KevinK
Mojo SL component questions about size!
Does anyone know the size of the Seat post clamp and the size/type of BB needed?
I'm pretty sure I know the next question to be Yes, but, just want to make sure. Can the Mojo SL accomodate a 135x10mm rear axle?
Thanks again,
Kevin
Thanks again,
Kevin
34.9 clamp size
BSA English thread 68mm width - trivia - BSA is Birmingham Small Arms
Yes, it can run 10mm rear axle
Thanks again,
Kevin
but i would recommend the stock ibis clamp because it is shaped to fit the frame. you're not going to save that much by using an ill-fitted clamp
KevinK
Thanks for the information Gram!
mx_599, I will keep that in mind. Thanks,
Kevin
- You may not post replies
- You may not edit your posts
Forum Rules
