Ibis Traction Tune for aggresive riding (enduro racing)?- Mtbr.com
Results 1 to 8 of 8
    Reputation: javigutz's Avatar
    Hi
    Recently I saw the Ibis Ripmo V2 and the geo is perfect for me
    But I race and ride a lot on harsh terrain and i have a very aggresive riding
    So... How performs the Traction Tune for a aggresive rider? Do I need a revalve/shim?
    Mar 2017
    Quote Originally Posted by javigutz View Post
    Hi
    What are you on now and where are you racing/riding?
    Pretty sure the whole traction tune is just marketing. They've always had low compression and rebound tunes which is what traction tune is (for the rear shock). Question is will 147mm of travel be the limiting factor for you? Or are you more of a 160-170mm travel user like the firebird?
    Quote Originally Posted by eshew View Post
    I had a HD with Low/Low tune and I was maxed out on the rebound. My Ripley LS is Low Comp/Med Reb and I'm within 4 clicks of max on rebound.
    They've gone further and custom tuned a lighter HSC and Rebound on the fork too. For myself, I run my, non traction tune, Fox 36 with only a 5 clicks out.
    From what I've gathered the idea is to open up the circuits to speed the wheel up for the average rider. So if you're more aggressive and heavier, there maybe not enough range to close the circuits enough.
    Aug 2013
    How is slow rebound a desirable trait for aggressive riders? AFAIK pros run super fast rebound with more spring rate and/or compression damping, which would feel harsh to us mortals but hold up better when nuking world cup trails.
    I think the traction tune is a much better range of adjustment. Get the bike then see if it works for you before making expensive changes that can always be done later anyways. You might find that more psi and lower damping works too, just a different feeling.
    Dec 2004
    It might be worth checking out JKW and Pinkbike's reviews of the HD5. I believe they both felt the traction tune baseline settings left the bike feeling too loose and uncontrolled and they ended up slowing it down to more "traditional" settings. They said the tuning range was there so it wasn't a problem getting it where they wanted. I have my DVO almost fully open so the factory tune doesn't seem overly light even though it's supposed to be "traction tune" as well.
    2020 Ripmo AF
    Dude...
    Reputation: ebry74's Avatar
    If you don't like it, I'll trade you my X2 from my V1 and I'll take your traction tuned shock.
    I'll definitely chime in if i get a chance to demo Traction Tune. I'm 200pounds and ride fairly fast and aggressive trails. Canada, so the demos don't come through very often.
  1. Ibis Traction Tune
    By digev in forum Shocks and Suspension
    Last Post: 09-27-2019, 02:19 PM
  2. When is more traction, too much traction?
    By singletrackmack in forum General Discussion
    Last Post: 05-15-2017, 05:21 AM
  3. Replies: 0
    Last Post: 09-07-2013, 01:03 PM
  4. Which rim for the aggresive trail riding?
    By MTBAlex in forum Wheels and Tires
    Last Post: 09-13-2007, 07:56 AM
  5. Replies: 1
    Last Post: 01-08-2007, 07:23 AM
Members who have read this thread: 130
