HD3 Shock Mount Question- Mtbr.com
Results 1 to 6 of 6
    Jan 2016
    Hi everyone- I have a 2016 HD3 that I keep well maintained. Just went through my rear shock and replaced the polymer DU bushings and the Upper Shock Mount shaft and hardware that mounts the shock to the frame. The shock is the stock Fox Factory Float DPS 3pos w/Adj and EVOL Sleeve with Kashima Coat.
    I put suspension grease on the small shaft when I mount through the shock and to the frame. I am also coat the exposed edges of the DU bushing with grease then slide the shock into the frame and assemble hardware. Using anti-seize on the hardware itself and washer. After several hours of riding I get the sqeaky/creaky noise back from this area.
    Any suggestions?
    Reputation: fresh tracks's Avatar
    Feb 2005
    Quote Originally Posted by Steve_MTB_22 View Post
    Any suggestions?
    What are you torquing the hardware up to? Ibis updated the torque specs from 7 to 10 nm on the front hardware. Also make sure the bolts on both sides of the hardware are torqued directly, even though you're stopping both of them turning as you torque one side. Otherwise you might find you're a little low in torque on the side you're not using the torque wrench on.
    Hope this helps
    Jan 2016
    Quote Originally Posted by fresh tracks View Post
    Hope this helps
    Great input. Cleaned everything up and torqued to the new spec. Hopefully this resolves this issue. I was definately in the 4-5 nm range. Also printed out the latest torque sheet from IBIS website for my shop. Thank you.
    Jan 2016
    Fresh Tracks your recommendation was spot on and resolved the issue. Wish I knew this 3 1/2 years ago! Thank you!
    Feb 2005
    You're welcome!
    It solved my creaking issue. Glad it did the same for you.
    Ride, Race, Live
    Reputation: Mick-e's Avatar
    Apr 2017
    Oh brother I’m with you.
    Earlier this year I broke my Hd3.
    When I went to the Ibis factory to exchange my HD3 for an HD4 I told the tech of my chasing creaking stories. I got the “did you hear about the updated torque specs to address creaking”
    Literally as I handed him my HD3 frame in a dead pan voice “thanks” I said. In my head “that would have been good to know last,year”
    ug :facepalm
  1. HD3 180mm rear rotor what mount?
    By Joel Fitzgerald in forum Ibis
    Last Post: 08-05-2018, 08:48 PM
  2. HD3 - Creaky upper shock mount
    By Mick-e in forum Ibis
    Last Post: 07-02-2018, 09:13 AM
  3. HD3 bottom bracket spacers with iscg mount
    Last Post: 09-23-2017, 06:05 AM
  4. Edit: Dumb question, nevermind
    By trhoppe in forum Shocks and Suspension
    Last Post: 08-11-2014, 06:38 AM
  5. Marin Mount Vision shock mount - what size?
    By rekrutacja in forum Marin
    Last Post: 05-16-2012, 06:28 AM
