Thoughts on the S35 i9 carbon wheels?- Mtbr.com
Results 1 to 5 of 5
    Wondering if anyone has them? Are they loud? Debating whether they are worth the $1100 upgrade on a new bike or if there is something lighter to look into for around the same price?'
    I don't ride really chunky trails. Mostly rock gardens, loose tracks, and I'm only 150lb. Was thinking of making the Ripley out to be more of an XC bike and checking out Zipp Moto wheels with a medium casing, medium compound fast rolling set of tires might be the killer setup.....any other recommendations?
    Jun 2012
    I would say if youíre 150lbs, and donít plan on gaining weight in the future, there are lighter options that will fit your need better. Especially if you consider yourself an XC guy and not a trail/enduro guy.
    Mar 2017
    Get the S28s if you want Ibis Carbon.
    May 2012
    I have 2 sets of the I9 Hydra Hubs with S35 rims for 2.6Ē wide tires. 1 is a bit louder while the other one is quieter. Both are NOT as loud as the older I9 torch hubs though.
    '20 Ibis Ripley
    '18 SC Tallboy CC_Wife
    '17 Giant Anthem Adv_Kid
    '17 Ibis Mojo 3
    '17 SC Bronson CC-Spare
    Nov 2014
    They are pretty loud. It can be kind of nice, because hikers usually hear me coming without a bell. Supposedly you can pack some more grease in them if you want to quiet them down a bit. It looked like they came with a pretty light coating, so I might have to try that at some point.
    I think the S28 would be a better rim option for a lighter, XC/Trail build. The 35mm internal on the S35 seems a little wider you'd want for modern 2.3-2.6" XC tires and might expose the sidewalls or square off the tread a little too much especially at the smaller end of that range. The 28.6mm width of the S28s is a little more comparable to the Zipp rims you're considering, but the S28s are about 160g lighter per rim than the Zipps and 40g lighter than the S35s. The S35 might be a better option if you want to run larger 2.5-2.8" tires.
    The Zipps should be the a little more compliant, but you pay a pretty hefty weight penalty for that and they're probably overkill for the type of riding you're describing. My S28s don't feel overly stiff or harsh at all, although I am running them on a 170/160mm bike with really good suspension.
  1. Replies: 0
    Last Post: 05-07-2020, 04:35 PM
  2. Experience with S35 wheels/rims?
    By jonlong724 in forum Ibis
    Last Post: 02-05-2020, 03:16 PM
  3. S35 Alloy Wheels - Tubeless Ready?
    By jonlong in forum Ibis
    Last Post: 12-06-2019, 06:56 PM
  4. S35 carbon wheels de-tensioning
    By ADD in forum Ibis
    Last Post: 12-02-2019, 07:36 PM
  5. Ibis S35 Rims/Wheels
    By WoodstockMTB in forum Wheels and Tires
    Last Post: 08-08-2019, 04:07 PM
Members who have read this thread: 67
