Results 1 to 11 of 11
    Rp23 issue on new Mojo hd.
    I just assembled my new HD and the propedal lever has no effect on the bike.Has anyone had this problem? I'm used to my rp2 which has a huge effect.
    Don't have an HD, but if its a low compression tune RP23 (look for a three bar cellphone signal like icon on the body of the shock--if only one bar is filled in, its a low compression tune) there will be almost no perceptible difference when propedal is turned on. It's not needed anyhow.
    Just checked over the shock for the markings and couldn't find anything similar.The bike peddals really well for its weight so I'm beyond stoked.I was thinking if I needed to sell the shock all the settings should work.
    Dec 2009
    rp2 has lock out.
    Rp23 is only compression damping.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    RP23 on HD has a numeric setting, not the 3 bars. Yours should say 200, which I believe is a low setting.
    The PP lever on mine makes a difference, but it's a small one.
    holding back the darkness
    Reputation: subliminalshiver's Avatar
    Quote Originally Posted by d-bug
    Technically, the numeric value is the boost valve value.
    The compression tune is separate. I think.
    **** censorship
    aka dan51
    Mar 2005
    Quote Originally Posted by subliminalshiver
    hmmm, that sounds logical. I think this thread needs someone that actually knows...
    You are correct.
    But these guessing games are so fun, even when I am wrong.
    MTB Monkey
    Reputation: Jefe74's Avatar
    Mar 2006
    The rp23 has 3 propedal levels. The lever turns if on and off and the number in line with the lever is the setting. The dial at the pivot of the lever can be turned by lifting and turning it. If it is on 1, there may not be an obvious effect, but you should definitely feel 2 or 3. If not, then get your shop to check it.
    I talked to Fox and they said if your velocity tune sticker and rebound tune sticker have an "L" (for light) on them the shock pro ped. shouldn't have much effect.I'll try to get to a shop this weekend though.
  1. Fox RP23 issue
    By mrgto in forum Shocks and Suspension
    Last Post: 02-05-2010, 05:17 AM
  2. MOJO SL for XC - RP23 or RPL??
    By chpfly in forum Ibis
    Last Post: 12-10-2009, 08:13 PM
  3. RP23 or DHX Air 5 for a Mojo?
    By Murchman in forum Ibis
    Last Post: 07-13-2009, 11:13 AM
  4. Want a Mojo RP23
    By iheartbicycles in forum Ibis
    Last Post: 07-07-2009, 10:26 PM
  5. RP23 Issue
    By JPE in forum Shocks and Suspension
    Last Post: 01-25-2009, 08:48 PM
