Results 1 to 10 of 10
    None
    Reputation: TheHamster's Avatar
    Need Latest Geometry for New Ti Mojo
    Hello,
    I am looking for geometry for medium sized Ti Mojo that was produced in 2009. It appears there is no information on the new Ibis website. Thanks for any help.
    Quote Originally Posted by TheHamster
    Hello,
    http://www.v3-2.ibiscycles.com/mount...mojo/geometry/
    H
    None
    Thanks, Hans. Can you tell me the approx. frame weight for a Medium?
    We are no longer in production FYI.
    Medium was about 1340 g / 3 lbs in it's most recent trim. Butted, tapered Ti!
    H
    None
    Thanks again. One last question--was it designed around a 100mm fork or 80mm? I have a chance to buy the frame and just trying to verify the specs.
    The geometry is designed around a mostly theoretical 90 mm fork. That way it works well with both 100 mm travel and 80 mm forks.
    H
    I have a similar question regarding the head angle of the Mojo - what axle to crown length results in the "standard" 69 head angle?
    From Colin, our engineer:
    A Fox 32 140 fork (510.9mm AC) with equal sized tires gives a head angle of 69.14. If you're like most people and run a slightly larger front tire you'd be right at 69 degrees.
    Cheers!
    Hans
    None
    So the 71ish head angle that is in the specifications for medium size is based on a 90mm fork? Usually, the head angle specs for recent hardtails are based on 100mm fork.
    @hans - thanks a lot! maybe you could include this number and the standover height in the geometry table on your homepage...
  1. Is the mojo a jumper? Geometry ?
    By ecibis in forum Ibis
    Last Post: 07-23-2010, 05:09 AM
  2. 1990's Ibis Mojo geometry
    By drtgirl in forum Vintage, Retro, Classic
    Last Post: 09-10-2009, 03:48 PM
  3. Mojo geometry with 130mm fork
    By bedell99 in forum Ibis
    Last Post: 12-03-2008, 12:41 AM
  4. Replies: 11
    Last Post: 07-27-2008, 07:33 PM
  5. Mojo Geometry / Axle to Crown
    By rug wheelie in forum Ibis
    Last Post: 05-19-2008, 06:56 AM
