SIZING Help for a Ripley V4!- Mtbr.com
Results 1 to 19 of 19
    Reputation: RooHarris's Avatar
    I've owned several Ripleys. All V1 and V2 OGs. The mediums all fit me well. But, I'm hearing that with all the geometry changes for the V4, I might be looking at a small frame? I'm 5'5.5" with a longer torso and a 28" inseam. Reach and Stack are very different here between the OG's and the V4. I'm ready to order a black one in the next few days. Can anyone help me with a size determination.
    Thanks,
    What size of stem were you riding?
    Quote Originally Posted by canuck_tacoma View Post
    90mm.
    May 2017
    Quote Originally Posted by RooHarris View Post
    Thanks,
    Not much help from me but have you emailed Ibis?
    Wanna ride bikes?
    Oct 2013
    According to the sizing chart you could fit either.
    Since you were using a 90mm stem I'd say stick with a Medium.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: Liquidmantis's Avatar
    Yeah, I'd say that's really stretching the size range for the small, but in the sweet spot of the medium. My vote would be for medium, likely with a shorter stem.
    Agreed on medium. Ibis advised me to stay medium going from a Ripley to Ripmo, if I liked medium in the former. They were right. It fits great. I bet the same for this new Ripley.
    Shortcutting Hikabiker
    Reputation: Acme54321's Avatar
    Oct 2003
    I would stick with a medium. They have tried to keep the sizing the same as what you would typically ride, the big geometry changes make that hard to believer at times. Look at the ETT between the bikes and factor in that the new Ripley is designed around a much shorter stem.
    Personally, I'd try to get a good ride in on one first depending on how steep the seat tube is on your current bike it could feel very different. I have a hardtail that has a 72 degree STA and a Smuggler with a 75.5 and going between the two it's immediately noticable. I ride the smuggler 95% of the time and if I haven't been on the HT for a while it feels like I'm sitting on an Electra Townie at first.
    Thank you for all these suggestions
    Quote Originally Posted by Acme54321 View Post
    I ordered a medium yesterday through Myke Berna of Velo City Cycles. Myke now has another shop here on the Mendo coast. Before doing so, I spoke with Todd and Scot and both did not hesitate to suggest going w/ a medium. That being done, I'm beside myself trying to wait for delivery sometime in early July. Meanwhile, I'm selling both my Ripley V2 OGs for $3100 each. All XT w/ carbon 928s on one and I9 wheels on the other. Both bikes are in excellent shape.
    Thank you all for your support to make a well thought out decision. New bike fever is something I get every 5 years or so after spending time enjoying what Ibis I might be currently riding. Best bikes I have ever ridden. Plus, their customer service is spot on and ready to help w/ anything.
    May 2017
    Another vote for medium
    Iíve had 3 Ripleys both OG and LS all size L with 80mm stem with perfect fit. For theV4 i emailed ibis and they suggested to get a M.
    All suggestions are very welcome
    May 2017
    Quote Originally Posted by mtbpri View Post
    If a large LS with an 80 mm stem fit perfect, there is no way you want a medium. Only way I would guess Ibis said medium was if your height is smack dab in the medium zone. Are you 5'8" or so?
    Still I would go with what is perfect fit and stay with large.
    May 2015
    Sizing - Ripley v4
    Hi,
    I am about to order a Ripley v4 and I need help with sizing. Im 5' 8" (173cm) and I've always been on Medium bikes. My current bike has a 585mm top tube with a 73.5 STA and I use a 60mm stem. The ripley will be my first bike with a Steep STA and long top tube. Based on the sizing chart I am towards the end of the Medium size and at the beginning of the Large.
    Unfortunately I don't have the option to demo one of these bikes. But I rode a Large Yeti 4.5 briefly and it didn't feel too big and I also rode a medium Ripley v3 (in the parking lot) which seemed like a good fit as well.
    Can anyone help me determine which size I should get?
    edit: I spoke to Ibis and they recommended a Medium, but im not 100% convinced.
    Nov 2016
    At 5'8, I would go medium and use a 50mm stem as a starting point. The new M Ripley has a 603mm top tube (the L is 630mm), so with a 50mm it'll still feel a bit roomier than what you're riding now, and I'm sure the reach will be a lot longer as well. I think going to a L will be too big of a jump. The sizing hasn't really changed on these bikes despite the reach being increased by so much. To visualize this, picture the contact points (bars, saddle) staying in place and just sliding the bottom bracket back ~45mm, and you end up with the longer reach and steeper seat tube angle.
    Oct 2003
    I'm just over 5'8" and after demoing a large Ripley V4 and a medium Ripmo I ordered a medium Ripley. The large felt too long to me.
    Aug 2016
    Compare reach numbers and not ETT to see what stem you'll end up with... unless you're going to change where your saddle will be. My saddle is always at the same spot.
    May 2015
    Quote Originally Posted by wheelzqc View Post
    Would you still keep your saddle in the same position if the bike had a much steeper STA?
    May 2015
    I appreciate everyones advice so far. Thanks
    Iím not sure thatís right....you sort of need both. Reach is length while standing. Effective top tube is the closest approximation of length while sitting. Effective top tube is approximate because where you actually end up is dependent on the seat tube angle and seat height.
  1. 2018 Ibis Ripley GX vs. 2017 Ripley GX
    By dddfg44 in forum 29er Bikes
    Last Post: 06-28-2018, 04:53 AM
  2. Ripley sizing question
    By jeremyfire55 in forum Ibis
    Last Post: 12-03-2014, 03:04 AM
  3. Ripley Sizing help
    By GlazedHam in forum Ibis
    Last Post: 08-24-2014, 07:45 AM
  4. Ibis Ripley sizing question
    By Smilerz in forum Ibis
    Last Post: 05-24-2014, 05:16 AM
  5. Replies: 14
    Last Post: 01-24-2014, 12:17 PM
Members who have read this thread: 33
