Issue with S35 wheelset valvestems- Mtbr.com
Results 1 to 3 of 3
    Aug 2015
    I recently picked up my Ripley with the alloy S35 wheels (the bike is amazing!). I found a strange issue with the stock valves, which is that the threading on the main stem of the valve doesnít seem to be compatible with my hand pump (Crankbros Klic) or my sealant injector (Stans). In both cases, the diameter of the valve stem is just slightly too large for those things to thread on. Anyone else have this issue?
    I ordered a set of Muc Off valve stems, and Iíll install those today and see if they work properly.
    Oct 2019
    I haven't had any issue with my S35 wheel stems. I use a pneumatic inflator so thats not telling, however, i have had to use a screw on c02 inflator once on the trail without any issue. Also bought some blingy ano valve caps and they threaded on fine.
    Do you have the issue with both stems?
    Aug 2015
    Following up to confirm that the Muc Off valve stems work perfectly with the S35 rims. They come with a few different rubber seal options, but the default ones that are installed on the valve stem match the seals used on the Ibis valve stems. Threaded tools attach to the Muc Off valves just fine, but do not work on the Ibis valve stems.
  1. Ibis S35 carbon rims and "compliance"
    By DrewBird in forum Ibis
    Last Post: 02-19-2020, 07:25 PM
  2. S35 Alloy Wheels - Tubeless Ready?
    By jonlong in forum Ibis
    Last Post: 12-06-2019, 06:56 PM
  3. S35 carbon wheels de-tensioning
    By ADD in forum Ibis
    Last Post: 12-02-2019, 07:36 PM
  4. anyone running ibis s35 wheel set?
    By Dave Mac in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 09-13-2019, 05:24 PM
  5. Ibis S35 Rims/Wheels
    By WoodstockMTB in forum Wheels and Tires
    Last Post: 08-08-2019, 04:07 PM
Members who have read this thread: 45
