928 Carbon Wheelset, front hub Boost Caps- Mtbr.com
Results 1 to 3 of 3
    I have Googles this with no clear win.
    I have a 2 y/o set of Ibis Carbon 928 wheels. The rear hub is a DT Swiss rear hub and a black "Ibis" front hub.
    I want to convert my wheelset to Boost using corrected end caps. I have the adapter kit with spacers but that is just not going to cut it. The rear hub converted very nicely with proper DT caps. I have no idea who really made the front hub. I called Ibis a few weeks ago and the guy that answered said he did not know. Any idea?
    Thanks in advance!
    This comes up every so often, but here is the answer. There is no kit for converting the hubs other than the spacers which you have used and are a pain.
    The hub on my 928 wheels was from Speedtuned I think. Your best option is to either sell the wheel or swap the hub. DT Swiss 350 is a good option, but you'll need to check spoke length.
    Sad face but thank you. I have a call into Speedtuned to varify what I have and to see if they have conversion caps.
  1. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  2. Boost to non-boost for SRAM 716 15x110 front hub?
    By Doug in forum Wheels and Tires
    Last Post: 10-12-2017, 05:18 PM
  3. Replies: 40
    Last Post: 04-23-2015, 01:50 AM
  4. Ibis 928 vs 941 wheelset upgrade
    By Alias530 in forum Ibis
    Last Post: 03-28-2015, 10:44 AM
  5. Ibis 928 vs 941 wheelset upgrade
    By Alias530 in forum Wheels and Tires
    Last Post: 02-15-2015, 10:59 AM
