Results 1 to 5 of 5
    Ibis Rear Hub-Potential issue??
    Can you guys check something out for me please? First pic is of the Ibis rear hub non-drive side. Second pic is drive side. The axle on the non-drive side has the silver knurled surface and the drive side does not. Is it supposed to? I suspect it does and think it has fallen off.
    Please check ASAP. Thanks.
    Attached Thumbnails Attached Thumbnails Ibis Rear Hub-Potential issue??-nondrive-side-hub.jpg
    it's OK
    Yup, that's normal.
    It needs the wrench flats on the drive side so you can get it apart but those flats make it very hard to put a knurled ring on it. Fortunately, because it's a through axle the knurling wouldn't be doing much anyways.
    Colin via Hans
    Thanks for the response. Yup, went to the lbs to double check this morning. Freaked out there for a minute. Had some play and thought this may have been the cause.
    bike rider
    Reputation: Lelandjt's Avatar
    What hub is that?
    Keep the Country country.
    Quote Originally Posted by Lelandjt
    What hub is that?
    They are Ibis hubs. OEM is Joytech I believe.
