Best adhesive for Chainstay Protector- Mtbr.com
Results 1 to 8 of 8
    Ride On!
    Reputation: NorCalTaz's Avatar
    Nov 2013
    I noticed while cleaning my Ripmo that the chainstay protector is starting to separate near the front. I am cautious about which adhesive to use that will fit the bill and not hurt the carbon. I am hoping that Ibis will eventually make them available in the store
    Oct 2016
    Either helicopter tape, or I prefer rubber mastic tape for chainstays.
    Shoe goo works well.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    any thin doublesided clear stuff...3m preferably
    you won't hurt crabon with anything you can find on a roll
    use a smear of lexel if you can find it...the only issue with lexel is cure time...you'll
    need to wrap or tape down what you are sticking, --for 3 days straight--, for proper lexel cure that will stand up to bike duty and hits (lexel can be peeled off later if you want to remove it, but cured properly will hold that protector down hard)
    adhesive in jars, tubes, or bottles, stay away from those,
    or you'll need to investigate the solvent carrier vs yer crabon bits
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Jul 2019
    Quote Originally Posted by NorthSideOf50 View Post
    My protector came off off my ripley4. I contacted ibis & they recommended a permatex weatherstrip adhesive as they couldn't send out a replacement. Here's the response from chuck & the link they sent to amazon & the permatex stuff. I ended up getting a replacement that has stuck on thus far so did not end up trying the permatex.
    "We don't have any replacements for those, but we hope to at some point. The best thing to do now is get some weatherstrip adhesive and reattach it. Super quick job. Something like this.
    https://www.amazon.com/Permatex-8185...RED9F79G4TQD5M
    Chuck Chuck Ibis, Customer Service, Ibis Cycles 2240 Delaware Ave, Santa Cruz, CA 95060 tel: (831) 461-1435 | Call us, we pick up.[/I] "
    Reputation: RSAmerica's Avatar
    Get it at Home Depot, high strength mounting tape, the outdoor gray stuff is better. I have also used it to remount the stainless steel chain stay protector.
    Ride On!
    Nov 2013
    Quote Originally Posted by nebio View Post
    Thanks, everyone for the responses. Thinking I will give this a go for now as it is only separating about an inch from the chainstay.
    Reputation: Velodonata's Avatar
    May 2018
    That's the best move, I tried all of the above and the Permatex works much better than 2 sided tape in this application. I have a variety of very good tapes, but the rubber material just doesn't adhere to the tape well enough in this case, where the weatherstrip adhesive is so far working great. It is significantly more of a messy PITA to apply, though.
  1. best adhesive for chainstay protector
    By blutow in forum General Discussion
    Last Post: 04-08-2019, 01:25 PM
  2. Best Lubricant/Adhesive to use for Czar build
    By TheHamster in forum Turner
    Last Post: 12-19-2016, 08:17 PM
  3. Contour adhesive mounts
    By John K. in forum Videos and POV Cameras
    Last Post: 11-01-2011, 08:15 PM
  4. Replies: 6
    Last Post: 10-16-2011, 05:09 PM
  5. Clear, protective adhesive sheet
    By Wheelspeed in forum Cars and Bike Racks
    Last Post: 03-02-2011, 05:29 AM
Members who have read this thread: 12
