put it in the threaded bore rather than on the screw threads, you have a better chance of getting it out of the bearing later.
    H
