170mm Fork on Ripmo?- Mtbr.com
Results 1 to 17 of 17
    Anyone running a 170mm fork on their Ripmo?
    I have heard that this is how Robin Wallner runs his race bike and I think it would bring the bike more or less totally in line with who I want it to be - slightly slacker, bit higher BB but not loosing too much on the STA.
    Reputation: philstone's Avatar
    Mar 2011
    Yep, running a 170 36. Also have a 160 with the Grip damper. There is a slight difference, but not massive. Still handles and climbs well with the 170.
    #bleedblackdieevil
    Oct 2012
    170 also here. No issue about it Just +++
    Dec 2008
    When I asked Ibis if they had some off-the-shelf geometry numbers for the Ripmo @170, was told by Chuck himself to keep the max front travel on the Ripmo to 160mm. So it would seem that 170 is not encouraged by Ibis.
    Oct 2012
    Quote Originally Posted by Crossmaxx View Post
    Yea thats why Robin Walner runs it on his ripmo! Noone can not be as him!
    Nov 2014
    Unless he's changed since Feb, Robin is running 160mm with an angle set. He said he feels the 170 would not be balanced with the 145 rear.
    Oct 2012
    which makes almost same numbers
    Jun 2019
    I did it, but it was because I was running the luftkappe. With the luftkappe the front sat about 5-6mm into travel with just the weight of the bike.
    Nov 2014
    Quote Originally Posted by SaintJV View Post
    Debatable. Reach isn't shortened as much with the angle set, stack is not changed, bb height gets slightly lower instead of higher, STA steeper instead of slacker. HA and WB are approx the same between 170 fork vs. angle set, so it really depends what you are looking for.
    I'm running a -1 angle set on my Ripmo and it's great. I would be interested to try the angle set AND the 170 fork because those numbers look pretty spicy on the geometry calculator
    Oct 2012
    What I like is higher bb. the rest is for me almost unnoticed.
    Jun 2019
    I have the 170mm fork on my ripmo and works great, now looking for an angle set to slacken it a bit so it is more balanced.
    Nov 2016
    Quote Originally Posted by Herch View Post
    What did you notice when switching to the Luftkappe?
    Mar 2011
    Quote Originally Posted by matt.s67 View Post
    I’ve luftkappe’d both of my 36s. Amazing upgrade. The small bump chatter that the fox forks are always talked about having is gone. Even with the new EVOL air shaft, luftkappe makes a noticeable improvement.
    #bleedblackdieevil
    Rollin 29s
    Reputation: isleblue65's Avatar
    I’ve already removed the single volume spacer from my 2019 36 when I converted from 160 to 170 shaft. Luftkappe suggests removing 2 tokens from your pre Luftkappe setup.
    I would definitely benefit from small bump and early stroke compliance, but it sounds like the effect of Luftkappe installation will be like adding two VS. that will be way too fast ramp up mid stroke. At least this is my assumption.
    Experience with zero VS pre and post Luftkappe install?
    Whoever invented the bicycle deserves the thanks of humanity.
    - Lord Charles Beresford
    Apr 2013
    Anyone not happy with 170 mm that has gone back to 160 mm? Looking for a new fork and can not decide between 160 or 170 mm.
    Nov 2007
    Depends on how you ride it. If it is mainly a trail bike, stick with 160 and stock HA. If it is mainly a shuttle / gravity bike with fire road climbs to get to the trail head, go 170.
    I have tried both, 160 is nicer for flattish trails and techy climbs.
    Reputation: Trackho's Avatar
    Quote Originally Posted by magnil View Post
    It’s just a $40 airspring assembly. I swapped mine to 170mm, I definitely like it. Doesn’t turn as quick, which was expected, so at first I was running a tad wide on exit of corners, but got it dialed pretty well.
  1. Ripmo questions (170mm fork and leverage rate?)
    By Streetdoctor in forum Ibis
    Last Post: 02-15-2019, 07:34 AM
  2. Replies: 46
    Last Post: 02-10-2019, 08:43 AM
  3. Replies: 4
    Last Post: 01-02-2019, 02:46 PM
  4. Replies: 0
    Last Post: 03-09-2018, 11:42 AM
  5. side by side 170mm 66rc and 170mm slider+
    By kyle in forum Downhill - Freeride
    Last Post: 01-07-2005, 08:18 AM
Members who have read this thread: 75
