Results 1 to 10 of 10
    Headset Installation - Mojo **Fixed now. Thanks
    Hello. I just got an 08 Mojo frame. The headset I am trying to put in is an FSA Orbit IS. I'm having a little trouble with the installation. I've got the race on and bottom bearing. When I put the top bearing on the fork, it wants to slide all the way down the headtube (even with the compression ring on) until it touches the bottom one. I was finally able to get it to stay up top, but I don't know how reliable it is going to be when I'm riding. It seems like there should be a lip or something that prevents it from sliding all the way down. Supposedly, this headset was used in this frame before, so I don't think I've got the wrong size. Am I just missing something? Or do I maybe have the wrong size headset? Thanks.
    Sam
    pics??
    I can post some tonight if that will help.
    Dec 2005
    Quote Originally Posted by RotarySam
    Sam
    huh? i think i am missing something
    mx
    sure would... cos what you're describing doesn't add up..
    Ok. I figured it out. The frame was shipped with some plastic plugs covering the top and bottom of the headtube. I just looked at the plugs, and one of them had pulled the metal sleeve out with it that goes on the top of the headtube. That metal sleeve holds the top part of the headset up. That is why it was just sliding down to the bottom. So, I WAS missing something.. haha. All is good now. Thanks for your time.
    [08 Ibis Mojo Carbon]
    Dec 2005
    have fun assembling your new bike!
    mx
    HOLD UP COWBOY!!!
    It is a Mojo Classic or SL you're building up...
    It sounds like a Classic, cos the SL has carbon races. That "metal lug" sounds like the upper bearing race. It's meant to be bonded to the headtube.
    You'd better give Ibis a call and have a chat to them..
    Quote Originally Posted by littlejohn
    HOLD UP COWBOY!!!
    It's a regular Mojo. Yeah, I know it's supposed to be bonded to the headtube. I took care of it. I'm not worried.
    jbweld to the rescue !
    http://jbweld.net/index.php
