Results 1 to 13 of 13
    Nov 2008
    Can Creek angelset on mojo sl
    I would like to try a 68 head angle on my sl...will it be possible to use the new can creek angleset?
    Tal
    meh
    Reputation: clewttu's Avatar
    no, mojo sl has a 1-1/8" head tube
    Nov 2008
    On CK site there is this model...ZS49 — ZS49/30, wouldn't that fit?
    http://www.canecreek.com/AngleSet
    http://www.canecreek.com/AngleSet?config=ZS49-ZS49
    Tal
    Nope. That's for a straight 1.5 head tube, not 1-1/8 like the SL.
    meh
    where its showing the 1-1/8 on those models on cane creeks website, its referring to the forks steerer tube, not the bikes head tube
    Mojo0115
    looks like definitely just 1.5" or tapered to 1.5" head tubes.
    Cane Creek AngleSet AngleSet ZS49 ZS49/30
    (Fits 49mm [1.5" Traditional] ID head-tubes 1-1/8" Straight Steerer)
    Cane Creek AngleSet AngleSet ZS44 ZS49/30
    (Fits tapered head-tubes 44mm [1-1/8" Zero Stack] ID top, 49mm [1.5" Traditional] ID bottom - 1-1/8" Straight Steerer)
    Cane Creek AngleSet AngleSet ZS44 ZS56/30
    (Fits tapered head-tubes 44mm [1-1/8" Zero Stack] ID top, 56mm [1.5" Zero Stack] ID bottom - 1-1/8" Straight Steerer)
    Nov 2008
    Thanks,
    maybe future models...
    Tal
    Clyde
    Reputation: LuckySomer's Avatar
    A way to get a similar affect would be to put a fork on the SL that has a great A2C like a Fox Float 36. That would get you pretty close to 68 degree HA
    09 Ibis Mojo - All Mountain Moab Edition
    Quote Originally Posted by Tal Kadouri
    Thanks,
    Yep, if future moj models have tapered head tubes. But remember only 1&1/8 steer tubes cause you gotta have room in there to do the angle, so you sacrifice the tapered steer stiffness option for the ability to change headset angle.
    (worth it to me on certain bikes.) Hopefully we will someday have the same model forks with more offset options with different axles to crown heights for different size bikes. IE size large or medium Talas etc. Along with angle headangle seatangle options thru different size frames.
    yea right !
    Actually, I would love to try a steeper head angle on my 650b moj.
    I see CC started making a XX 44 headset that's intended to enable the use of a tapered steerer on a 1-1/8 bike. Although this would not enable the use of a angleset, WOULD it enable an SL to take a tapered fork?
    TA
    meh
    looks to be for zerostack head tubes, not integrated
    screamer
    Reputation: budgie's Avatar
    why make it so complicated?
    2.2 rear tire, 2.4 front, 30% shock sag. Hey, presto: 68 degrees!
    On heavy rotation: White Lung: Deep Fantasy
    Unpredictable
    Reputation: Ridnparadise's Avatar
    Even less complicated - bend the forks at the steerer and get that genuine Mojo chopper look.
