Results 1 to 7 of 7
    Reputation: bedell99's Avatar
    2009 Ibis Mojo Part Spec's
    Any new infomation on the 09 part specifcations for the new mojo's? I'm thinking about converting after trying an 08 Ibis. I can actually say it is the best bike I have ever ridden.
    In the next coming days, I 'm going to do a complete review between the Yeti 575 and Ibis Mojo
    Erik
    Reputation: critterdesign's Avatar
    The 2009 Specifications are out! Check out the Ibis site. Does anyone know if they changed anything other than some of the parts? What are your thoughts?
    The new X9 kit looks fine. In 2009 you get Ibis grips as well:
    Ibis Foam grip with clamp / Ibis laser logo. Made by ODI?
    KevinK
    The new 09 Fox RP23 is so much improved, you now can get full range. It's so good, that, the only real advantage the DT has is, weight. I'd like to hear a comparison to the new 09 RP23 vs. the DT swiss Carbon. RP23 are standard on all SL builds, even the WTF. DT is a premium.
    Kevin
    The MTB Lab
    Reputation: pastajet's Avatar
    I will have something out for a shootout between the 09 RP23 and the DT Swiss
    KevinK
    Quote Originally Posted by pastajet
    I eagerly anticipate your test results. With Hans talking up the RP23 so much, my curious is past peak, and is overflowing.
    Thanks again,
    Kevin
    I saw Ibis spec build, it looks like the Mojo will be more affordable
    07 Giant Anthem 2 (Int'l Edition) | omartan.co.cc
    Im a MOJO Fanboy
