• 09-19-2007
    dbo43867
    URGENT!!! Fork Question, Haro Escape
    I have a 2007 Haro Escape Sport with the Marzocchi MZ Race fork 120mm. I am wondering if I could put a 2005 Marzocchi Dirt Jumper 3 100m with a 7 1/4 inch steerer tube and a 20mm Axel. Also, would it be worth the upgrade for someone riding xc/some jumps? Would everything bolt up, and if not what would need to change? Thanks
  • 09-19-2007
    dankilling
    Measure the steerer first- 7 1/4 is pretty short. Also, you would need a new front hub. Worth it? If you are into DJ, a through axle is a good idea, however, make sure the fork hasnt been beaten because any fork with several seasons of DJ in it is likely coming to the end of its service life.
  • 09-20-2007
    downhilljill
    Agreed Dan. Unless the fork is new old stock or the dude is giving it to you, I'd be wary of a used DJ fork. They just get beat to hell.
    And yes, 7 1/4 does seem short. Whether or not it fits will depend not just on the HT length of your bike, but what stem, HS, and spacers you run with it.
