Ripley LS swingarm on a V1 frame?- Mtbr.com
Results 1 to 10 of 10
    NedwannaB
    Reputation: JMac47's Avatar
    They interchangable?
    Thx in advance.
    Ripley V1 XC/Gravel Adventure rig
    NORCO Fluid FS
    Salsa Timberjack
    Jan 2016
    call IBIS
    Reputation: Velodonata's Avatar
    May 2018
    Yes, if it is a V2 swingarm it will bolt up. The V2 clevis is slightly longer. The cable routing is different. But it can be done.
    NedwannaB
    Quote Originally Posted by pctloper View Post
    call IBIS
    Gee, thnx.
    NORCO Fluid FS
    Salsa Timberjack
    NedwannaB
    Thanks. So is v2 same as v1, but not LS version? I guess that's what I was really asking. I have a small frame just wondering if that would lengthen it out any and stabilize it abit. Thinking to put an angleset on it aswell.
    NORCO Fluid FS
    Salsa Timberjack
    May 2018
    There is no difference in the swingarms between regular V2 and LS versions, just the front triangle was changed for LS bikes. The differences in the swingarm from V1 to V2 were for tire clearance and cable routing. So if you have a V1 frame, changing to any V2 swingarm will only get you a little tire clearance, and make the cable routing a little awkward. If you have both versions of clevis you can see which one works best with the combination. But there is not really much benefit to the swapping swingarms overall. You would gain more from the angleset. You could also try a 44mm offset fork.
    Feb 2005
    V1 and first wave of V2 were not Boost...
    Quote Originally Posted by Pelly_NH View Post
    The LSV2 is boost and the whole pivot area is wider. Geometry is the same as the V1. The LS v1 might match up. Not sure why, what is the benefit? unless it is a fix for a crack?
    May 2018
    Quote Originally Posted by billb0872 View Post
    There is no V1 LS, and the pivot area didn't change until the V3. Anything pre V3 will bolt up, V3 only works on V3.
    Boost did become available during V2 production, that's something I didn't mention but obviously important depending on what OP is trying to do.
    NedwannaB
    Ok thanks for info. LS swingarm inquiry was off the cuff. Along with the angleset, I'm co templating a 34 SC fork if I go with upgrades on the v1 relic🙄. I think the SID on it is 51 offset. I'll look into what's offered in the Fox. I'll want to get it with offset that will work transferring to a newer bike in the future.
    NORCO Fluid FS
    Salsa Timberjack
  1. V1 vs LS Ripley as a distance machine?
    By WoodstockMTB in forum Ibis
    Last Post: 06-20-2017, 05:37 PM
  2. 5010 v1 to Bronson v1 frame
    By Juz1970 in forum Santa Cruz
    Last Post: 05-09-2016, 08:32 PM
  3. Replies: 22
    Last Post: 03-24-2016, 06:15 AM
  4. Replies: 48
    Last Post: 03-18-2016, 08:52 AM
