Ripmo AF Thread- Mtbr.com
Page 1 of 6 12345 ... LastLast
Results 1 to 200 of 1152
Thread: Ripmo AF Thread
    Reputation: Velorangutan's Avatar
    Ripmo AF Thread
    These are showing up at dealers this week. I think this is a great idea to get a quality bike at a lower price point.
    • 29 Wheels
    • 160mm front travel
    • 147mm dw-link rear travel
    • 2.6 tire clearance
    • Aluminum front and rear triangle
    • Available in four sizes S-XL, fits riders between 5 and 66
    • Frame weight of 8.25lbs for a medium with a DVO topaz shock
    • Available with DVO JADE X coil shock
    • Progressive suspension leverage ratio for compatibility with select coil shocks.
    • Slack 64.9 head angle
    • 44mm Fork Offset
    • Steep 76 degree seat tube angle
    • Threaded BB (73mm BSA)
    • ISCG 05 Compatible with removable adapter
    • Port style Internal cable routing
    • 22oz bottles fit inside front triangle
    • Size M-XL compatible with 170mm+ droppers, 125-150mm for smalls
    • Molded rubber swing arm protectors
    • IGUS bushings in lower link, bearings in upper link
    • Metric 210x55 shock
    • 203mm max rotor size
    • 1x specific design
    • Boost spacing
    • Tapered headtube and steerer: ZS44 upper, ZS56 lower
    Ibis posted this last night.
    Reputation: vikb's Avatar
    Quote Originally Posted by Velorangutan View Post
    Selling a lower cost metal Ripmo is a great idea. Nice work Ibis.
    Hopefully that rider can save enough $$ with the lower price point to buy himself some elbow and knee pads.
    Safe riding,
    Vik
    www.vikapproved.com
    Feb 2018
    Wow
    Reputation: Vespasianus's Avatar
    This is an absolutely fantastic move by IBIS. A fantastic bike at an affordable price. Just brilliant.
    It is the Right of the People to Alter or to Abolish It.
    Jul 2014
    impressive, apparently the frame with shock(not sure which one) is 8.25...That's damn good.
    Oct 2010
    mmm. Orange is good.
    Jul 2019
    Can someone give me an idea of what a complete bike might weigh with an 8.25lb AL frame? Not a lot of manufacturers give out frame weights for AL bikes, so I'm not sure what to compare it to. Are we Talking 34+lbs like the new Hightower?
    Feb 2018
    Quote Originally Posted by Annadel Adam View Post
    2 lbs more than the carbon ripmo. my x01 with carbon wheels was 29.4lbs.
    Aug 2013
    https://reviews.mtbr.com/ibis-ripmo-...w-price-weight
    31.25 lbs GX/air shock build with carbon wheels, not sure which size. So like 31.75 with stock aluminum wheels.
    Jul 2014
    I believe there's a pic. on Pinkbike showing the SLX and GX builds at 31.8.
    Your bike sucks
    Reputation: Carl Mega's Avatar
    I think Ibis nailed it with this one. Quality coil - frame for $1899? Hats off.
    Working to stomp out redundancy, I repeat, working to stomp out redundancy.
    Carbon Ripmo frame is 6lb. People in the Ripmo build thread claim weights ranging from 28-31lbs for their carbon Ripmos, so figure 30-33 for the Ripmo AF.
    (My Ripmo GX with carbon 942 wheels and pedals is 29.5lbs FWIW).
    Soon if I am reading it correctly the coil compatibility is from a slightly different rear end lay out correct? So not possible to buy a new linage and make carbon Rip's coil compatible?
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Quote Originally Posted by groundskeeperwilly View Post
    I was wondering this too. Must have lowered the front shock mount slightly to get the increased progression and maybe tweaked the rear.
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    No Pavement Nation (NPN)
    Reputation: Undescended's Avatar
    Apr 2018
    Quote Originally Posted by Smokee300 View Post
    The 31.8 is the stem mount diameter for the handlebar...
    Reputation: johnD's Avatar
    I'm glad that Ibis recognizes the fact that not everyone is a dentist.
    The orange slx build is legit !
    2019 Trek Fuel EX 8
    Jul 2017
    I like the looks of this model better than the standard ripmo, especially the orange. The weights and price of the GX build sounds pretty impressive too. The mtbr review makes it sound like its a worse all-arounder with less sensitive suspension than the carbon ripmo, but its still pretty cool. I guess I like that they slackened it and made the suspension a bit more progressive which were changes people wished for in the standard carbon ripmo, so ibis listened to customers and made it better than the carbon ripmo in some ways.
    Its a bit too enduro for my riding but I like it, I believe these things will be pretty popular.
    No Clue Crew
    Apr 2005
    Man, I literally just sold my HT2 to come back to a Ripmo, which I bought last week. Not saying I would have waited, but the better head angle, excellent builds for the price and -- most importantly -- coil compatibility definitely pique my interest.
    Curious if there's a way to tweak the plastic version to take a coil.
    Just like a raindrop, I was born to fall.
    Quote Originally Posted by Blatant View Post
    Expensive, but MRP makes progressive springs for that sort of application. A Works Component headset should work [didn't check all the specs, but they make many models] for slacking out the other end.
    https://mrpbike.com/products/enduro-...e-coil-springs
    Safe riding,
    Vik
    www.vikapproved.com
    Jul 2017
    It depends on why you sold the HT2 to go back to the ripmo though, the HT2 is longer and slacker than the ripmo while the ripmo af is longer and slacker than the HT2. So if you went for the ripmo because its smaller/ more agile then the ripmo af is actually a worse choice for you than the HT2 was.
    No Clue Crew
    Apr 2005
    Yeah, I ran Works on my last Ripmo. I've understood that the MRP coils still aren't progressive enough for the Ripmo, but haven't really followed that line of argument.
    That may be true. I have no specific Ripmo info. It just seemed like it would be a workable option. MRP has been pretty responsive to questions for me. If that's something that seriously interests you I'm sure they give you an idea of whether it was likely to work.
    Safe riding,
    Vik
    www.vikapproved.com
    Mar 2019
    This is awesome! Just purchased a -1 works angleset for my ripmo lol and have been curious about running a coil. I'll be demoing one of these for sure, might end up replacing my carbon frame with this.
    Got rocks?
    Reputation: desertwheeler's Avatar
    Carbon is neat but Im a sucker for a well made metal beauty!
    May 2018
    Ext storia will work on a ripmo with a customized shim stack coupled with the hydraulic bottom out control you just have to pay the money.
    Mar 2019
    Quote Originally Posted by desertwheeler View Post
    me too, the raw aluminum looks great
    Quote Originally Posted by alsoran View Post
    true but that's probably another $1k, one could probably break even selling a carbon frame and buying an aluminum
    Way to go Ibis. This bike will be a killer!
    ...I only wish for the Ripley AF...oh when....
    May 2005
    Quote Originally Posted by yeti0200 View Post
    And then end up selling the aluminum version when the revised carbon version comes out in the spring. And the cycle continues.
    Jun 2019
    Where are they building these? Are they going to be sourced from vietnam?
    Aug 2019
    Who has experience with the DVO suspension? I feel like the NX build is the killer deal with the same suspension as the SLX or GX build.
    Oct 2014
    Quote Originally Posted by TheGenErik1 View Post
    Same thoughts I'm having... First time I've pondered a new bike in awhile.
    I know a buddy that just raves about the DVO Topaz. Bladder, super adjustable, serviceable at home. Overall they seem to have a good reputation, but I'd love to hear how a Diamond stacks up to a 36 or a Lyric.
    Jul 2014
    Interesting that the NX and GX have 32T rings but the SLX is 30T,
    Reputation: TahoeBC's Avatar
    Saw this getting built up, welds look good, great price point, I think ibis will sell a bunch of these
    Where's it made ?
    2019 Trek Fuel EX 8
    Aug 2019
    Taiwan ROC (there is a sticker on the seat tube above the top pivot point)
    Dec 2004
    I have a Hightower on order but this has me thinking. I wanted alloy to begin with but there were no options I liked. This though... What would "more progressive" ride like compared to the carbon ripmo? Would it just firm up faster through its stroke? The ripmos I demo'd were already what I'd call somewhat firm and not as plush or supple as some others.
    Rollin 29s
    Reputation: isleblue65's Avatar
    Ripmo AF Thread
    Quote Originally Posted by sfr4dr View Post
    The front tire sticks out further forward. One reviewer said the bike doesnt navigate tight switchbacks as well as the CF Ripmo, but descends with even more confidence. Climbing is just as good. Ripmo AF might be a better choice for a downhill focused rider. He also mentioned that the increased reach was noticeable.
    Whoever invented the bicycle deserves the thanks of humanity.
    - Lord Charles Beresford
    Apr 2014
    I do, though not on an Ibis. I bought a (first gen) Topaz for my Bronson V1 to replace the stock Fox Float CTD which I never really liked. The Topaz has been great. It improved the rear suspension feel tremendously and has been very reliable over the last few years.
    I haven't had to use it, but their customer service is also great. Lots of reports in the suspension threads from guys who emailed them and they helped them set up their shocks for their bikes/weights/trails/riding styles over email or the phone. I was actually pleased to see all these builds with DVO suspension as I suspect that they'll be popular and I've very much liked DVO as a company so far, both in product quality and service. I'm glad they'll be doing well.
    Jul 2014
    Quote Originally Posted by Heist30 View Post
    Im a dope.... My bad.
    Reputation: redmr2_man's Avatar
    I've had a sapphire and diamond, as well as a topaz rear. They make fantastic suspension.
    Reputation: JimmyC's Avatar
    Dec 2005
    I have a Sapphire on my Ripley V4...and a Diamond and Topaz on a Canfield Riot. I really enjoy the adjustability (I really like the OTT feature), reliability, and feel of DVO suspension. I have nothing against Fox suspension, but I have a strong preference for DVO suspension components.
    Aug 2019
    Thanks for the responses regarding the DVO suspension. I'm still torn bewtween the SC Hightower, Ripmo and Ripmo AF. Obviously the Ripmo AF saves me ~$1200 vs a similar build Ripmo and Hightower C.
    Aug 2015
    Longer reach than the same sized ripmo but a slacker HT? My head is hurting.... how?
    Quote Originally Posted by JDUBku View Post
    Stretch out the frame. You can make a Bike A longer than Bike B and still call both "mediums" within their respective line ups.
    Safe riding,
    Vik
    www.vikapproved.com
    Sep 2018
    34 lbs 12 oz with pedals, weighted at the shop today. NX Medium
    What does the carbon NX weigh?
    NedwannaB
    Reputation: JMac47's Avatar
    I just took it that you rounded up from the previously quoted 31.75. Hah! 😎
    Kinda liking this move from Ibis. Could be an economical alternative to get a longer travel bike and span the gap from my V1 Ripley.😎
    Ripley V1 XC/Gravel Adventure rig
    Marin Hawk Hill 2.5
    NedwannaB
    Quote Originally Posted by oghunt View Post
    But....what pedals is the question. 😁
    Marin Hawk Hill 2.5
    Quote Originally Posted by JMac47 View Post
    Same...Ripmo wasn't enough of a jump for me to spend the money to change out my RipleyLS. If they make a carbon version with this Geo or a HD5 29r I'm in.
    Sep 2018
    Raceface Chesters
    Quote Originally Posted by fiveo View Post
    Don't have any NX carbon builds in at the moment but will say my XO1 with i9 carbon hoops weighs over 33 lbs with pedals(mallets), cage, and tube ... running WTB Verdict up front and Vigilante(tough casing) out back. Ridiculously heavy tires for bike park season. Normally weighs just over 31 lbs
    Jun 2019
    Strangely the reach on the Ripmo AF only seems to be appreciably longer on the Medium (+12mm). Size Small has the same reach and L/XL are barely longer (+4mm and +2mm, respectively).
    Jul 2019
    Almost 35Lbs seems pretty heavy.. I'm coming from an AL Specialized hardtail thats 28Lbs though. Does the peddling efficiency on these modern bikes negate the weight penalty that newer bikes seem to have? Mostly fire road climbs over here.
    Dec 2004
    Well, HT2 and Ripmo AF now have almost the same wheelbase and head tube angle. Reviews have said the HT2 was a bit more stable than the carbon Ripmo so my guess is the Ripmo AF will now be about the same as the HT2. GX builds are $900 difference between the HT2 and AF.
    Aug 2019
    What pricing are you looking at with $800 difference.
    Dec 2004
    HT2 Carbon S (gx kit) is $5199 and Ripmo AF GX is $4299. $900 difference. Both prices off their own websites.
    NX cassette is a boat anchor , I'm sure the cranks aren't far behind.
    Wheels are probably pretty hefty also. Assegai tires , it all adds up.
    2019 Trek Fuel EX 8
    Aug 2019
    Why are you not comparing aluminum to aluminum? SC HT aluminum S (GX) is $4299 and a direct comparison to the Ripmo AF GX build.
    Turns out the Ripmo AF aluminum is pretty much the same weight as the HT aluminum. First reviews seemed to suggest the Ripmo AF was a couple pounds lighter but people have weighed and posted weights that match the HT aluminum bikes. I was about to buy a Carbon R build (NX) HT and thought the Ripmo AF NX for 2999 was the same weight. Thus I would save about $1300, but then real weight numbers showed up.
    Jul 2014
    If you're in the mood to commit to metal, this 2020 Commencal, looks like a very good value. https://www.commencalusa.com/meta-tr...ce-c2x29149178 I know it doesn't have super sophisticated linkage but......
    anybody purchase one yet?
    Dec 2004
    I was comparing those because like you, I originally thought they were about the same weight but now it sounds like they aren't. I have a HT2 C S on order which should be here this week. If the Ripmo AF SLX or GX is about the same weight, I'd be interested and willing to take a gamble on the DVO stuff, since I haven't ridden it before. If the Ripmo AF SLX or GX is 2 lbs heavier than the HT2 C S, then I'll stick with the HT2 C S since I know and like the Lyrik/SD, GX and codes.
    Assegai EXO+ adds 300-400g compared to Minions EXO. This is a gravity focused bike. But you easily drop 1lb or even 2lbs with tires (Rekon EXO, Bontrager XR3)
    My buddy picked his up last night. Hitting Moab in two weeks.
    Reputation: Rom3n's Avatar
    Jan 2014
    My custom build came in at 32 lbs fully loaded.
    Jun 2005
    Quote Originally Posted by Rom3n View Post
    Nice build. Is that with pedals? Specs? Any ride impressions?
  67. #67
    Jan 2014
    Quote Originally Posted by awr94903 View Post
    Yes that's with pedals. Taking it out for a setup ride this evening.
  68. #68
    Reputation: OldHouseMan's Avatar
    This is the bike I have been waiting for...Aluminum from a reputable comapny.
  69. #69
    Quote Originally Posted by OldHouseMan View Post
    And selling the frame only at a reasonable price.
  70. #70
    Rocks belong
    Wow. Full AXS build.
    These Ripmo AF's ain't gonna be light
    I like 'em long, low, slack and playful
  71. #71
    Jun 2018
    Just ordered two of these for my wife and I. Stoked beyond stoked.
    Sent from my SM-G965U using Tapatalk
  72. #72
    Jan 2014
    Quote Originally Posted by 06HokieMTB View Post
    They are going to be about 2 lbs more than a carbon version.
  73. #73
    Rocks belong
    Sorry, sounds like I was mis understood.
    Surprised his full AXS build isn't lighter
    However, life is too short to obsess over frame weight
  74. #74
    is the frame painted silver or is it raw aluminum?
  75. #75
    Rocks belong
    Quote Originally Posted by etacata View Post
    From every picture I can see, it looks painted
  76. #76
    Jan 2014
    full AXS is not a big weight savings. The remote dropper is heavier than most so the total savings over the stock GX groupset and dropper is maybe only a few hundred grams, add in the extra weight of my code rsc brakes over the stock shimano and you are talking about maybe half a pound difference. I think given that it's aluminum and the weight of this fork the total weight on this bike is where it should be.
  77. #77
    Jan 2014
    I'ts satin silver
  78. #78
    helluva bike , congrats !!
    2019 Trek Fuel EX 8
  79. #79
    Dec 2004
    For those that have one, where did you get it? One of my local shops has an orange nx large and said it was around 33 lbs. I'd want the silver frame only, slx complete or gx complete. Shop told me Ibis was showing mid Oct delivery for that. I'm going to call Jensen tomorrow to see what they have.
  80. #80
    Dec 2004
    I'ts satin silver
    But is it raw alloy (no paint) or is it painted? Personally I think they should bring back bead blasted anodized.
  81. #81
    call Fanatic bike shop.
    2019 Trek Fuel EX 8
  82. #82
    Such a sweet option to have on the market.
  83. #83
    check fanatic website , it says they have a few.
  84. #84
    I have a silver/coil frame on order from Jensen. Ship date is end of the month. Also checked with fanatic and they have same time line. What they had sold quick. Hopefully the restock date is true
  85. #85
    I agree
  86. #86
    I agree
  87. #87
    Aug 2019
    Shaun @ N+1 bikes had a few more in stock when I ordered mine.
  88. #88
    Apr 2014
    I'm really curious to see how this compares to the Fezzari La Sal Peak. I read a lot of reviews that described the bikes as similar with the LSP having a bit more confidence on the descents and the Ripmo being a bit livelier when pedaling. The geo changes on the AF bring it pretty darn close to the LSP, so I'm curious if they now ride even more similarly.
  89. #89
    Rocks belong
    Quote Originally Posted by MarcusBrody View Post
    The fit (especially during seated pedaling) will be waaaaay different though. The Ripmo/Ripmo AF is 1.5" longer in ETT than the La Sal Peak.
  90. #90
    Sep 2014
    Wow, I just looked at the LSP geo and the Medium has a 22.2" Top Tube! I know everybody only like to talk about Reach but dayum, that has to be a pain riding that thing while seated. It's not a DH bike, you're gonna be sitting a good chunk of the time.
    Ibis Ripmo
    Ibis Ripley V4
    Ibis Mojo HD5
    Pivot Mach 4SL
    Pivot LES SS (loaned out)
    A road bike
  91. #91
    Quote Originally Posted by BmanInTheD View Post
    A lot of people are putting areo bars on those bikes to stretch out when seated.
    Safe riding,
    Vik
    www.vikapproved.com
  92. #92
    Apr 2014
    The short TT does seem to be the most polarizing part of the LSP. I don't know if it would bother me or not, though. It is 13mm shorter than the TT on my current bike (an XL V1 Bronson). I have the seat slid up to steepen the STA a little bit, so I suspect that if I slid the LSP's back on the rails, it would be about the same, which is fine by me, if not long.
    I don't see nearly as much reason to go for the LSP now that the Ripmo AF is out, but I will wait for reviews to see if there is more difference than I'd expect.
  93. #93
    Rocks belong
    correct
    The Ripmo AF is right at the cusp of what I prefer for ETT. (635-640mm is my sweet spot)
  94. #94
    No Clue Crew
    Apr 2005
    Roman: I'd be interested in hearing your thoughts on the AF, particularly as a direct comparison to the stock plastic Ripmo. Also, do you have a consistent test loop there? HiLine? Hogs? Something else?
  95. #95
    Id also be curious as to how the bike does in Sedona. Particularly in the slow tech moves.
  96. #96
    Dec 2004
    I was able to score an AF GX build! It'll be here Monday. I'll post a full review later in the week. I've been on a quest all summer. Demo'd a lot of the latest bike, all on the same trail so can directly compare. I had a hightower on order for a month when I cancelled it yesterday. Bikes ridden were the enduro, ripmo, stumpy 27.5, mojo3, instinct bc, altitude, tracer, and bronson v3.
  97. #97
    Jun 2018
    Did you get to demo a ripmo af? If so how was it compared to others.
  98. #98
    Dec 2018
    I just got the NX build in orange for 3k out the door! They actually had it stickered for $3199. I will just say from initial impressions - very stoked!! You wouldn't know if was aluminum from a quick glance. Paint job is superb. And the orange color with the yellow/green accents from DVO along with the standard Maxxis Yellow all make for a sick looking bike. Got 2 comments already from pedaling around neighborhood. It's relatively heavy but pedaling it eased my apprehension. Even with the Assegai. It's my first DW though so maybe it's the platform. Can't imagine a better deal out there for 3k while supporting Cali and the local bike shop. Win! Will ride when it's not balls hot down here in SoCal.
  99. #99
    Jan 2014
    I like to take new bikes on a few trails here, one being Hiline. I got a good ride in on it today. The bike to me feels better with it's slacker HTA and more progressive suspension. The stock DVO suspension felt good and im just running the base settings with no fine tuning yet. I think this bike is a big winner for the price it's selling for and I think the stock build kits are solid. I will put some more miles on it over the next few weeks and play with setup more a bit.
    Video from my first ride, blew a tire at the end
    https://youtu.be/OBi_vrqyXtM
  100. #100
    Dec 2004
    Quote Originally Posted by Stickyface View Post
    No demo on the AF, just the regular Ripmo. Our shops wont offer AF demos until next summer.
    2020 Ripmo AF
  101. #101
    Apr 2018
    saw one at sports basement today. idk. it's definitely not a spesh aLU bike. it's not a stumpy evo. definitely budget built. gussets are a little jank to be honest. would make a great disposable racebike though.
    -still uses ti and ano alu fasteners, that's cool.
    -no internal routing in the swingarm
    -headangle is definitely 1+ degrees slacker
    -suspension felt good off the top. very supple.
    -cable bosses are standard china factory fare
    -i think the lower gusset on this one is off center? intentional?
    -no downtube guard, they're reallly shaving pennies on this thing.
  102. #102
    Nov 2007
    Quote Originally Posted by FactoryMatt View Post
    Wow, the small details on that bike look a bit cheap for sure. That gusset will be a dirt and mud trap, very strange for it to be off centre like that too.
    I guess in the end, for the price that's what you're going to get. Hopefully these are "first run" bikes and the later ones come out much cleaner.
    Of more interest though is the short travel whip possibly in the pipeline... Have a listen to the Bike Rumour podcast with Scott and Hans, there's a little snippet in there with sketchy detail, but definite hints. But that should be a different thread
  103. #103
    Apr 2018
    thx for the tip. will do. could be sick.
  104. #104
    Jan 2014
    Mine is off center to the NDS. This section above the BB would be nice if it was welded all the way around to keep it from collecting mud. My spesh alum evo was very clean but it's also about $600 more for similar spec as the AF. My evo also did not have a downtube protector which I think is almost a must these days.
  105. #105
    Downtube protectors are really only required on carbon frames.
  106. #106
    Jan 2014
    There are several companies that use downtube protectors on their aluminum frames. It might not crack like carbon but you can still F**K up aluminum with rock strikes.
  107. #107
    I wouldn't argue if Ibis wanted to stick a downtube protector on there, but I don't feel it is necessary.
  108. #108
    Rocks belong
    I feel like were splitting hairs here, no?
  109. #109
    Feb 2013
    The SLX build is actually a better bang for the buck choice over the GX.
    The cranks are better (and lighter) than Descendants and the SLX 7100 4-pot brakes will be superior to the Deores that come with the GX.
  110. #110
    Aug 2019
    Quote Originally Posted by Verbl Kint View Post
    GX comes with carbon bars.
  111. #111
    Aug 2019
    Which SB has them in stock to check out?
  112. #112
    Nov 2008
    I saw an orange one (XL I think?) and silver one (L) at the Berkeley SB a couple of days ago.
  113. #113
    Sep 2017
    Just picked mine up on saturday, hopefully will have it built by the middle of this week.
    I'm pretty stoked and I think the frame is nicely made, but I agree that bottom gusset is a bit of an exception to that and it looks like a bit of an afterthought. I also wonder if the cables are going to rattle like hell in the frame, I wish the cable ports actually clamped the cables.
    Otherwise really pumped. I felt both the ripmo and evil offering were awesome but too steep on the head angle side and could stand to be more progressive, oh, and less expensive. :-P Ripmo AF solves all of those issues so I am pumped.
    My build will be rough an X01 and a little lighter on the tire setup too so while I don't care too much I'm interested to see where the weight ends up.
  114. #114
    Apr 2018
    this was SB - presidio - in SF - it had some weird band on it like it was either being held or it was sold. IDK. was a GX build, not sure of size.
  115. #115
    with the og ripmo not able to run a coil I would have thought that the coil version would be popular but have only seen air shock versions. like to get a report on how the coil runs. only photos of a ripmo af coil are pics from ibis add. strange....
  116. #116
    I dont think the coil is available till end of October
  117. #117
    that's weird. were did you here that from? I have a colon order. date they gave me is 9_21
  118. #118
    Jun 2018
    Kinda seems like everyone's dealers are saying different things. I'd love for an ibis employee to read this thread and add input. I ordered mine and the dealer basically said "i have no idea when it will come".
  119. #119
    May 2005
    Not trying to be a downer, Im definitely an Ibis supporter (own a Ripmo), but when I look at the welds on a Knolly Fugi vs. the AF there simply is no comparison. Im sure the AF will hold up but the Knolly wins the eye test in every way.
  120. #120
    Dec 2018
    I'll take excellent build kits and mediocre welds any day. If I don't want to look at the metal work I'll go carbon. I'm fine with the trade-off. I think this bikes target audience will be ok with it. Hopefully the response is strong and we'll see the ripley go metal.
  121. #121
    gainlessly unemployed
    Reputation: Tame Ape's Avatar
    Saw at least two AFs on the floor at the Berkeley SB yesterday and they're going to have Demos soon too
  122. #122
    Jan 2014
    Quote Originally Posted by chowdapilot View Post
    The only area that is not visually appealing to me is the area above the BB. I think the fact that this frame is hundreds less than other alum frames and how good the bike rides will help some overlook minor cosmetic issues.
  123. #123
    I had a buddy buy one for his kid. He went down to sports basement the day before official release and said I want one. They had it in a box and said come back tomorrow morning and get it. Kid is super stoked!
    Demand is high and Ibis is testing to see if aluminum frames sell. Other frame s are sure to follow.
  124. #124
    Dec 2004
    I hate to say this but all these comments about the frame gusset are pretty funny. You guys certainly are particular! The carbon frame has a large bulge in the same spot. Not sure why they need anything there on either but there must be a reason. Overall, I like the looks well enough. In person, it has a pretty beefy, "ready to send it" look and not as sleek as the new Hightower or some others. I like it better than the carbon Ripmo colors. I just built mine up last night and am going for a shakedown ride after work. Initial feelings are, it will be a total steam roller. Maybe a bit slow on pedally stuff due to the heavy tires. I took it around the hood last night, including a couple short trails. It was almost dark out so didn't get too much time. Added weight over the carbon, assuming the same GX/Assegai build, should only be the fork and frame so maybe 2.3 lbs of non-rolling weight.
    2020 Ripmo AF
  125. #125
    Sep 2017
    Couldn't have said it better. Also got mine built yesterday. On initial pedalling around I was really surprised by how plush and solid it felt.
    When I rode the evil offering and standard ripmo, the felt capable enough but like they definitely had some clear limits at least at my skill level.
    Conversely when I rode the Pivot Firebird 29 it felt like an unstoppable battering ram of a bike.
    The Ripmo AF feels kinda in the middle between those two types of ride feels and for me that's a good thing.
    And also agree the gusset is easy to pick on but in the sum of its parts it's a great looking ride.
    Let us know how you like the assegais. Here in the pacific north west I don't think I want such a heavy, but not-sticky tire. For now I have an XR4/SE5 combo I will run until I decide what to do with them.
  126. #126
    Quote Originally Posted by KennyWatson View Post
    PNWet Assegai review with some interesting comments about casing and rubber compound options.
    https://nsmb.com/articles/maxxis-ass...o-tire-review/
    Safe riding,
    Vik
    www.vikapproved.com
  127. #127
    Apr 2014
    Thanks for the firsthand reports, guys! This is the first bike that I've considered upgrading to in a while, so I'm very curious as to how people end up liking them.
  128. #128
    Dec 2004
    Fwiw I rode with the whole Rocky Mountain EWS team when they were here a month ago and they all swore by the Assegai on the front. They did admit though, their mission isn't climbing speed!
  129. #129
    Jan 2014
    I think its currently the best front tire for aggressive riding but I run the Dissector on the rear.
  130. #130
    Jun 2018
    Got an email reply from ibis today. Ordered my ripmo af like two days after announcement and it wont be here until late October. Damn. Killing me.
  131. #131
    Feb 2018
    Quote Originally Posted by smoothmoose View Post
    That would be the DD version. The exo+ assegai is maybe 100g heavier than the stock DHF. To me that's like nothing.
  132. #132
    I have a pretty good amount of experience with their stuff. Figured it might be worth mentioning here since there will be a lot of first time DVOers. I've had 3 different Topaz shocks and one of their forks. I weigh 215ish and ride pretty natural terrain.
    For the Topaz, you have spacer adjustments on the positive and negative side that can be changed out without removing the shock (but make sure it's clean, you don't want dirt inside the air can). I suggest removing it and wiping it down really good, but you don't have to. You also have rebound and bladder pressure.
    On the spacers, the positive spacers work the same as others do by increasing progression. On the negative side, I honestly couldn't come up with a good explanation for how they work. It seems like it helps reduce the power the negative has, so it can help provide more support on the midstroke, while also reducing the amount of air pressure required for a given sag point. In other words, if you are blowing through the first 20-30% of the travel too easily, add a negative spacer. It may reduce small bump compliance, though. That's my interpretation, anyway, but could be wrong. I'm sure it also depends on the linkage, I've never run them on a dw bike.
    They also like faster rebound settings. I found returns from deep in the stroke kindof slower than I'd prefer, but at 215 and running fairly high air pressure, I kept the LSR adjuster fairly open. YMMV and the tune may be different. The bladder pressure has a valid range, I think 170-200psi, I would keep it around 185-200. If it drops too low, the bladder can collapse and cause problems that require a rebuild, which is really important to note for the winter time where temps fluctuate, so you'll want to stay on top of the bladder pressure.
    It's one of the smoothest shocks I've owned, very little stiction and very supple. I wish there were more damper adjustments, but they do feel great.
    On the fork, I didn't have a Diamond, but a Sapphire 34 which has a different stanchion diameter and slightly different airspring. I don't think it's that much different than the Diamond, but take if FWIW.
    The tuning page that DVO setup for Giant is really close to how I set mine up:
    http://tech.dvosuspension.com/wp-con...up-guide-2.pdf
    I found any HSC above ~10 clicks would cause spiking, but I did use most of the range of the LSC adjuster for different trails. The key with their forks is to get the spring set up right, I ran about 15% sag but had the OTT adjuster cranked in pretty far. That provided more support with some off the top sensitivity for small bump compliance.
    All their products can be rebuilt by the end user and they have great support. If you have any questions, they are real easy to get on the phone and are happy to help you walk through stuff, they are awesome to deal with.
  133. #133
    Sep 2017
    Weighed my size L build today at 33lbs even with Hope F20 pedals (which weigh just under 1lb).
    I'm good with that.
    Changes from "stock" are:
    X01 Cassette
    Bontrager Line 30 Comp wheelset (about 2100g)
    2.4 XR4 tire rear, 2.6 SE5 tire front
    Hope cranks and pedals.
    Magura Mt Trail Sport brakes (probably no weight diff there though)
    The hope cranks are nearly as heavy as NX and the wheelset is not light either.
    With carbon wheels and cranks you could probably save another 1-1.5lbs or so.
    I'd expect a total gucci build to tip the scales around 30lb without pedals. You won't get much lighter without installing wheels and tires that don't suit the intentions of the bike, IMO.
    First "real" ride tonight! Stoked.
  134. #134
    Am slow building mine after work at the shop. Everything looks as it should but damned if running internal housing is pain in the tuckus I tell you. Also the paint is thiccc. I had to use a metal screw driver to pry the NDS housing plates off the downtube.
  135. #135
    Apr 2014
    I'm good with that.
    X01 Cassette
    Thanks for this. So I imagine that an XL NX build would probably be a bit over 35 stock.
    I honestly don't even know what my current bike weighs, so whether it would be notable, I'm not sure.
  136. #136
    TL:dr - I wouldn't worry about the weight
    I've ridden similar capability bikes from just under 28lbs to 35lbs and the only time I really notice a significant difference is lifting the bike out of the truck. I have PR'd climbs and DHs on lighter and heavier bikes. I've taken my heavier bikes on epic alpine rides with no issues.
    I'm not saying there is no difference at all, but from a practical point of view a few pounds either way is not a big deal.
    Lighter bikes do accelerate a touch better, but they also get deflected off line easier and require more energy to control. Heavier bikes take a bit more effort to get going, but they also hold their line better and keep rolling a bit more easily in chunk. The end result is pretty much the same for recreational fun riding.
    Stuff like tires, suspension design and setup is way more important.
    To be fair I am ~195lbs ready to ride a strong rider - for a normal casual MTBer. If I was building a bike for my 120lbs GF I'd be a little more concerned with bike weight as it would matter more to her on a power to weight basis.
    Safe riding,
    Vik
    www.vikapproved.com
  137. #137
    Apr 2014
    Quote Originally Posted by vikb View Post
    I'm not super worried about it (I'm near your weight ready to ride). The AF is also a bit slacker than my current bike and I don't want my next bike to end up feeling more sluggish. I do take my everyday bike to the park, but most of the trails I ride, I'd be fine on a Ripley. So i'm just trying to get a sense of things. Thanks for the help!
    Really I should be patient and look for a demo tour next spring, but we shall see...
  138. #138
    Dec 2004
    First real ride last night. Had some clunking I thought was the fork and the found the headset was loose after the ride. It distracted me the whole time. First impressions are that it climbs great like any Ibis, rolls a bit slow due to the tires, corners and maneuvers amazingly, jumps great and is very easy to move in the air for a big bike, brakes/drivetrain/dropper are good and smooth, rear end is stiff laterally and suspension feels good but not dialed yet. We got some rain so given perfect dirt, I could still not believe the cornering traction I had. The limits were way higher than I expected and could barely reach them. The trail is my normal testing loop and has a good amount of jumps and doubles up to 2.5 bike lengths, berms, fast descending, great enduro bike test area. I over-jumped it several times. The bike just makes mole hills out of jumps. Seems like a total idiot could jump it. The rear end felt fairly supple but firm. Hard to describe but seems how all DW bikes I've been on. Mashed through some 1' rock clunk and it was pretty active and supple. Front end, I'm not sure yet. I need some more time on it.
    2020 Ripmo AF
  139. #139
    Jun 2018
    Thanks for the review! You're a hero to us all.
  140. #140
    Apr 2014
    Thanks for the review! Could you clarify a little bit: when you say that the bike makes mole hills out of jumps, you mean that it's poppy so it tends to clear their landing, correct? Not that it soaks up the take off transition?
  141. #141
    Dec 2004
    This particular trail, I ride all the time and have done all of my demos on this year, so I know the jumps very well. I overshot some probably because the bike carries a lot of speed and hides it well because it's so stable. It does have good pop and does not absorb the takeoffs. I did my usual compression at the bottom of each jump and there's good support to push against and create as much pop off the lip as you want. It did make the jumps feel smaller because it just handles them so easily.
    2020 Ripmo AF
  142. #142
    Apr 2014
    Awesome! Thanks.
    Maybe I missed it up thread, but what other bikes did you demo aside from the Hightower and how did they compare?
  143. #143
    Did anyone ever figure out if the silver is raw metal or silver paint?
    And what about the orange? It says the color is savina red. Is it more red or orange in person? Pictures make it look kind of orange.
    Raw frames are awesome, but orange is my favorite color.
  144. #144
    Jun 2018
    Quote Originally Posted by richulr View Post
    I'm pretty sure it's a silver paint. Anyone have one? I'm seeing one tomorrow so i can confirm. The red definitely looks orange to me.
  145. #145
    Aug 2019
    I'll be able to take a look once I open the giant box in my garage that arrived today. Will report back.
  146. #146
    Dec 2018
    more orange
  147. #147
    Apr 2018
    it's paint.
    Ibis needs some fresh blood in the cosmetics department. and/or start charging for custom colors like porsche does or SOMETHING.
  148. #148
    Aug 2019
    Just looked at mine, paint for sure.
  149. #149
    Apr 2014
    Great first ride reviews, they've got me pumped. My large orange frame arrives tomorrow. Hope to have it built up quick, and I'll post my ride reviews too.
    I did see two completes in the local shop before they sold (these things are not sitting long) and can confirm that the silver is PAINTED not raw.
    As to the Orange, it's what I would describe as an earthy orange, almost a rust maybe? It's kind of hard to describe, and it brightens noticeably in the sun, and looks kind of muted in darker lighting. It's not red, and it's not bright orange like the Transition Patrol or Orbea rallon. It's a darker, earthy orange. That probably didn't help, lol.
    "Slow is smooth, and smooth is fast."
    Real Estate Professionals llc.
    realestate-professionals.com
  150. #150
    Actually that helps a lot. I'm glad to hear it is more orange than red. I'd rather have a brighter orange, but I think this looks great too.
    I've always lusted after an Ibis bike. I thought the Mojo 26er was the sexiest bike back in the day, but I could never afford one. Now I am really thinking of selling my current bike, which i really love, to get a Ripmo AF.
  151. #151
    Dec 2004
    Awesome! Thanks.
    Wow, that would be a long answer. Older models I demo'd were a 2017 enduro and a 2017 tracer. 2019 bikes demo'd were the ripmo carbon, bronson v3, stumpy 27.5, mojo3, altitude, and instinct bc. All rides on the same trail. Any of these in particular you want to know about? I can PM you. The Bronson was my fave. So plush and dialed feeling. I wanted a "modern geo" 29er though. Ordered a 2020 Hightower C S and waited over a month for it. The Ripmo AF came out and I somewhat impulsively snagged it. I wanted alloy when I began my demos but there wasn't one I liked. Went for the AF over the Hightower due to ability to run a coil, more travel, room for a 2.6 rear, and 35mm rims. I'm still a little unsure if I did the right thing not getting the Hightower since the Bronson was so good and the HT is a 29er version of it. That's what I really wanted as of a week ago before the AF was released. Others high on my list were SB130 LR edition and the Offering. I'm getting some noise from my fork and what I think is cable noise inside the frame so that's stressing me out. Need to get that resolved before I can really feel good about the AF, otherwise it does ride awesome and I'm sure I'll get those issues sorted very soon.
  152. #152
    May 2005
    Pricing seems a bit odd, at least here in Europe: there is a 850 difference between the nx and slx version, when you can get an slx groupset for 450.
    Slx comes with a better dropper but still.
  153. #153
    Apr 2014
    Thanks! I'm actually on an older Bronson (though with an angleset and Topaz), so it's interesting to hear that was your favorite of the other bikes you rode. I'm kind of in the same boat as you. I overall like my bike, but am curious to try out a 29er on the rooty, rocky stuff I ride most often.
  154. #154
    Apr 2013
    Anyone seen a comparison between coil and air? Particulary interested in how much worse the pedal efficiency is with coil.
  155. #155
    ya, really wanting to here a coil review. my af frame with coil wont be in till mid Oct. hoping someone before then swaps out there air shock with a coil. maybe a rs super deluxe
  156. #156
    Does the AF have any kind of internal tunnels for the cables or are they just laying inside there? How is the perceived stiffness of the AF, especially the rear end, compared to the carbon?
  157. #157
    Sep 2017
    Got my first ride in yesterday!
    For context:
    I'm coming from a Bronson V2, and previously demoed the Offering and standard Ripmo as well as a very brief ride on a Firebird 29 (closer to a parking lot test).
    When I set the suspension up I got reasonable sag front and rear with about 10psi less than DVO baseline, and I rode with the compression wide open front and rear.
    For straight up plowing this setup was great, the bike is a monster truck. It feels like a much bigger bike than an Offering or standard ripmo. More of an enduro bike than a trail bike.
    I found the standard Ripmo and Offering very mild mannered and easy to ride on a variety of trails, but it was easy to bring them to the point of feeling overwhelmed on steep rough tracks. The AF feels more like I remember the firebird 29 feeling. Point and smash.
    The point and smash applies both up and down. It likes going up steep rough technical climbs as well. It's amazing how you can stand and mash the pedals and the rear suspension stays working, I really notice this coming from a previous gen VPP bike that is prone to hanging up on ledges.
    I found it pretty ground huggy and really easy to ride fast, great traction and rips corners (I think even better than the offering, and that bike corners great).
    I didn't find it very poppy or playful on milder terrain, or at the very least as i had it set up, to really jump little side hits and stuff you need to be going fast. But - as noted I did set the bike up pretty soft initially. Next I will try another 5-10 psi in the suspension and/or some more compression and do a ride on some more traversing trails and see if I can find a balance between pop and plow. I suspect I can since I erred on the plow side in the initial setup.
  158. #158
    Sep 2017
    Quote Originally Posted by swade View Post
    Nope, no tunnels. I was worried about rattling, I'm only one ride in but I didn't notice anything thus far, I will report if I do, for sure. I'm about 210 geared up and ride hard, as noted in my first impressions I think I had the bike set up a little soft which made stiffness a little hard to judge, but I can say the back end tracks really well when slapping a berm which is where I would typical expect to notice laterally stiffness.
  159. #159
    thanks for the review!
  160. #160
    Apr 2014
    Thanks for the review! How did it feel in comparison to the Bronson? I'll be eager to see what it's like with a few more PSI in, as I don't need a smash bike most of the time.
  161. #161
    Reputation: bikeboardorblade's Avatar
    FWIW, Amazon has insulated covers for hydration pack hoses for cheap that work well for quiting internal routing when there isn't cable guides.
    Sent from my Pixel 2 XL using Tapatalk
  162. #162
    Apr 2014
    Frame arrived! Here's a picture inside, where the frame has a more muted and reddish-orange look to it. The other picture is outside in natural sunlight and you can see that burnt orange or rust color.
    Maybe this will help in addition to the pictures posted above.
    Attached Thumbnails Attached Thumbnails Ripmo AF Thread-ripmo-natty-light.jpg
  163. #163
    Feb 2014
    Quote Originally Posted by spaniardclimber View Post
    US is worse. Difference is $1000 for NX and SLX when SLX group is less than $500 at full retail pricing.
  164. #164
    Jun 2018
    Just got mine today. Cancelled my order from LBS due to the immediate backorder status and called every shop within driving distance to find one. Ended up driving 5.5 hrs round trip. Could not be more stoked on it. I'll frame protect it tomorrow, ride over the weekend and report back.
  165. #165
    Just got my first ride in. Am coming off of a Ripley LS V2 with a -1d headset and a 140mm fork with 51mm offset. The AF was stable and heavy. So so heavy... Probably shouldn't have put that cushcore in the rear wheel...
    Anyhow, weight aside, I'm looking forward to dialling it in and getting some miles in Truckee/S.Tahoe before the snows come.
  166. #166
    Rocks belong
    Do the frame onlys come with a headset installed like in the pics on their website?
  167. #167
    No
  168. #168
    Will this not make a good trail bike?
    I have a short travel bike and got a long travel bike to compliment it. Turns out, I love riding the long travel bike on all kinds of trails. I don't get too much of a perceived downside even on tamer trails. I often would rather just be on the long travel bike than the short travel ride. I was thinking of selling my long travel bike and getting this in hope it would also be fun on all kinds of trails. Would those who have ridden it advise against this?
  169. #169
    Feb 2014
    Ibis are notorious for low bb which makes them super fun going down but up not so much. As an all arounder I would see if you can rent one to take out on your trails and see if it's for you.
    Sent from my ONEPLUS A6013 using Tapatalk
  170. #170
    Dec 2018
    What is your long travel trail bike? I would consider this a bit burly for a long travel trail bike due to tires, weight, head angle. This bike likes gravity. As has been mentioned in a few reviews, this is different from the original Ripmo. If your're not giving this bike gravity and/or jumps, it's going to get bored and maybe cumbersome feeling compared to something with a bit less travel and 66ish head angle. This thing wants to get rowdy, not just cruise relatively tame trails.
  171. #171
    Feb 2013
    True. However, note that the GX crankset weighs about 100g more than the Shimano SLX crankset, so the weight savings on a carbon bar are negated.
    Add the fact that the brakes are better and the RD has a better clutch, then the SLX is starting to look like an even better option.
  172. #172
    GX has a clutch.
  173. #173
    I was just contemplating the same question because I keep reading things like 'monster truck' and 'big bike'. I'm starting to think the plastic Ripmo might be a bit more versatile and trail worthy since it's lighter, shorter and steeper. When the Ripmo AF came out I was dead set on buying one because of the value. But the long wheel base and slack head angle might make some of my slower trails here in the Northeast feel a bit boring. I'm just speculating based on the geometry.
  174. #174
    Look at the HD4 numbers...I can tell you that it doesn't feel like a monster truck. Sure the larger wheels will add a bit. Overall it will be a great trail bike with a gravity focus.
    Of course the original Ripmo will be more versatile. If you're just ripping trails then a Ripley would be the best choice.
  175. #175
    Dec 2004
    I've been on two rides now on terrain that's just what this bike is for. Jackass/Yogi area for my fellow Truckee commenter in this thread. The bike is a bit slow of a climber but with the DW link, it's not bad and pedals very efficiently. I love how it climbs over and through rocks. Since the only things heavier than the same build carbon Ripmo are the frame 2.1 lbs and fork ~.25 lbs, the weight difference isn't much, and not rolling weight. Either bike with the Assegai front and rear is going to be a bit slow. The bike is big and long but riding, it doesn't really feel like it and the handling is nimble downhill and easy to toss from corner to corner. Awesome MTB on YouTube said this and I agree, it can be a burly trail bike as is, or you can do a lighter build and have a great all around trail bike for the alloy fans out there. I might toss on a faster rear tire at some point. I'm also getting some cable noise in the frame so plan on wrapping the cables in foam and I'm getting a clicking sound from the fork when it compresses from full extension. Hopefully I can sort that out with DVO.
    2020 Ripmo AF
  176. #176
    Quote Originally Posted by vicjoe View Post
    My current long travel bike is slacker and heavier than the AF. I have a Process 153 29er AL. I put a Durolux on it. It has a long crown to axel length, and ends up being a little over 170mm according to my measurements.I love the Durolux. Its fantastic. It has slackened the bike to having a 64 degree head angle. And I haven't noticed any negative side effects really.
    Its also a heavy beast, but so am I. I never notice the weight when pedalling. I tried the bike on some tame trails and loved it as much as my shorter travel bike. I dont really notice any disadvantages on it. I'm not an amazing rider popping off everything, although I wish I was. I'm a more of a go fast and monster truck everything kind of guy.
    But as I mentioned before. I've always wanted an Ibis. I'm really thinking of trying the AF. I figured with the DW Link it may feel even better than the Process. Am I thinking wrong?
  177. #177
    Ibis makes great bikes, but it sounds like you'll spend a bunch of money to end up pretty close to where you already are. Personally I wouldn't bother.
    Safe riding,
    Vik
    www.vikapproved.com
  178. #178
    Feb 2014
    Since you have a process 153 the Ibis is going to pedal worse. Going down it might be more fun but you going to hate going up.
  179. #179
    Quote Originally Posted by gus6464 View Post
    Huh? Ibis pedal worse than a 4 bar Kona?
  180. #180
    You can tie some zap straps around the cables and not cut them. They will suspend the cable housing inside the frame. Beleive DVO has a coil negative spring, so that might be what youre hearing.
  181. #181
    Dec 2018
    i've ridden the Kona 153 in aluminum. It pedaled worse than the Ripmo AF in my opinion. The Ripmo AF pedals well for what it is - a 34 pound enduro bike with downhill tires. Swap the tires and it will roll better. It's' not about climbing fast with this bike. It shouldn't be mentioned with the Ripleys and such. It gets the job done. But you shouldn't pick this bike if your focus is more on going up and not down.
  182. #182
    Apr 2014
    Quote Originally Posted by canuck_tacoma View Post
    Right?
    Ibis bikes peddle well. Kinda known for it. True that they tend towards the lower BB side, but still climb well. I'll have my AF frame built up shortly and my trails are ultra rocky. My other bike, a GG Smash, is on the higher side for BB's and is an excellent climber. We'll see how the Rip AF compares.
  183. #183
    Feb 2014
    Forgot this was the Ibis forum and that it's against the rules to say that anything in existence is better, my apologies.
  184. #184
    True that!! Lol.
    Ibis isn't perfect, has flaws...but it's pedaling isn't one of them.
  185. #185
    Apr 2018
    since you have a process 153 the ibis is going to pedal worse. Going down it might be more fun but you going to hate going up.
    Sent from my oneplus a6013 using tapatalk
    lol
  186. #186
    Apr 2014
    I've never owned an Ibis, and only currently own a frame sitting in a box. I love my GG, loved my GT, love Kona, which I know you're a fanboy of. Lots of good bikes. Ibis isn't perfect, I may not even keep this one long if I don't like it. I agreed with you that Ibis BB's are on the lower side and certainly lower than my personal preference dictates, but as I said, I also think you're overstating that case.
    But all of that said, Ibis bikes have been considered good, efficient peddlers and excellent climbers for a long time. I've ridden the ripmo a bunch and it climbs really well. Your claim that they don't peddle well and that a previous gen aluminum Process 153 out climbs the ripmo is just kinda silly, especially for one attempting to hurl accusations of bias at others.
    Your posts in the Kona forum are just as kool-aide drinking as anyone's here in the Ibis forum. I just happen to like both bikes, and there are several threads here where you can find me singing the Process bikes praises. Regardless of what I like though, I think exaggerated claims and subjective opinions stated as fact do no good.
  187. #187
    Apr 2018
  188. #188
    Feb 2014
    Quote Originally Posted by kmj831 View Post
    I drink no kool-aid. In fact I say that Kona build kits suck and that the Ripmo goes downhill better than the Kona. One for going up and another for going down so please point me to the kool-aid.
  189. #189
    Feb 2014
    Let's compare 2 bikes with 2 different wheel sizes because you can?
  190. #190
    Apr 2018
    the 29 is same or worse cuz.
    here's a 134. half inch less travel. still less AS. facts. who's the fan boy? i'm with you on the low BBs though.
  191. #191
    Apr 2014
    Right?
    I'll be eager to hear what you think. The Smash is another of the bikes that I have on my list as an eventual Bronson replacement.
  192. #192
    Aug 2019
    Finally got a chance to assemble and take this guy for a ride. Really liking the DVO suspension! Buttery smooth with great support.
  193. #193
    Does anyone have a base tune for the Topaz?
  194. #194
    Jun 2018
    Check out rider.dvosuspension.com or something like that
  195. #195
    I did. Could only find base tune for the Diamond.
  196. #196
    Aug 2019
    http://tech.dvosuspension.com/setup/topaz-2/
  197. #197
    May 2005
    Not against the rules. Ive owned many bikes including the process 111. Kona makes sick stuff but the DW Ripmo climbs better than any Kona Ive ever been on. The DW Ibis is amazing when climbing an I honestly have no idea where youre coming from. That said, each to their own and I value you option.
  198. #198
    Apr 2014
    What are you referring to when you say "base tune"? I'm coming from a moto/dirt bike background, and base tune usually refers to the shim/valve stack internally.
    But a lot of MTB guys seem to often use it to mean clicker settings, i.e. HSC/LSC and HSR/LSR settings, which is pretty simple on this shock given it only has 3 compression settings and on rebound circuit, right?
  199. #199
    Dec 2004
    Can anyone with a size large verify that it came with a 160 bike yoke? I have a 160 but was hoping it'd have a 185.
  200. #200
    Aug 2019
    My GX did, but I specifically asked for a 185.
  1. Replies: 10
    Last Post: 3 Weeks Ago, 09:46 PM
  2. Replies: 46
    Last Post: 02-10-2019, 08:43 AM
  3. Replies: 4
    Last Post: 01-02-2019, 02:46 PM
  4. AF Canyon Trails....OPEN!
    By tallsteve in forum Utah
    Last Post: 05-19-2012, 11:30 AM
  5. AF on coaster brakes!
    By stiingya in forum New Mexico
    Last Post: 12-03-2011, 06:47 PM
Members who have read this thread: 1192
