What fork's travel possible for Haro Thread?- Mtbr.com
    Reputation: mesier's Avatar
    I ride Haro Thread One ' 07 with standard 80 mm fork's travel.
    I could install 100 mm fork, but I not sure of this good idea...
    What your opinion about this?
    Haro Product Manager
    Reputation: PatSS's Avatar
    Quote Originally Posted by mesier
    You can, the bike is designed around a 80mm fork so putting a 100mm fork on will slacken your headangle out about 2 degrees. The bike wont handle quite the same but it will work
    In other words, you not recommend to install 100-mm fork?
    You can use a 100mm fork if you want too. It will not void any warranty you have but it will slacken your head angle. If you feel the bike steers too quick for you now that might be a good option for you.
