Ripmo/Ripley4 internal cable routing: greasing outer gear cable and brake housing?- Mtbr.com
Results 1 to 3 of 3
    Dec 2008
    I'm about to replace the brake and cable housing on my Ripmo, and noticed that the current housing (in particular the shift cable housing) seems to have almost seized inside the moulded cable channels due to grit getting in, creating a lot of friction between the cable housing and the frame. I'm therefore considering applying some grease to the outside of the cable housing (after cleaning the moulded channels as best I can) when installing the new housing. Has anyone tried this?
    Reputation: SoCal-Rider's Avatar
    I noticed that issue too and did grease my housing the last time I put on new cables. I have yet to replace them again, so I canít say if it helped or not.
    I used a bit of soapy water to help get them out. Also took the crank off and cut the housing there. Only issue was in the chainstay.
  1. Replies: 3
    Last Post: 07-15-2019, 05:57 PM
  2. Replies: 4
    Last Post: 01-02-2019, 02:46 PM
  3. Replies: 0
    Last Post: 09-27-2015, 08:34 AM
  4. Cable housing options for internal routing
    By sam-eye-am in forum Ventana
    Last Post: 10-27-2013, 05:41 PM
  5. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
Members who have read this thread: 7
