Rock damage to V4 frame lower and higher pivot areas!?- Mtbr.com
Results 1 to 27 of 27
    Reputation: RooHarris's Avatar
    Similar to the Ripmo frame issues for rock damage, I have experienced a similar issue to the lower pivot area between seat tube and rear triangle after only 200 miles of riding.
    As both space are approximately 3/8" to 1/2", small chunks of rocks can get caught and wedged here and do some surprising damage to seat tube or rear triangle. It took me some effort to dislodge yesterday's chunk.
    I have seen nothing on the Ibis thread discussing preventative measures to alleviate this issue. What are you doing to mitigate this problem? Is Ibis even talking about this issue? If so, what are they doing to mitigate it?
    Thanks for you input. Please show your fix. Thanks!
    Rock damage to V4 frame lower and higher pivot areas!?-ibis_ripley_version_4.jpg
    Apr 2018
    there's info out there in main thread.
    one person designed a 3D printed guard.
    Ibis will send you a motofoam block that goes in front of lower link if you enter it in "Z-part" field on their Store site.
    Quote Originally Posted by FactoryMatt View Post
    Thanks Matt!
    sbd
    sbd is offline
    It's the same on a Ripmo and there is a lot of info for them as well.
    As well executed as these frames are Ibis need to come up with smarter design for these areas.
    Sent from my Moto Z (2) using Tapatalk
    Reputation: plummet's Avatar
    A cheap quick fix might be to cut, stretch and cable tie some inner tube around the section to prevent rocks getting in.
    Give it a go with a bit of old inner tube you have lieing around. You have nothing to loose.
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    Ibis has a newer solution to the lower link. Call or email them and they'll send it out.
    I'll post pics when I can. For the upper link they have it taped up. FWIW, I armored up both of those areas with 3M Mastic tape. Works great and keeps things well covered.
    - -benja- -
    Picture please.
    Quote Originally Posted by benja55 View Post
    Can you post a picture of your fix.
    I was unable to locate the field area on store site. "Z part" field was leading nowhere.
    Thanks,
    Dec 2008
    This. 3M 2228 Mastic tape has worked like a charm for over a year on my Ripmo, and looks pretty neat too.
    Apr 2018
    Quote Originally Posted by RooHarris View Post
    Thanks,
    just at the end of the parts section.
    Z Random Part – Ibis Cycles Online Store
    Too Much Fun
    Aug 2005
    Here is the stick-on flap piece that Ibis sent me (bends upwards) for my Ripmo, and you can also see the Mastic tape. I tape the shite out of all my bikes, hence I always get black, raw or darker colors.
    ...and here is an upper flap I fabd out of an inner tube and Mastic tape on the seat tube.
    - -benja- -
    Apr 2018
    where do you source that black tape? it looks great.
    thanks in advance.
    Thank you! I will endeavor to do this fix.
    Too Much Fun
    Aug 2005
    The thick rubber tape is the 3M Mastic stuff.
    https://www.amazon.com/3M-Scotch-Moi...809&psc=1&th=1
    I also have Invisiframe on other areas you can see in the pic.
    - -benja- -
    Apr 2018
    I C. 65mils 1.65mm is thicc!
    How are people finding the paintwork on the blue frame is holding up with invisiframe covering etc. Really love the blue but still a bit worried I will chip the hell out of it.
    Possible easy fix!
    I found some black, 3/8"X3/4" foam pipe insulation. The type you see in the hardware stores that are in 6' sections. I use this stuff for bike trunk racks to insure bikes don't rub against each other on long trips.
    Anyway, I cut two wedges, one for each pivot slot. Yesterdays twenty mile ride with lots of pivot action, the wedges stayed in place! Invisible as well. I even found a small rock sitting on top of the top wedge, and not affecting the area of concern.
    Cheap and easy fix! $1.79 at Home Depot per length.
    This is the stuff.
    Rock damage to V4 frame lower and higher pivot areas!?-black-m-d-building-products-foam-tapes-50150-64_1000.jpg
    The curve in the cut wedge section adds some staying power.
    Now, I'll go ride the hell out of it!
    Aug 2019
    Maybe I missed it, but is that Invisiframe on a Ripley V4? I didn't think they had come out with that kit yet. Or are those photos from a Ripmo?
    Too Much Fun
    Aug 2005
    Quote Originally Posted by The Prof View Post
    Those are on a Ripmo. I should have clarified that.
    - -benja- -
    sbd
    sbd is offline
    Roo do you have a pic of it installed?
    Foam wedges
    Quote Originally Posted by sbd View Post
    Sean,
    Here are the two wedges in place. Remarkably, they seem to be well positioned, secured enough not falling through the slots. I have tons of this stuff so if I lose one, I'll make another. First test results: Had one small pebble sitting on top of foam in top pivot after a 20 mile ride.
    Upper Pivot
    Lower Pivot:
    sbd
    sbd is offline
    Sean,
    Upper Pivot
    Lower Pivot:
    Looks good!
    Aug 2019
    Hey Roo, so are those foam pads just "resting" there? Not actually attached in any way?
    Foam wedges
    Correct. Just slid into place w/ no adhesives or taping. The curve of the foam seems to be enough to insure they stay put. We'll see over time.
    Tested perfectly this weekend! See report below...
    Be advised that both pivots should be protected. I have had rocks in both at different times.
    Jun 2019
    Roo, the pipe insulation is a great idea. FYI, I posted a photo of the motofoam Ibis provided for my Ripmo here:
    https://forums.mtbr.com/ibis/ripmo-r...l#post14195469
    I like that the pipe foam is readily/cheaply available.
    Field tested - POSITIVE!
    Quote Originally Posted by [email protected] View Post
    Just finished two days of all day rides guiding the Mendocino Ibis Migration here on the coast. Total distance was 56 miles w/ 7,000' of elevation gain. The two pipe foam wedges never budged one minimal iota! I think I have my solution now. My quads tell me another story...
  1. Replies: 29
    Last Post: 10-31-2019, 06:54 PM
  2. Replies: 19
    Last Post: 05-17-2015, 07:02 PM
  3. Replies: 10
    Last Post: 03-05-2015, 02:20 PM
  4. Replies: 5
    Last Post: 12-31-2013, 05:20 AM
  5. whats the difference between higher and lower end cranks?
    By potvinwannab in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-17-2007, 07:13 PM
Members who have read this thread: 4
