Help dismounting X2 shock off of HD3- Mtbr.com
    Jul 2014
    Need to send the shock in for service, but can't dismount it from the front eyelet. As far as I know, there's a pin inside, but I can't get it out. Any suggestions? Thank you !!!
    Attached Thumbnails Attached Thumbnails Help dismounting X2 shock off of HD3-img_7750.jpg
    Mar 2016
    Use a ratchet with 5mm allen while applying slight pressure on the bolt from the opposite side with a small screw driver or pick. I found that I have to rotate the ratchet pretty quickly to get the bolt to come out.
    Ride, Race, Live
    Reputation: Mick-e's Avatar
    Apr 2017
    There's cap head bolts on both sides.
    remove one bolt completely
    Remove the other bolt partially, maybe 3/4 of the way.
    Insert the 4mm allen key, tool, socket etc and gently tap with a hammer until bolt head makes contact
    You should be able to grab the other side and pull it out, but if not
    push the remain bolt out with an allen key
    Jul 2014
    Thank you @fisherk. The spin'n'push method did the trick.
    Thank y'all for the suggestions.
  1. Replies: 14
    Last Post: 07-04-2016, 01:28 PM
  2. Tire Dismounting Horrors
    By myitch in forum Wheels and Tires
    Last Post: 07-03-2014, 05:35 AM
  3. newb needs help mounting and dismounting. also scared to fall.
    By mdsniper7 in forum Beginner's Corner
    Last Post: 04-23-2013, 03:04 PM
  4. Cramping is calf when mountain/dismounting
    By Yanner in forum XC Racing and Training
    Last Post: 06-22-2007, 07:55 AM
  5. CX mounting and dismounting techniques
    By porterjack in forum XC Racing and Training
    Last Post: 03-24-2005, 07:33 PM
Members who have read this thread: 18
