Results 1 to 6 of 6
Thread: Head Set Creek
    Head Set Creek
    I know it's been discussed before, and yes my cables are clean and lubed.
    I'm 96% sure it is the Headset.
    Question, I went from 6 n-m torque on the bearings (IS-1) to 7 n-m and it seamed to help.
    Does anyone know the safe torque on the hs
    Mojo
    DIRT DART
    Reputation: b-40's Avatar
    i had the same problem and i just used 1 rap of that Teflon pipe tape around the outside of the upper and lower bearings and Viola no more creaking it's lasted me over a year so far.
    Quote Originally Posted by b-40
    That's a neat idea, i'll have to try it. Only one wrap not 2?
    Do you use a torque wrench or just feel, for hs bearing tightnenss?
    Mojo
    DIRT DART
    Quote Originally Posted by Mojo Man
    Mojo
    if i remember it was only like 1 - 1 1/2 wrap, and i just snug it up by feel and then tighten up the stem clamp.
    Reputation: wykes's Avatar
    I've got definite movement and noise, not a creek, more of a knocking even with lots if bolt tension. I'll try the tape too, thanks!
    Duhhh, it was simply that the top spacer was a smidgen too short, problem solved, headset set, mojo sl complete, photos coming soon.
