Ripmo - Anyone running a OneUp Dropper Post V2- Mtbr.com
Results 1 to 14 of 14
    Ride On!
    Reputation: NorCalTaz's Avatar
    Nov 2013
    I like the bike-yoke 160mm that came with my Ripmo. Wanted to get the 185mm, but forgot to specify it Anyway, I was looking around and seeing what else is out there and came across the OneUp Dropper Post V2 210mm, from the specs it looks like it will fit without a problem. Just curious what others experiences with them might be?
    Nov 2007
    I haven't run one myself, so can't comment on durablity directly compared to the Bike Yoke 180mm, but I've got friends who run them on other bikes and they're still going well.
    Compared to the BikeYoke, they don't feel quite as smooth on the drop or return, and the lever action isn't quite as nice. A bit more play compared to the BikeYoke also. The shimming won't be a concern on a Ripmo, as you've got plenty of room, but it was handy for one of my mates when he was a touch too short.
    Thing is, the OneUps are about half the price of the BikeYoke, so it's hard to go wrong if you're on a budget.
    Sep 2017
    I have a 210 on a large ripmo AF. Love it. Agree not as smooth as some posts, but super short and 210mm travel means it really has no competition for me.
    What is your question though? If you buy the appropriate diameter, of course it "fits". I don't understand. Do you mean is there enough seat tube length to slam the dropper down to the collar? If so, no - not quite. The actuator ends up at the cable port. But you can get within 10-20mm of slamming it. I have a 32 inch inseam on a large frame and I still have about 50mm of post showing. So it can accomodate pretty short legs.
    No Clue Crew
    Apr 2005
    I've run a couple OneUps on other bikes. They've both worked great for me, particularly when paired with a Wolftooth lever.
    I guess I'm not that particular about the "feel" of a dropper, as long as it continues to go up and down when I press the lever.
    Just like a raindrop, I was born to fall.
    Apr 2014
    210mm on Rip AF. Plenty of insertion depth available on the frame if that's what you're asking.
    Also own a fox transfer on another bike. It's operation is smoother as others have said, but the one up is fine. 210mm at half the price, shorter insertion depth, can adjust dropper speed with a shock pump, replaceable cartridge, can shim to perfect height etc... Seems like a winner to me.
    Ride On!
    Nov 2013
    Quote Originally Posted by kmj831 View Post
    Cool, my main concern is with the insertion depth. Agreed, 210 mm is well worth a bit of smoothness, which I am not too sure my ass would really care about as long as it is not going OTB
    Anyone know if the Bike Yoke actuator works with it ?
    Nov 2007
    Quote Originally Posted by NorthSideOf50 View Post
    The BikeYoke lever won't work, as the BikeYoke terminates the cable at the post end, whereas the OneUp terminates the cable at the lever end.
    Ride On!
    Nov 2013
    Quote Originally Posted by Isildur View Post
    Thanks for the info! I tried out dropping my current 160mm to simulate both a 185mm & 210mm. I was surprised to find that the post dropped at the 210mm level was too low for me. Felt like my knees were too low on the bottom end, the 185MM depth felt like a good fit. Right now I am still leaning towards the OneUp as I can set it to a more custom fit.
    Ride On!
    Nov 2013
    Pulled the trigger on the OneUp 210 mm, as others mentioned, not as smooth as the Bikeyoke, but it is the first time my ass has hit my back tire
    Isn't the Bike Yoke lever like the Wolf Tooth or PNW that works either way? I thought so.
    Sometimes cut and crimped both ends...
    Ride On!
    Nov 2013
    Quote Originally Posted by bikedrd View Post
    The BikeYoke remote worked fine, there is a set screw that holds the cable, just need to cap off the end. Not sure why, but my remote did not come with he set screw which is a M4 X 3mm, got mine at Lowes. I most likely will be getting the Wolftooth to clean up the cockpit.
    Nov 2007
    Ah, well there you go, good to know it does work both ways - I guess I hadn't looked close enough at my lever!
    Ride On!
    Nov 2013
    One Month Review
    Been riding a OneUp Dropper V2 now for about a month. Found it very easy to install and setup. Only thing that bothered me is that the action was not as smooth as I like. Followed some advice on another thread about taking it apart and lubing it with Slickoleum, just went out for my first ride and it is now buttery smooth, dang near as smooth as the BikeYoke dropper it replaced (wanted more travel).
    Instructions on how to do it can be found here:"https://vimeo.com/348913657" (not sure why it did not embed)
    The video is for the V1 dropper, but everything is the same except that there is not the o-ring in the actuator. If you have a OneUp Dropper, it is highly recommended to do this!
    Thanks for sharing.
  1. OneUp Dropper V2
    By OneUp in forum Components
    Last Post: 3 Days Ago, 07:46 PM
  2. OneUp dropper post
    By RS VR6 in forum Components
    Last Post: 3 Weeks Ago, 09:57 AM
  3. Oneup ISCG05 Chainguide on Ripmo
    By Chukwithak in forum Ibis
    Last Post: 03-03-2020, 01:57 PM
  4. Replies: 46
    Last Post: 02-10-2019, 08:43 AM
  5. Replies: 4
    Last Post: 01-02-2019, 02:46 PM
Members who have read this thread: 29
