Results 1 to 6 of 6
    Ibis Mojo SL DT EXC 150 & EX 1750
    Hey Folks,
    Sweeeeeeeeeeeeeeeeeeeet!!
    Matt Scott
    That looks great!
    That's a beautiful bike Matt! How much does it weigh? Do you have a ride report on the EXC 150 for us? I haven't found any reviews on it.
    -Ryan
    Hey Ryan,
    Comes in at around 11.68kg. I've got to give 20 hours or so to bed in the fork bushings. So far the launch control is very cool, being able to drop it down to 4" by just pressing down the red rebound adjuster and pushing down on the bars.
    Cheers
    Matt Scott
    Reputation: BlueMountain's Avatar
    Nov 2006
    Beautiful setup! You will have to give us the low-down on the fork and all the details such as:
    Weight and features
    Plushness and damping
    Comparison to anything else you have owned
    Quote Originally Posted by BlueMountain
    Weight and features
    Travel 150mm
    1695g (with thru bolt)
    32mm Stanctions
    Hollow Carbon Arch, Carbon Tubes, Magnesium Dropouts
    Linear Air Spring with Coil Neg Spring
    Adjustments:
    Air Pressure
    Rebound
    Compression
    Launch Control
    IS Disc Mounts
    Ride Height 525mm
    I need a few more rides to get the new setup dialed.......
    Matt Scott
